#127837 - 25/11/2002 12:44
Empegs don't bounce !
No, they definately do not bounce.
Hopefully the only damage sustained is the suspected broken VFD, as it seems to function OK. Carsupport already mailed.
Can you guys offer advise on anything that I should check (i.e. fuses ? ??) before I have to ship it back for repair.
LTJ
#127838 - 25/11/2002 12:49
Re: Empegs don't bounce !
[Re: LTJBukem]
Shake it gently to hear if there's anything loose. Do this with the power off. If you hear the fill neck of the VFD clattering around, that's most likely the problem. You should be able to verify it by removing the fascia with your Allen key: remove the knob and the display filter/lense. The VFD is the large glass unit (it's pretty obvious). Bottom right corner as you face it should have a filler neck: if it's gone, that's the problem.
#127839 - 25/11/2002 14:00
[Re: schofiel]
Not knowing what a filler neck is, i'm not sure. But on inspection there was a small glass 'breast' shaped bit floating around inside. Presumably that should have been in the hole on the right hand side of the display just below the level of the vol knob ?
Thanks for your help.
LTJ
#127840 - 25/11/2002 15:00
[Re: LTJBukem]
Yep - that's a broken fill nipple.
#127841 - 25/11/2002 15:02
[Re: LTJBukem]
Loc: Germany (Ruhrgebiet)
Yes, that was the filler neck/nipple.
cu,
sven
#127842 - 25/11/2002 22:07
[Re: smu]
Loc: East Coast, USA
<half joking> Lordey, can't we just find a way to put those things back on?
But really, breaking the glass breaks the vaccuum, I guess. Anyway that it could be refilled and have the glass heated and melted back in place? It just sucks that so many of these precious parts keep dying.
#127843 - 25/11/2002 22:36
[Re: FireFox31]
Possibly, unless something burns out when you power it up without vacuum/with air inside.
But the cost for the process would probably be on the same order, if not higher, as the cost for a new module. The modules are standard parts, after all...
#127844 - 26/11/2002 14:04
[Re: mtempsch]
The problem is that the nipple is so close to the pivot point that the lower row of leads provides. If you drop it, the foam pad behind the display compresses with the Force of the accelerated display unit. The unit rotates around the pins along the bottom of the display, and the nipple comes into contact with the rotary switch. Due to the length of the lever arm created, you get a nutcracker effect on the nipple, and POW it breaks off.
The only way to stop it is to use a dense double sided foam pad of the same thickness as the depth of the leads, instead of the low-density foam tape used at the moment. This doesn't compress so much on impact and it MIGHT help, but I'm not really prepared to test my theory.
The problem gets worse if you use a PCB for illumination over the shaft of the rotary switch. Thing to do is remove the switch!!!
#127845 - 26/11/2002 15:18
[Re: schofiel]
Mk.1 players suffer exactly the same fate when dropped - and they have no rotary control.
#127846 - 26/11/2002 15:21
[Re: rob]
hopefully lads@empeg will contact me tommorow and tell me what to do ? It was all quiet on the Cambridge front today ...
Ta
LTJ
#127847 - 26/11/2002 15:35
[Re: LTJBukem]
Lad, singular. David to be precise.
The rest of us work for Engineering, thank god
#127848 - 26/11/2002 15:50
[Re: rob]
Is he is East Angular tomorrow ?
LTJ
#127849 - 26/11/2002 15:56
[Re: FireFox31]
Loc: Squamish, BC
I think you'd have to re-empty it, not re-fill it
A.
#127850 - 26/11/2002 16:14
[Re: LTJBukem]
Anonymous
Unregistered
I had a parachute system installed on my empeg. The internal gyroscopes are triggered when they sense the player starting to accelerate at 1G, and they deploy a miniature chute about 1 foot in diameter. If for some reason the acceleration does not immediately slow down, it will automatically fire the reserve. The only downside is I have to repack the chute everytime I drop it.
My next project will be installing a propeller that will serve two purposes:
1) it will keep the player from overheating
2) when the player is dropped, it will auto-rotate it safely to the ground.
#127851 - 26/11/2002 20:35
[Re: ]
Hey, my empeg did bounce.. I droped it a few days ago on my concrete driveway, it fell about two feet and landed on it's left side. Instantly my stomach flew up into my mouth and I had to swallow it. Luckily I had it in a fairly well paded bag (case logic cd player case) and it was ok... but I still freaked when it fell.
Ben mk2a 60gig green/Greenlights Buttons mk2a 60gig green/Greenlights Buttons mk2a 40gig blue no illumination....yet hijacked
#127852 - 26/11/2002 22:19
[Re: ]
Loc: US: CA
You mean accelerate past 1G. If it were triggered at 1G it would always be deployed. ;p
#127853 - 27/11/2002 02:55
[Re: rob]
However, they do have the "winker" LED right next to the nipple, and the display is mounted the same way, hence I am not really surprised that they break in the same failure mode.
I think I'm going to have a look at high-density sticky foam to replace the original support foam, and raise the top edge of the display away form the board a little to give a touch more clearance. It's a shame that (even though not designed for this) given the good disk shock mounts, the impact resistant disks, and the generally rugged stainless construction of the case, the the display failure occurs so often due to a mechanical shock fault.
