#102286 - 30/06/2002 11:32 My home docking station pictures and description.
Right here. Enjoy!
#102287 - 30/06/2002 11:40 Re: My home docking station pictures and description. [Re: tfabris]
rockstar
very nice, as usual
#102288 - 30/06/2002 11:47 Re: My home docking station pictures and description. [Re: rockstar]
Thanks!
Next one will use a better grade of wood, I think. Plywood still doesn't look great even after it's stained.
#102289 - 30/06/2002 12:02 Re: My home docking station pictures and description. [Re: tfabris]
ElectricD7
Loc: Indiana, USA
Tony,
You should try laminate over the wood. Fairly inexpensive, and all you need is some adhesive and a flush router bit. I used black laminate over plywood for my arcade cabinet, and couldnt be happier with the results.
ED7 --------------------- 20G Mark2A SN#: 010101680 1997 Chrysler Sebring LXi
#102290 - 30/06/2002 12:03 Re: My home docking station pictures and description. [Re: tfabris]
Laura
Loc: Greenhills, Ohio
Any way you would be interested in doing one for my MKI or sending me some plans that I could have someone else make one for me? I kind of like the wood idea better than metal, it's classy looking. I do know someone with woodworking skills.
Laura
MKI #017/90
whatever
#102291 - 30/06/2002 12:05 Re: My home docking station pictures and description. [Re: tfabris]
Just a couple of ideas for the current version - If you have a router, you might try rounding the corners for a softer look. As far as the finish goes, you might try a couple coats of sealant to cover the grain and then paint it black. Black hides a multitude of imperfections I realize that that defeats half the purpose of using wood, but like you said, plywood doesn't have the most pleasing grain and color anyway.
#102292 - 30/06/2002 12:06 Re: My home docking station pictures and description. [Re: tfabris]
maczrool
Loc: Louisiana, USA
Why not use a nice exotic wood like Rosewood or Coco Bolo. They look best without stain at all. You can even get Rosewood plywood for the top and front and use solid Rosewood for the sides. I know that's what I would do anyway.
Stu
#102293 - 30/06/2002 12:10 Re: My home docking station pictures and description. [Re: ElectricD7]
Yes, laminate is the next thing I was considering. Although I prefer the look of solid wood, and I also prefer the look of stained wood over just plain black.
I actually have some better wood and I think the next one will just be done with that.
#102294 - 30/06/2002 12:15 Re: My home docking station pictures and description. [Re: Laura]
Any way you would be interested in doing one for my MKI .
Doing the woodworking is the hardest part for me, and after I finish the second one, I'll probably be completely burned out on woodworking for quite a while. So, I'd have to refuse.
There aren't any plans as such. This was kind of improvised. The only thing I did was to make some measurements and drew some rectangles in Corel Draw so I could decide on the size of the top, bottom, and front pieces so that I could get that 9 degree angle.
If you talk to your woodworking friend, he could probably come up with something much better if you showed him the photos and worked with him on the design.
Don't forget to allow enough space in the back for working with all the wires.
#102295 - 30/06/2002 13:03 Re: My home docking station pictures and description. [Re: Laura]
thinfourth2
this can be made to order if you ask my dad awfuly nicelly
#102296 - 30/06/2002 13:46 Re: My home docking station pictures and description. [Re: thinfourth2]
thrasher
Wow your dad did a great job,thats a sweet cabnet.I like the way that the plywood turned out.very nice job.
040103958 60g
#102297 - 30/06/2002 13:53 Re: My home docking station pictures and description. [Re: JBjorgen]
maczrool
Loc: Louisiana, USA
Plywood does not inherently have displeasing grain or color. It appearance depends on two things. The veneer used and the construction of the plys. If the edges are visible, it would be best plywood to use Baltic Birch plywood which has very thin plys. If the edges are hidden, it really can be hard to separate it from solid wood. The plywood used in his docking station is obviously veneered with rotary cut fir plywood like you find at hardware stores, which is not at all suited for fine woodworking. It's not even easy to make it look real good with paint.
Furniture grade plywoods which use quarter sawn or flat sawn veneers, are an excellent choice for the project as long as the edges are concealed.
