#130079 - 10/12/2002 04:19 Odd Boot message
furtive
I've getting the following message (in Hyperterminal) when my empeg boots. Any idea what's causing it?
serial_notify_thread.cpp: 116:@@ N110
serial_notify_thread.cpp: 117:@@ F0x3000
serial_notify_thread.cpp: 118:@@ TA Lap Dance Is So Much Better
serial_notify_thread.cpp: 119:@@ ABloodhound Gang
serial_notify_thread.cpp: 120:@@ GPop
serial_notify_thread.cpp: 180:@@ #0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
Also, when trying to synchronise with emplode it hangs at Checking Disk Integrity:
Rio Karma - now on ebay...
#130080 - 10/12/2002 04:20 Re: Odd Boot message [Re: furtive]
furtive
Additional: In hyperterminal when synchronising emplode, I get this:
Adding Swap: 15084k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
#130081 - 10/12/2002 04:44 Re: Odd Boot message [Re: furtive]
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
You can ignore this. It's caused by the absence of /etc/mtab.
#130082 - 10/12/2002 04:46 Re: Odd Boot message [Re: furtive]
You've got notify=1 in config.ini somewhere.
#130083 - 10/12/2002 04:47 Re: Odd Boot message [Re: furtive]
Are you sure? It takes a long time for that progress bar to start moving. Leave it for an hour and see if it's still hung.
#130084 - 10/12/2002 04:47 Re: Odd Boot message [Re: Roger]
furtive
What does that do, how do I change it, what should I change it to, and will it stop the problems synching with emplode?
