#298425 - 25/06/2007 19:27
Re: Tuner - In and out of stereo
[Re: Sheepdip]
Quote: I know it doesn't help but I'm now suffering the same problem after years of perfect reception. The FM station keeps cutting out and after some lengthy observation, it seems to coincide with the stereo symbol being displayed / stereo being received. I can even get full signal strength, but if that logo's not there I only get static. As this is a new issue I can only assume it's something to do with the tuner module itself. Dry joint may be as it 'seems' to be worse when everything's cold?
p.s. I've never been able to receive any AM stations for some reason I don't understand
That's not the same problem being described earlier in this thread. Your problem sounds like you totally lose radio sound, whereas the original problem was just losing the stereo effect.
Your problem is very likely the "dead tuner" problem that many people have run into. Replacement of the RF module seems to be the only solution to date -- Patrick has spares for PCATS tuners, but those can also be fitted specially into factory tuners.
