#145325 - 23/02/2003 15:22 example song for using emphatic ?
newguy1
Loc: Massachusetts,USA
I finally got this installed(emphatic; thanks to all involved in that) on my player .But i cant quite figure out how to tag my own songs with the lyrics and get them on the player .Could someone provide me a sample song so i can see how this works please.Or even better provide me with Idiot instructions to do this.I do have winamp with the Lyrics 1.22 plugin and im running win 2k.Any comments good or bad accepted
MIKE 80Gb RIO
#145326 - 23/02/2003 16:08 Re: example song for using emphatic ? [Re: newguy1]
Well, I'm hoping that in the future, this process will be a little easier, but here's the way to go for now:
1) Find the lyrics to your song(s) on the Internet.
2) Select the text of the lyrics on the web page, and copy them (Ctrl-C usually.)
3) Open the Lyrics window in WinAMP (there should be a little icon that looks like a book in your system tray.)
4) Click on the top of the Lyrics window (just so it has focus) and hit Ctrl-L to go into "edit lyrics" mode.
5) Hit Ctrl-V to paste the lyrics into the window.
6) Hit Ctrl-D to switch into "add time tags" mode.
7) Hit the Play icon on Winamp, and, as each line comes up in the song, click that line in the WinAmp lyrics window. It will add the time tag to the left of each line. Just do it once per line, and do it when that line first begins playing.
8) Keep adding time tags until you're done.
9) Once you're done, click the little wrench icon on the lyrics window and select "Save as LRC." Save it to a file.
10) Use lrctool to add the lyrics to your MP3. (lrctool is available from the emphatic page, http://empeg.webhop.net/emphatic.html.) To add the lyrics to your MP3, run the following from a DOS prompt:
lrctool lrc2sylt filename.lrc filename.mp3
Where filename.lrc is the LRC file you saved from WinAMP, and filename.mp3 is your MP3 file. Once this is done successfully, you just need to send the MP3 over to your empeg and you're done.
Another way you could do it would be to substitute Step 9 with "save as Lyrics3" and then run lrctool with this syntax:
lrctool l32sylt filename.mp3
Either way will work, but having the LRC file separate is good so you can share it with others later.
I'm working on ways to reduce the number of steps, but right now, that's how it works. Pretty soon lrcdb.com is launching, that will provide people with a way to share LRC files, which will help reduce the amount of work for everyone involved. If you're having trouble with the above instructions, then be paitent, I'm working on some ways to make this easier.
Hope this helps.
#145327 - 23/02/2003 16:29 Re: example song for using emphatic ? [Re: tonyc]
newguy1
Thank you ill try that out .It sounds pretty easy.I guess that means Ill have to replace the tagged song with the nontagged song on the Empeg and sync each time this is done.Correct?
MIKE 80Gb RIO
#145328 - 23/02/2003 16:31 Re: example song for using emphatic ? [Re: newguy1]
Well, yeah. I've been discussing alternatives, but right now, that's how it works.
#145329 - 24/02/2003 11:47 Re: example song for using emphatic ? [Re: tonyc]
jamville
Loc: South Texas
Tony,
What version of Winamp and which (if any) plugins?
Thanks,
Joe Mumme
#145330 - 24/02/2003 11:54 Re: example song for using emphatic ? [Re: jamville]
Oh, sorry, I figured everyone had been following previous threads.
WinAMP Lyrics is the best plugin I've seen for our purposes. There are others that write to LRC or Lyrics3 specs, but none have interfaces that I like. It's a WinAMP 2.x plugin. I haven't seen any Winamp3 components that do the job, and Winamp3 is slow enough on my system that I didn't look very hard.
Incidentally I wrote the author of Winamp Lyrics asking if he would be willing to publish/share his source, but I'm not holding my breath on a positive response.
#145331 - 24/02/2003 12:25 Re: example song for using emphatic ? [Re: tonyc]
TheAmigo
If that doesn't pan out, would you mind giving him source to lrc2sylt and ask if he'd integrate SYLT writing into the plugin?
