Heres the output from hdparm v5.2 [couldn't find a binary of 5.3 for Redhat].
I ran hdparm -I /dev/hda
/dev/hda:
ATA device, with non-removable media
Model Number: Maxtor 6Y120L0
Serial Number: Y40QEKSE
Firmware Revision: YAR41VW0
Standards:
Supported: 7 6 5 4
Likely used: 7
Configuration:
Logical max current
cylinders 19 19
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 19152
LBA user addressable sectors: 20000
device size with M = 1024*1024: 9 MBytes
device size with M = 1000*1000: 10 MBytes
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 1
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: unknown setting (0x0000)
Recommended acoustic management value: 192, current value: 192
DMA: mdma0 mdma1 mdma2 udma0 udma1 *udma2 udma3 udma4 udma5 udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* NOP cmd
* READ BUFFER cmd
* WRITE BUFFER cmd
* Host Protected Area feature set
* Look-ahead
* Write cache
* Power Management feature set
Security Mode feature set
* SMART feature set
* FLUSH CACHE EXT command
* Mandatory FLUSH CACHE command
* Device Configuration Overlay feature set
* Automatic Acoustic Management feature set
SET MAX security extension
Advanced Power Management feature set
* DOWNLOAD MICROCODE cmd
* SMART self-test
* SMART error logging
Security:
Master password revision code = 65534
supported
not enabled
not locked
not frozen
not expired: security count
not supported: enhanced erase
HW reset results:
CBLID- above Vih
Device num = 0 determined by the jumper
Checksum: correct
Attached is the output from /proc/ide/hda/identify
Now looking at the output from hdparm -I [above] can't see if the problem is the unlock - doesn't look like the drive is locked to me.
Still the info will be in the relevant parts of the attached identify output.
149724-IDENTIFY (271 downloads)
