#248011 - 06/03/2005 05:23
Re: Metal Buttons - options, ideas, prototypes, designs, etc.
[Re: FireFox31]
Loc: East Coast, USA
Here are those metal button light option mockups I promised. I used plastic buttons because I don't have metal yet:
The design goals are:
Add colored lighting to metal buttons.
Minimum disruption to the beautiful metal surface.
Allow colors to be changed.
Keep it simple to keep costs down.
The red on the left are 3mm end glow fiber rods. The green on the right are 1.5mm end glow fiber rods. They are long enough to be close to the LEDs, but not touching, even when the button is pressed. I had no idea how to polish the ends, so they could be even brigher if done right.
The rods are simply pushed into holes of (almost) the same size. They are not glued so they can be popped out and replaced with other colors.
Does this modification satisfy your metal + lighting needs? I could buy a drill press and make this modification as requested. Or, with enough interest, have the machine shop punch a certain amount. I plan to include a full rainbow kit of lighting rods; one set of each color, so you'll have them when you need them.
Then the size question: 3mm or 1.5mm or either? Allowing for either would work with enough interest. Otherwise, it's best to choose one size for all lighting rods.
I hope this give you the best of both worlds. Let me know what you think.
- FireFox31 110gig MKIIa (30+80), Eutronix lights, 32 meg stacked RAM, Filener orange gel lens, Greenlights Lit Buttons green set
FireFox31
29/01/2005 03:46
peakmop
29/01/2005 05:03
mtempsch
29/01/2005 06:47
mcomb
30/01/2005 22:42
Mach
31/01/2005 15:28
mtempsch
31/01/2005 17:30
FireFox31
27/02/2005 21:11
SonicSnoop
27/02/2005 21:52
mtempsch
28/02/2005 04:33
Qtqc
03/03/2005 13:57
FireFox31
06/03/2005 05:23
RobotCaleb
06/03/2005 05:43
SE_Sport_Driver
06/03/2005 18:07
pgrzelak
07/03/2005 09:12
FireFox31
08/03/2005 02:55
FireFox31
22/03/2005 19:05
peakmop
23/04/2005 02:24