--The Amigo
#145332 - 24/02/2003 12:36 Re: example song for using emphatic ? [Re: TheAmigo]
Well considering my stuff is written in C and his plugin is written in Delphi, I didn't think he'd care for that approach. Esp. considering he hasn't touched the lyrics plugin in upwards of 3 years.
#145333 - 24/02/2003 16:39 Re: example song for using emphatic ? [Re: tonyc]
jamville
Loc: South Texas
Thanks for the WinAmp info.
Joe Mumme
#145334 - 24/02/2003 16:43 emphatic question [Re: tonyc]
jamville
Loc: South Texas
Where does emphatic in HiJack.
(I have emphatic installed as per the readme & have changed the config.ini.)
Joe Mumme
#145335 - 24/02/2003 17:22 Re: emphatic question [Re: jamville]
Think you're missing a verb in there, but I'll assume you're asking how to run emphatic? Bring up the Hijack menu (hold the knob in) and "emphatic" should be one of the options. If it's not, then something probably went wrong during installation, and if that's the case, posting a boot log from the serial console will help me determine what's going wrong.
#145336 - 24/02/2003 18:58 Re: emphatic question [Re: tonyc]
jamville
Loc: South Texas
Yes, that message is missing a verb,(I didn't proofread.)
Here it is Thanks
empeg dsp initialised
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
or forever hold their peace...it seems not. Let fly the initialised, PDIUSBD12
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v312 (root@ibbm) (gcc version 2.95
empeg single channel IDE
.3 20010315 (release)) #2 Tue Feb 4 20:03:25 EST 2003
hda: FUJITSU MHL2300AT, ATA DISK drive
Processor: Intel StrongARM-1100 revision 11SU MHL2300AT, ATA DISK drive
empeg-car player (hardware revision 9, serial number 30102949)DISK drive
hda: FUJITSU
Command line: mem=16mive
Calibrating delay loop... 207.67 BogoMIPSx038 on irq 6
Page cache hash table entries: 4096 (order 2, 16k)TF:TP MEM:6144b MAC 00:02:d7:26:0b:8
5
P
Linux NET4.0 for Linux 2.2
hda: hda1 < hda5 hda
NET4: Linux TCP/IP 1.0 for NET4.0ISK: Loading 320 blocks [1 disk]
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bhash 16384)ached, running e2fsck is recommended
VFS: Mounted root (ext2 filesy
ng.
Pre
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTtart a shell.
Signature is 67706d65 'empg'
Scheduling custom logo.he flash, let
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialisedy the Penguins of Linux!
Copying kernel...
Calling l
Processor: Int
empeg single channel IDEn 11
Probing primary interface...nder Floating Point Emulator
ide0 at 0x000-0x007,0x038 on irq 6peg-car player (hardware revision
hda: FUJITSU MHL2300AT, 28615MB w/204
empeg-flash driver initialized207.67 BogoMIPS
smc chip id/revision 0x3349emory: 15024k/16M available
smc9194.c:v0.12 03/06/96 by Er
hda: hda1 < hda5 hda6 > hda2 hda3 hda4order 2, 16k)
RAMDISK: ext2 filesystem found at block 0 testing by UNIFIX
EXT2-fs warning: checktime reached, running e2fsck is recommendednux TCP/IP 1.0 for NET4.0
IP Pro
empeg-pump v0.03 (19980601)84)
Press Ctrl-A to enter pump...change_root: old root has d_count=1Dag Brattli)
Linu
Trying to unmount old root ... okayue May 18 03:11:39 1999 )
Freeing unused kernel memory: 4k initempeg
Error mounting partitions (possibly already mounted)17) is a SA1100 UART
Remounting first music partition read-only= 16) is a SA1100 UART
Remounting second music partition read-only706d65 'empg'
S
No secondary hard diskStarting player
khttpd: listening on port 80dsp audio initialised
kftpd: listening on port 21sp mixer initialised
Restored terminal settings
empeg power-pic driver
RAM disk drive
No secondary hard diskdisks of 4096K size
Player exited normally: 1
Probing p
Starting bash.e...
empeg:/empeg/bin#
hda: FUJITSU MHL
or forever hold their peace...it seems nTSU MHL2300AT,
smc9194.c:v0.12 03/06/96 by Erik Stahlman
SMC9194: SMC91C94(r:9) at 0x4008000
Command line: mem=16mdone.
