#136389 - 22/01/2003 09:24 Mime types in XP
Anyone know how to change MIME allocations in XP? It used to be in Folder Options from Explorer but it's not there any more.
I installed an annoying program that provided browser viewers for every file type you can think of, but it didn't restore the old associations when I uninstalled it. Therefore if I click on, say, a Word file (application/msword) instead of opening Word it does nothing.
#136390 - 22/01/2003 09:31 Re: Mime types in XP [Re: rob]
Terminator
Loc: Dallas, TX
Did you try my computer -> tools -> folder options -> file types? Im not sure if you tried it from internet explorer or not. You can also try tools -> folder options from the control panel.
Sean
#136391 - 22/01/2003 10:53 Re: Mime types in XP [Re: rob]
Look in:
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/msword
It should contain a single string value, called 'Extension', containing '.doc'
Then, go and look in:
HKEY_CLASSES_ROOT\.doc
It should have a string value, called 'Content Type', containing 'application/msword'.
The '(Default)' value should contain 'Word.Document.8'
Then, there's a bunch more scary stuff in:
HKEY_CLASSES_ROOT\Word.Document.8
The easiest option, however, is probably just to go to Control Panel/Add or Remove Software/Microsoft Office, and try the 'Repair' option.
Whether that actually does any good remains to be seen, however.
#136392 - 22/01/2003 15:39 Re: Mime types in XP [Re: Roger]
Ezekiel
Loc: NH USA
M$ Office 'Repair' often requires the install CD, which can be a pain if you haven't got it, FWIW.
-Zeke
WWFSMD?
