OK. I think you were right regarding the Fidsift.sh thing. I searched for it and found a post by Mark where he said the automatic translation worked only through /empeg/fids0/ and /empeg/fids1/, and not through /drive0/fids and /drive1/fids which is what EmpegLink was using. I recompiled using /empeg/fids?/ and it works the same for me (i dont use fidsift.sh). But it will probably now work for you as well. Please check it out. The new EmpegLink is attached. I also updated the distribution files. Hope this change doesnt break anything....
Edit: Important - Before running EMSC again after installing the new EmpegLink, make sure you delete the zero length "Empeg.your.empeg.ip.addr.PlayerDB" file that was created in the EMSC directory, or that you run EMSC with the "-r" option.
212292-empegLink (299 downloads)
Edited by jules (16/04/2004 22:45)