POSIX conformance testing by UNIFIX: 4k initDrive(s) appear to be alre
Based upon Swansea University Computer Society NET3.039s return to continue anyway - anything else to start a
IP Protocols: ICMP, UDP, TCP02 20001106 (hugo@empeg.com)
TCP: Hash tables configured (ehash 16384 bhash 16384) there is anyone present who wants to upgrade the fla
Copying kernel...
Calling linux kernel...
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART.............................. done, booting the
l.
Linux
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTrnal.empeg.com) (gcc versi
Scheduling custom logo.lease)) #130 Mon Oct 22
empeg dsp initialisedng Point Emulator V0.
empeg remote control/panel button initialised.9, seria
RAM disk driver initialized: 16 RAM disks of 4096K sizer 4, 64k)
empeg single channel IDEble entries: 4096 (order
Linu
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
empeg-flash driver initializedIP Protocols: ICMP, UDP, TCP
smc chip id/revision 0x3349CP: Hash tables configured
Partition check:
hda: hda1 < hda5 hda6 > hda2 hda3 hda4 virtual tty driver for IrCOMM ( revisi
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Signature is 677
Freeing unused kernel memory: 4k initempeg i
Tried to mount /dev/hdc4 but got error 6 PDIUSBD12 id 1012
Error mounting partitions (possibly already mounted)89/88c1 (sav
Remounting first music partition read-onlyRDS driver initialised
Remounting second music partition read-only(first boot)
No secondary hard disksk driver initialized:
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
khttpd: listening on port 80L2300AT, ATA DISK drive
e
No secondary hard diskalized
Player exited normally: 1/revision 0x3349
Switching to shell-player loop.12 03/06/96 by Erik Stahlman
Starting bash.
empeg:/empeg/bin# ÿIf there is anyone present who wants to upgrade the flash, le7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:8
t them speak now,
Copying kernel...s [1 disk] into r
Uncompressing Linux..................................... done, booting the kernes recom
V
l. M
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v312 (root@ibbm) (gcc version 2.9503 (19980601)
Trying to unmount o
ng.
Press retu
POSIX conformance testing by UNIFIXpeg49 (mac@aphex.internal.empeg.com
Based upon Swansea University Computer Society NET3.03915 (release)) #130 Mon Oct 22 18:52:07 BST 2001
Processor:
IP Protocols: ICMP, UDP, TCP 11
Calibrating de
Memory: 15024k/16M available
Signature is 67706d65 'empg'che hash table entries: 1638
empeg display initialised. cache hash table entries:
empeg dsp mixer initialisedmance testing by UNIFIX
Linux NET4.
empeg audio-in initialised, CS4231A revision a0upon Swansea Universit
Linux-IrDA: IrCOMM protocol
RAM disk driver initialized: 16 RAM disks of 4096K sizesion:Wed May 26 00:49:11 1999 )
SA1100 s
hda: FUJITSU MHL2300AT, ATA DISK drivel options enabled
empeg dsp mixer in
5i
Partition check:
EXT2-fs warning: checktime reached, running e2fsck is recommended89/88c1 (save to d0004f00).