Stu
#102298 - 30/06/2002 14:15 Re: My home docking station pictures and description. [Re: maczrool]
You are of course correct. I was referring to fir or pine plywood like the stuff used to sheet floors and roofs. I use birch all the time when making cabinetry, and it looks great. With something this small though, using solid wood rather than cutting strips to cover the ply edges would be recommended.
#102299 - 30/06/2002 14:20 Re: My home docking station pictures and description. [Re: thinfourth2]
Laura
Gee, I would love something like that for my stereo setup. Right now everything sits on a wire rack. How would I ask your dad and it would probably cost a lot to ship over the pond. You could ask him nicely for me and let me know how much it would cost
Laura
MKI #017/90
whatever
#102300 - 30/06/2002 15:31 Re: My home docking station pictures and description. [Re: JBjorgen]
elvis
Loc: Arizona USA
Hmm, I actually think it looks quite nice. I think the grain, finish etc all work well together. A satin finishing coat, something without too much shine would be perfect.
Elvis
#102301 - 30/06/2002 15:45 Re: My home docking station pictures and description. [Re: thinfourth2]
lockuplever
Loc: Tucson, AZ
They both look good to me, does anyone have any plans of producing these?
Steve
#102302 - 30/06/2002 16:51 Re: My home docking station pictures and description. [Re: tfabris]
mrfixit
Looks great Tony, I was thinking of making one for myself but I only have one sled and it's in the car. Do you know where I could get another sled?
Ben
Ben
hijacked
#102303 - 30/06/2002 19:09 Re: My home docking station pictures and description. [Re: tfabris]
foxtrot_xray
Loc: Atlanta, Georgia
That is pretty sweet, dude! How's the empeg slide out with the 'fixed' ethernet connection?
#102304 - 30/06/2002 20:28 Re: My home docking station pictures and description. [Re: mrfixit]
Order one before the Empeg International Store closes on May 31, 2002.
Help from Christian Williams might be necessary, though.
#102305 - 30/06/2002 20:59 Re: My home docking station pictures and description. [Re: tfabris]
mrfixit
Hey Tony, thats a good one. It just happens that I am a really big fan of the back to the future movies, so I know what you are saying, I found the post from philp69 listing the part#s for the main connector so Im going to make one. Besides Christian`s Delorean won't help... I didnt see a flux capacitor anywhere in it
Ben
Ben
hijacked
#102306 - 30/06/2002 21:53 Re: My home docking station pictures and description. [Re: mrfixit]
It's the newer model, the compact one. It's under the louvres with the upgraded Mister Fusion. They've done a lot to improve the system since Doc Brown's prototype.
#102307 - 30/06/2002 23:20 Re: My home docking station pictures and description. [Re: elvis]
muzza
Or you could coat it with plush fur. like this guy's computer
#102308 - 01/07/2002 08:07 Re: My home docking station pictures and description. [Re: muzza]
mrfixit
Now Iv seen everything!
Ben
Ben
hijacked
#102309 - 01/07/2002 09:37 Re: My home docking station pictures and description. [Re: muzza]
lockuplever
Loc: Tucson, AZ
unbelievable!
Steve
#102310 - 01/07/2002 09:48 Re: My home docking station pictures and description. [Re: muzza]
Seems someone misunderstood the term "fuzzy logic".
#102311 - 01/07/2002 09:56 Re: My home docking station pictures and description. [Re: tfabris]
Happy Birthday tonyc
*groan*
#102312 - 01/07/2002 10:03 Re: My home docking station pictures and description. [Re: tonyc]
Thank you, thank you, I'm here till Thursday.
Be sure to tip your servers.
#102313 - 01/07/2002 21:49 Re: My home docking station pictures and description. [Re: tfabris]
lectric
Loc: New Orleans, LA
Where do you people FIND this stuff?
#102314 - 02/07/2002 01:14 Re: My home docking station pictures and description. [Re: lectric]
It's out there, lectric.
#102315 - 02/07/2002 01:41 Re: My home docking station pictures and description. [Re: frog51]
Legoverse
Loc: Mesa, AZ
I Love It.
Way too much time and spare parts.
-- Terry K -- 30Gb Smoke / Toyota 4x4 30Gb Amber / Bounder RV Pants first, then shoes
