Page 1 of 3 1 2 3 >
#163227 - 28/05/2003 17:21 My new motherboard is dead?
So I recently received my Abit NF7-S motherboard, Athlon XP 1700 CPU, and 512MB PC2700 RAM, along with a CPU fan/heatsink, etc. Began the process of installing last night, and before installing my peripherals, the PC would POST, CPU temps were nominal, etc. Then I put in a few hard drives, my video capture card, etc. and it wouldn't POST. No video, no BIOS beeps, but the LEDs on the motherboard are lit, all the fans go on, etc. So I figure I might have too many things connected, so I unplug everything, and I get the same results. Tried again tonight with a brand new power supply/case (not that those were at fault, but I needed a new one anyway) and still no luck.
So what the hell happened? I was taking care to avoid static electricity, I didn't cross any power connectors on the motherboard... Is there anything else I cna do to diagnose the problem? Is it possible it's the CPU or RAM that's failed somehow? How can I tell exactly what's gone wrong? I don't have any other compatible RAM or CPU I can swap in, unfortunately, or I'd try those.
This kinda sucks. I was really looking forward to getting this system together, and now it's clear something's broken. And chances are it's my fault, I just don't know what I did. I've built a dozen computers in my lifetime and never had these kind of problems... Just the way my luck's been recently.
So... ideas?
#163228 - 28/05/2003 17:29 Re: My new motherboard is dead? [Re: tonyc]
Ezekiel
Loc: NH USA
Have you tried just the processor, no RAM, vid etc...? It should at least beep at you then. Do you have an old MOBO you can put your processor & RAM into to check those (sounds like you don't)?
Is there perhaps a loose case screw sitting where it shouldn't (give it the shake test)? Does the mobo/proc/RAM operate with the case mounting screws removed (perhaps a cold solder joing that flexed open)?
-Zeke
WWFSMD?
#163229 - 28/05/2003 17:41 Re: My new motherboard is dead? [Re: Ezekiel]
Daria
Actually I've had boards that wouldn't POST without RAM they liked.
#163230 - 28/05/2003 17:43 Re: My new motherboard is dead? [Re: tonyc]
robricc
Make sure the jumper for CMOS clear is set on "normal" (not clear).
Next thing I would do is check all the memory is seated properly. Then I would check that I didn't crack the Athlon's die when applying the heatsink.
#163231 - 28/05/2003 17:45 Re: My new motherboard is dead? [Re: Daria]
robricc
Another possibility is that the memory is ECC. Most "consumer" chipsets coming out now are not supporting such memory.
#163232 - 28/05/2003 18:09 Re: My new motherboard is dead? [Re: robricc]
Ezekiel
Loc: NH USA
It posted once for him, so I assume that's not the problem?
I agree about the re-seating tho.
-Zeke
WWFSMD?
#163233 - 28/05/2003 18:21 Re: My new motherboard is dead? [Re: Ezekiel]
[->Zeke]
Yeah, tried it, no beeps. (Speaker is connected properly.)
Nah, the only other motherboard I have is an Abit KT-7 which won't support the newer Athlon's. (Got a Duron 800 in it now.)
Nah, I transplanted everything to a new case and same results.
Didn't try that, but I will add it to my list of things I'll try before I send 'er back.
It posted about a dozen times, actually.
[->Rob]
First or second thing I checked. I did try clear the CMOS just to see if it was the issue, but the jumper is back where it's supposed to be.
Yeah, that's next, though I've been reluctant to pull the heatsink off because I'll have to reapply my thermal paste (and remove the old paste) to do so. I have never had problems with this though, and the CPU/Mobo *did* work for the first half hour of my journey. I doubt a CPU with a cracked die would operate for that long.
This is brand new Kingston PC2700 DDR. One thing I thought about was putting it into my "old" system (KT7-RAID.) Are newer PC2700 memories backwards-compatible to a system that normally runs on PC100 or PC133 RAM?
Sigh. I'm going to keep trying things here, I guess the next step is popping the CPU out and taking a look at it. I'm thinking it's the mobo, but I figured if I did something screwy to it, it'd at least beep at me or not power up at all...
Edited by yn0t_ (28/05/2003 18:22)
#163234 - 28/05/2003 19:38 Re: My new motherboard is dead? [Re: tonyc]
DDR RAM won't fit in a SDR socket. There are actually more pins on a DDR module.
When you disconnected everything from the motherboard, were they still connected to the PSU?
Also, might be a stupid question but the fuse hasn't gone in the plug has it?
- Trevor
#163235 - 28/05/2003 20:04 Re: My new motherboard is dead? [Re: tman]
genixia
If it has then I want to know where I can get those magic LEDs and fans that work without consuming any electric power!
#163236 - 28/05/2003 20:07 Re: My new motherboard is dead? [Re: genixia]
Doh! Didn't notice that bit in the original post!
More seriously though, is the 12V ATX auxillary plug necessary on your motherboard? I forgot to plug it in once and the board would act really strange and not power up properly but the fans would spin.
