#299329 - 12/06/2007 18:40
Re: Loose Something??
[Re: Dbqsmurf]
Quote: but under the hardrive holder on the front right side is a probably the higest thing on the board and when it would hit a bump it will bump this part and reset itself anyone know how to fix it or is it just loose and need to be resoldered?
If you mean that black inductor thingie on the back side of the display board, then.. yes, it probably just needs resoldering -- common failure, that.
But also check the display ribbon cable for nicks or wear/tear, because it sometimes gets pinched and shorts out against the display board.