VFS: Mounted root (ext2 filesystem).ver initialised
empeg-pump v0.03 (19980601)er initialised (first boot)
Press Ctrl-A to enter pump...hange_root: old root has d_couner initialized: 16 RAM
Mounting first music partitionve
hda: FUJITSU MHL230
hda:
ide0 at
emp
smc9194.c:v0.12 03/
VFS: Mounted r
Joe Mumme
#145337 - 24/02/2003 19:30 Re: emphatic question [Re: jamville]
Not seeing hijack_exec in there, so I think your EXEC_ONCE entry in config.ini must be botched.. Mind posting the [hijack] section of your config.ini?
#145338 - 24/02/2003 19:32 Re: emphatic question [Re: tonyc]
jamville
Loc: South Texas
[hijack]
khttpd_root_index=/drive0/opt/khttpd/charcoalgray99/index.html
;@EXEC_ONCE /usr/local/bin/emphatic
;@AC standbyLED_on=0
[output]
notify=1
[ir_translate]
;PopUp0=Shuffle,Info,Mark,Swap,Repeat,SelectMode,PopUp1
;PopUp1=Time,Artist,Album,Genre,Year,PopUp0
;Bottom.LU=PopUp1
;Bottom.LN=PopUp0
;@DC 00A85701=One; LD remote
;@DC 00A85702=Two; LD remote
;@DC 00A85703=Three; LD remote
;@DC 00A85704=Four; LD remote
;@DC 00A85705=Five; LD remote
;@DC 00A85706=Six; LD remote
;@DC 00A85707=Seven; LD remote
;@DC 00A85708=Eight; LD remote
;@DC 00A85709=Nine; LD remote
;@DC 00A85700=Zero; LD remote
;@DC 00A85753=prev;back; LD remote
;@DC 00A85717=Play;play; LD remote
;@DC 00A85752=Next;forward; LD remote
;@DC 00A85716=SelectMode;stop; LD remote
;@DC 00A85745=Cancel;clear; LD remote
;@DC 00A85743=search;display; LD remote
;@DC 00A8574D=Ok;A; LD remote
00A25D01=One
00A25D02=Two
00A25D03=Three
00A25D04=Four
00A25D05=Five
00A25D06=Six
00A25D07=Seven
00A25D08=Eight
00A25D09=Nine
00A25D00=Zero
00A25D0f=prev;back
00a25d17=knob;play
00a55a4c=play; cd sel
00a25d16=bottom; stop
00a25d18=top; pause
00A25D0e=Next;forward
00A25D16=SelectMode;stop
00A25D41=search;disc
00A25D52=Ok;10+
Joe Mumme
#145339 - 24/02/2003 19:36 Re: emphatic question [Re: jamville]
Umm... The boot log says you're on Hijack v312, and the khttpd_root_index option wasn't added until v313. I don't know if that throws off config.ini parsing or what, but certainly, it's a good idea to either upgrade to Hijack v320 or take that option out.. Otherwise, your syntax looks right and we should at least be getting an error if something else is wrong, like permission or filename errors.
#145340 - 24/02/2003 19:38 Re: emphatic question [Re: tonyc]
jamville
Loc: South Texas
Interesting,
On boot I see HiJack v320
Joe Mumme
#145341 - 24/02/2003 19:43 Re: emphatic question [Re: jamville]
<Hank Hill> That ain't right! </Hank Hill>
I was going by this:
On my boot log (v320) I see:
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320
Very odd that you'd see v320 when you boot up... When I saw that, I looked at the Hijack version log and saw that the khttpd_root_index option wasn't valid for that version. That's the only explanation I could come up with as to why we aren't seeing any errors (or success messages) relating to launching emphatic. On my boot log, I get this:
hijack_exec("/usr/local/bin/emphatic"), rc=0 (okay)
And if there were some kind of error, we'd see a non-zero number in the "rc=" field.
So I'm officially stumped.
#145342 - 24/02/2003 19:46 Re: emphatic question [Re: tonyc]
jamville
Loc: South Texas
Thanks for everything.
If/when I get it, I'll let you know.
Joe Mumme
#145343 - 24/02/2003 19:49 Re: emphatic question [Re: jamville]
Anyone else have any ideas here???
