Ok Mark downloaded & Flashed the newest version, and here's what I get.
Visual: Scope, Info: Off
Show Flash savearea
Before:
40: 0001 0100 1026 0100
48: C414 0000 2305 0000
After:
same as above
This is SO weird.
I've also tried applying 2.0b7 again, so of course HiJack was completely erased. But the weird thing is, I'm about 99% sure it kept ALL of my HiJack settings!
The temp warning was 122F, timeout was 5 minutes and Restore Visuals was Enabled. Are these the default settings cause I'm sure I changed the temp warning?
Could something be corrupt or something? I know I shouldn't be asking this, but are you sure line 40 & 48 are the correct lines to look at?
I've attached a dump of my player booting maybe you can see something?
63145-dump.TXT (195 downloads)
Edited by Fastrack (30/01/2002 16:44)
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
