#299466 - 17/06/2007 00:48
Re: Empeg not working, probably IDE problems
Quote: There's definitely something wrong with the hardware here -- the SMC ethernet chip is not being detected, plus the hard drive data is getting corrupted.
Could be a bad cable, bad header, bad SMC chip, or other possibliities.
Mmm.. since the D7 line appears to be stuck high, I'm leaning towards a faulty SMC ethernet chip as the culprit now. But it does require some hardware debugging to make sure of that -- soldering and lifting pins and such.