#127854 - 27/11/2002 13:54
[Re: ricin]
no because it has to accelerate to one G. When you hold it still, it isn't accelerating.
I personally have an antigrav implanted in mine. that way it never falls
Murray
Is it the 'N', or the 'Zero'?
#127855 - 27/11/2002 14:12
[Re: muzza]
But it really sucks when you let go of it and have to watch it float away...
#127856 - 27/11/2002 15:35
[Re: muzza]
[grammar nazi]
Since one G is a measure of acceleration, you are really saying "No because it has to accelerate to a known acceleration" which doesn't make any sense. It could accelerate at a rate of 0.01m/s/s until the sun implodes, and would still not get to 1G. (It'd still be at 0.01m/s/s, ignoring gravitational effects from the aforementioned solar catastrohpy)
What I think you meant to say was "It's acceleration has to increase to 1G".
[/grammar nazi]
#127857 - 27/11/2002 17:06
[Re: genixia]
picky picky
I have it finely tuned to not be greater than one G. if anything, it decends very slowly. it can also detenct whether it is decending rapidly, and ramps up the antiG accordingly.
OK Grammar Nazi, It has a levitation device. Which just WORKS. OK? If I had to explain its existance it would cease to exist. Like God. It's a faith thing. I have faith that it works, It has faith that I believe it exists and everything's sweet.
Murray
#127858 - 27/11/2002 17:16
[Re: muzza]
Hey, I wasn't questioning that your anti-grav device worked! I'd really like one for my empeg...can I buy one for less than the amount of money that I'm receiving from the sale of London Bridge?
#127859 - 27/11/2002 18:13
[Re: genixia]
Actually I don't believe 1 g is sufficient to brake your Empeg. If it was, than mine would have been broken long ago. I know I've subjected it to 1 g of deceleration in my CRX. Perhaps the real answer is 20, 30 50, 100? g's as the Empeg goes through rapid deceleration as it strikes a hard surface?
Happy Thanksgiving to all of you Yanks out there.
#127860 - 27/11/2002 23:34
[Re: muzza]
My answer was a big ol' helium filled balloon. It sucks to see around in the car though...
#127861 - 27/11/2002 23:55
[Re: Tim]
But it works really good for ordering food at a drive thru.
#127862 - 28/11/2002 00:16
[Re: muzza]
Loc: US: CA
My point was that, even siting still, the empeg (and anything else, for that matter) is always at 1G. When on Earth, anyway.
Edited by ricin (28/11/2002 00:17)
#127863 - 28/11/2002 07:58
[Re: Neutrino]
Hahaha
#127864 - 28/11/2002 14:09
[Re: ricin]
G is the planetary constant of attraction, not the acceleration due to the Earth's mass, which is g (9.8 ms-2). An object at rest within the earth's gravity field is subject to a force which results in an acceleration when unopposed: a box lying on the ground is being opposed with a force equal to that exerted by the mass of the box, so the net acceleration is zero.
#127865 - 28/11/2002 14:10
[Re: Neutrino]
I've seen 1.6 g on the Mini, and it did sod all.
#127866 - 28/11/2002 17:50
[Re: schofiel]
Loc: US: CA
Ahh, I meant 1g then. You all knew what I was trying to say.
#127867 - 29/11/2002 08:41
[Re: schofiel]
No it's not. It's the universal gravitational constant. Nothing planetary about it. It's the constant of attraction between any two masses.
It's stupidly small, and has some totally daft units:
G = 6.672x10^-11 N m^2 kg^-2
See:
http://scienceworld.wolfram.com/physics/GravitationalConstant.html
#127868 - 29/11/2002 09:40
[Re: Roger]
Loc: Lochcarron and Edinburgh
[G is] stupidly small, and has some totally daft units:
Au contraire, the units make a lot of sense. The force is proportional to the product of the two masses you're considering, and inversely proportional to the square their separation. So, multiply G by two masses (kg^2) and divide it by the square of the distance (m^-2), and lo&behold, you end up with a number of newtons - just as you'd expect for a force.
Dimensional analysis, lesson one.
#127869 - 29/11/2002 10:32
[Re: tms13]
Oh, I can do dimensional analysis. Many moons ago, I even managed to pick up a Physics A-Level.
My point is: "square kilograms"?
I know why, it's just hard to visualise.
#127870 - 29/11/2002 11:13
[Re: tms13]
Ah, another convient unit of measure. Just like every constant K in the world of chemistry and physics. Isn't it neat how they all just HAPPEN to cancel out all the unnecessary units you don't need? Damned if I could think of one right now though since I haven't used them in 6 years.
#127871 - 29/11/2002 11:24
[Re: Roger]
It always sat uneasily with me, doing F=Gm1m2/(r^2) at A-level, that the LHS is clearly vector while the RHS is equally clearly scalar unless you cheat by multiplying by r-hat.
Edit: r-hat, not |r|.
#127872 - 29/11/2002 16:40
[Re: peter]
Hell this is way too complicated ...
I just emailed support and TNT are picking it up on Monday. What could be simpler ! Thanks Guys
LTJ
