#119051 - 02/10/2002 16:46 Info_Bug
jets
Loc: Toronto, Canada
Using hijack v299. if i remove 'Info' from the PopUp0 that i have set to open when pressing the knob, i get an ir_translate config error on the empeg when i reboot. the PopUp0 then reverts to it's default menu items.
It seemed like a good idea at the time.
#119052 - 04/10/2002 08:01 Re: Info_Bug [Re: jets]
Post your config.ini file that gives the error, please.
#119053 - 04/10/2002 14:26 Re: Info_Bug [Re: mlord]
jets
I must note that I do not get the error after changinfg the .ini file and the empeg gets synced (the pc reboots it). It's only after I reboot myself that i get the error. Here you go:
[controls]
stalk_side=none
[tuner]
region=us
[Options]
Name=HelloAss
[User Info]
Email=XXXXX@XXXXX.com
Phone=XXXXXXX
Name=Mario
[Network]
Gateway=0.0.0.0
Netmask=255.255.0.0
IPAddress=169.254.122.140
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[display]
visual_names=0
caching=0
[synchronise]
seq_num=201
[hush]
hushpercent=50
[volumecap]
enabled=1
[kenwood]
disabled=1
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=0
[aux]
source=
title=
artist=
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
50=InfoTex
49=StarDust
48=Sphere Plasma
47=Tube Plasma
46=Variscan
45=Svecofennian
44=Caledonian
43=Hercynian
42=Grampian
41=Hofmann
40=Sugar Cube
39=Tripping Prisoner
38=Tubular
37=Pianola
36=TimeShade 128
35=StereoLog 32
34=StereoLog 128
33=SpectroLog 128
32=Spectrokit 128
31=Spectrometer 128
30=Spectrometer 64
29=Spectrometer 32
28=Spectrometer 16
27=Eventview 64
26=Eventview 32
25=Eventview 16
24=Lavatory Floor
23=BorgBeat
22=Fantasy Fishnets
21=Hula Hoops
20=Casualty
19=OurEmEss
18=OurEmEss LR
17=Anna Vu
16=Funnelweb
15=Marquesas
14=Oscilloscope Cave
13=Oscilloscope Terra
12=Oscilloscope Zoom
11=Oscilloscope Persist
10=Oscilloscope LR
9=Oscilloscope
8=Sound Samosa
7=Rorschach
6=SoundFlag
5=Shapescape
4=Image Pan
3=Swarm
2=Scope
1=Off
count=50
[VisualFavourites_FM]
count=0
[hijack]
standbyLED_on=0
PopUp0=La Menu
fake_tuner=1
menu_remove=Auto Volume Adjust
menu_remove=Button Codes Display
menu_remove=Button Illumination Level
menu_remove=Calculator
menu_remove=Filesystem Check on Sync
menu_remove=Home/Work Location
menu_remove=Left/Right Time Alignment
menu_remove=Show Flash Savearea
[ir_translate]
PopUp0=Detail,KnobSeek,Repeat,Shuffle,
KnobLeft.M=Visual.N,KnobLeft.U
KnobRight.M=Visual.N,KnobRight.U
it is definately The PopUp0 line causing the problem. After I got that error, I experimented and the only way i got rid of it was to make that line look like this:
PopUp0=Clock,Detail,Info,KnobSeek,Mark,Repeat,Shuffle
If I ever did get my way (someday haha), it would read Bookmarks,Detail,Info,KnobSeek,Mark,Repeat,Shuffle,VisualMenu with the knobleft for visual sequential backward/knob right for sequentiual forwards.
#119054 - 05/10/2002 05:33 Re: Info_Bug [Re: jets]
Get rid iof the excess comma ',' at the end of the PopUp0 line.
#119055 - 05/10/2002 07:03 Re: Info_Bug [Re: mlord]
jets
OMG! um....thanks.