#145344 - 24/02/2003 22:06 Re: emphatic question [Re: tonyc]
mcomb
Loc: San Carlos, CA
Is it just me or is that serial output is all mangled? Perhaps some of that log is way old. Was that from a copy and paste or from capturing the log to a file? I am thinking that some (all?) of that is from a previous run which would explain the out of date hijack and the missing exec line. Try doing to serial capture again, this time to a new file and repost it.
-Mike
#145345 - 25/02/2003 00:47 Re: emphatic question [Re: mcomb]
jamville
Loc: South Texas
Okay, Attached is a captured text file.
I've been playing w/ the syntax in the config.ini. My current version looks like this:
[Startup]
ReserveCache=48
[Options]
Name=Number 4
[synchronise]
seq_num=67
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[User Info]
Email=jamville@jamville.com
Phone=xxx-xxx-xxxx
Name=Joe Mumme
[Network]
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.14
DHCP=0
[tuner]
region=us
[controls]
stalk_side=none
[hush]
hushpercent=20
[display]
visual_names=1
caching=0
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[power]
off_timeout=30000
[aux]
source=
title=
artist=
[sense]
muteaction=0
mute=-1
[hijack]
; dc_servers=1
; [serial]
; car_rate=115200
;@EXEC_ONCE= /usr/local/bin/emphatic
[output]
notify=1
[ir_translate]
;Bottom.LU=PopUp1
;Bottom.LN=PopUp0
00A25D01=One
00A25D02=Two
00A25D03=Three
00A25D04=Four
00A25D05=Five
00A25D06=Six
00A25D07=Seven
00A25D08=Eight
00A25D09=Nine
00A25D00=Zero
00A25D0f=prev;back
00a25d17=knob;play
00a25d18=top; pause
00A25D52=Ok;10+
143462-emplog.TXT (368 downloads)
Joe Mumme
#145346 - 25/02/2003 07:57 Re: emphatic question [Re: jamville]
genixia
should be
#145347 - 25/02/2003 13:07 Re: emphatic question [Re: jamville]
mcomb
Loc: San Carlos, CA
Ahh, much better, there is hijack 320 and as genixia said it looks like the problem is that equals sign. If Mark is reading it would be nice if hijack would warn on lines that it can't parse as there is no error in that bootlog.
-Mike
#145348 - 25/02/2003 15:01 Re: emphatic question [Re: genixia]
jamville
Loc: South Texas
Okay, I took the = out
It now looks like HiJack tries to run it.
However I get:
hijack_do_execve: execve() failed, errno = 2
hijack_exec("/usr/local/bin/emphatic"), rc=-2 (ERROR)
Joe Mumme
#145349 - 25/02/2003 15:35 Re: emphatic question [Re: jamville]
Yang
Loc: Raleigh, NC
Make sure that emphatic is set executable.
#145350 - 25/02/2003 15:36 Re: emphatic question [Re: Yang]
jamville
Loc: South Texas
How does one go about that?
Joe Mumme
#145351 - 25/02/2003 15:38 Re: emphatic question [Re: jamville]
Yang
Loc: Raleigh, NC
'chmod +x /usr/local/bin/emphatic' either from the serial or from telnetd
I'm not sure, but you may have to use rw/ro as well.
#145352 - 25/02/2003 15:42 Re: emphatic question [Re: Yang]
jamville
Loc: South Texas
Thanks, I'll have a go at it.
I found that you can change file permissions w/ Charcoalgray's ftp browser.
And also emphatic runs now.
Thanks ever so much,
Edited by jamville (25/02/2003 15:49)
Joe Mumme
#145353 - 25/02/2003 15:50 Re: emphatic question [Re: jamville]
Daria
You also get this error if you have no interpreter.
Though I can't imagine he'd have a copy linked against other than /lib/ld-linux.so.2 or that that wouldn't exist on his system.
