Do the capacitor trick now.
Okay... I couldn't find a low value cap, so I used a resistor, instead. Assuming I did it correctly, then nothing changed. Can you confirm that I was doing the right thing, from the photo?
The area in the box, with the question mark is what I had thought were the resistors to check, but wasn't sure.
The other interesting thing to note -- after trying this, I left the RCAs with no output plugged into the stereo, cranked it (with the empeg volume maxed out, as well), and was able to hear the music, though faintly.
Edited by canuckInOR (12/06/2010 15:42)
