#148855 - 16/03/2003 04:44 Long fsck on one drive but not on the other
Can anyone see a reason why a fsck would take substantially longer on one drive (Hitachi Travelstar 40GB) than another (Fujitsu 30GB)?
You can see in my boot log below where I timed a fsck on each drive. One took 12 minutes the other a little over two. The fast drive is about 25/30GB full and the the slow one is only about 15/40GB full.
The slow drive is the system drive if that could make any difference.
Any ideas? I just noticed when syncing on the checking media stage (I guess the fsck was due), that it was taking quite a long time so I did it myself manually.
There are no irq timeout etc errors that are quite often a sign of a dying drive. Am I paranoid?
Just found it a little strange that my brand new IBM would take that much longer to fsck than the original Fujitsu.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 9, serial number 40104192)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9bbb0
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATCS04-0, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:60
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1517/4096 files (0.5% non-contiguous), 9446/16384 blocks
empeg:/empeg/bin# time fsck -fayVC /dev/hdc4
[/sbin/fsck.ext2 -- /dev/hdc4] fsck.ext2 -fay -C0 /dev/hdc4
/dev/hdc4: 10303/228352 files (9.8% non-contiguous), 6157817/7304850 blocks
real 2m23.148s
user 0m16.630s
sys 0m6.790s
real 2m23.233s
user 0m16.190s
sys 0m6.890s
empeg:/empeg/bin# time fsck -fayVC /dev/hda4
[/sbin/fsck.ext2 -- /drive0] fsck.ext2 -fay -C0 /dev/hda4
/dev/hda4: 4425/304448 files (28.9% non-contiguous), 11223749/38965657 blocks
real 12m25.375s
user 0m37.270s
sys 0m23.790s
empeg:/empeg/bin#
#148856 - 16/03/2003 06:03 Re: Long fsck on one drive but not on the other [Re: Shonky]
The fast drive is about 25/30GB full and the slow one is only about 15/40GB full.
The swap partition is on the system drive. Paging fsck or swapping its data will cause lots of time-consuming seeks if you're fscking a partition on the same drive. But I'm still surprised that there's a factor of six difference. Maybe the fsck data structures for 30GB's worth of disk just fit in memory, and for a 40GB disk they don't and it thrashes swap?
The actual disk performance -- whether data rate, spin speed, or seek time -- makes a lot less difference in these circumstances, unless the slow disk is actually dying (and doing a lot of retries), which seems unlikely.
#148857 - 16/03/2003 08:12 Re: Long fsck on one drive but not on the other [Re: Shonky]
Very simple: the "slow" drive isn't really that slow, it just has a LOT more data on it. Look at the "block counts" rather than the file counts. The "slower" drive has almost double the amount of data stored on it, which may be enough to cause some "thrashing" in e2fsck (cannot hold all data structures in memory at once, so it has to reread some of them over and over ..).
#148858 - 16/03/2003 08:28 Re: Long fsck on one drive but not on the other [Re: mlord]
Maybe he could try activating the secondary drive's swap space instead of the primary's and see if that significantly changes the time. (I'm correctly remembering that /swapfile is just a link to a partition, aren't I?)
#148859 - 16/03/2003 12:29 Re: Long fsck on one drive but not on the other [Re: mlord]
Oooh, good spot. Probably part of the problem is that the slow drive was mke2fs'd with a 1K block size, and the fast drive with a 4K block size. With nearly half the files on the filesystem several megabytes in length, 4K is obviously more efficient. The slow drive is only 30% bigger but has five times as many blocks, and I can bet fsck has some data structures sized by block count. Were these drives formatted with the builder image, or by hand?
#148860 - 16/03/2003 16:55 Re: Long fsck on one drive but not on the other [Re: peter]
The "fast" drive is the original drive from the factory and has never been reformatted or anything like that. So it is as it came from the factory.
The second drive was a brand new drive installed in the player and formatted using the disk builder. I followed the instructions word for word from the Drive Upgrade page on riocar.org.
The only thing that did happen was that when I put the new drive in, I put it in as a master and I put the original drive in as a slave in the hope that the newer drive might have been a little faster. I also copied the dynamic data from the old drive to the new drive and it worked perfectly in case anyone was wondering.
I know it's not going to affect things too much in real life but could 1k blocks instead of 4k blocks pose any sort of problem later on apart from slow fscks? Although I will try turning on the other swap instead and see how fast that goes...
#148861 - 16/03/2003 17:59 Re: Long fsck on one drive but not on the other [Re: Shonky]
Enabling only the other drives swapfile made absolutely no difference. Still 12 minutes 30 seconds.