- Trevor
#163237 - 28/05/2003 20:34 Re: My new motherboard is dead? [Re: tonyc]
tracerbullet
Loc: Minnesota
Thoughts, take 'em or leave 'em:
It DOESN'T beep at you when you turn it on with a missing video card or RAM? Seems like it should. See what BIOS type is in it (Phoenix or Award probably) and their sites will list beep codes and their meanings. But you don't get anyhing, that makes no sense!
When you say it doesn't POST, does it at least beep once? As in, it works but it's just that the video has gone dead? Either way, might try a different video card, or a PCI one or something.
All BIOS options to "failsafe"?
Your chip may work int hat other board. It will physically fit - and even though it won't run full speed, the board that the Duron is in right now may (I'd say "should") at least take the info off the chip regarding the multiplier, etc. and make something of it. Perhaps run at 100 instead of 133, or something similar. That's been my experiences anyways - a new XP chip won't go full speed but will POST.
I've owned an Abit, and I returned it, it was so flaky when I was putting that particular machine together. Traded it for a Gigabyte which worked great, immediatley. Myself - I'd never buy another Abit. My point is - it really could be the board...
Edited by tracerbullet (28/05/2003 20:35)
#163238 - 29/05/2003 00:58 Re: My new motherboard is dead? [Re: tracerbullet]
[->Trevor]
You mean the little square one with the 4 pins? I don't think so. During the several times it did successfully POST and boot up, I didn't have it connected. In fact I didn't even know what it did until you just mentioned it and I looked it up. According to the manual, attaching it is "optional," which begs the question why anyone would attach something that's optional. I have never known of such a connector, and my old case doesn't even have a plug for it (though my new one does, strangely.)
I guess I'll try connecting it just for fun.
[->Greg]
As I said, no video, no beeps. Video card is just fine, using it right now with the old motherboard and Duron processor.
Right. That's what I'm sayin'.
Well, they're set to factory defaults, since I cleared the CMOS, but I have no way to view them, since there's no video, and I can't get into the BIOS screen.
Hm, okay, I may try the AthlonXP in my current board, then, just to see what's going on. For some reason I thought the newer generation Athlons wouldn't run at all on an older board.
Well, I've never had a problem with any of the ABit's I owned (TX-5, BP-6, KT7-RAID) so this is new to me. I guess I just want to know that it's the board before I ship it out for a return.
Anyway thanks for the help, guys, I'll probably try to swap chips/etc. tonight when I get home to see what's going on. Let's hope I don't damage my current setup in the process. I seem to have the "reverse Midas touch" lately.
#163239 - 29/05/2003 01:27 Re: My new motherboard is dead? [Re: tonyc]
Try the board out of the case, I thought i'd fried my new board but found it was a grounding issue in the case.
#163240 - 29/05/2003 03:12 Re: My new motherboard is dead? [Re: tonyc]
I once had it happen to me that the reset switch on the case was stuck. So the motherboard worked fine OUT of the case, but every time I put it back into the case the thing wouldn't post. (because each time I would connect those tiny led/speaker/reset switch connectors again without knowing that that was the problem).
The moment I pulled those wires while the PC was on the thing posted no problem!
So I agree with Andy : assemble the PC OUTSIDE the case and connect nothing to the motherboard but keyboard, mouse, videocard and power.
If it doesn't work then you can pretty safely say that your motherboard is kaput.
#163241 - 29/05/2003 07:06 Re: My new motherboard is dead? [Re: tonyc]
If the board was powered up without the 12V aux connector plugged in, then it is very possible that too much current got sucked through some poor unsuspecting component (or hopefully, a fuse) on the motherboard as a result of electricity travelling the "hard way" to the CPU or whatever.
#163242 - 29/05/2003 07:12 Re: My new motherboard is dead? [Re: tonyc]
Chimaera
Loc: DFW Area, Texas, US
Will the Duron run on the new board? saves risking the Athlon on the old board.
#163243 - 29/05/2003 07:29 Re: My new motherboard is dead? [Re: Chimaera]
[->mlord]
Really? I've *never* had a power supply with a 12V Aux connector until now, and never even knew of its existence on any motherboards. I definitely missed a memo somewhere along the line.
Mind explaining what you mean by electricity travelling the "hard way" to the CPU? I thought that all the power that motherboards needed came from the standard rectangular connectors that come from the power supply... The little square 4-pin jobbie is completely new to me.
[->Chimaera]
I don't think so. I think the board supports only 166 FSB. I will check, though.
#163244 - 29/05/2003 08:07 Re: My new motherboard is dead? [Re: tonyc]
robricc
It's extremely common on Pentium 4 motherboards. Only ultra-modern Athlon boards are starting to come with it now.
Attached is the connector circled if anyone doesn't know what we're talking about.
#163245 - 29/05/2003 08:57 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
heres a thought, is your motherboard using an Nvidia chipset? If so... Did you over clock the front side bus speeds? The reason I ask is I recently bought the latest and greatest shuttle PC, all nvidia, I overclocked (accidentally) it began acting very strange, displaying odd characters and eventually no post.... ended up taking it back and getting charged 20 bucks for something I would later figure out via web search. Hold the insert key down while booting (I think)... it's the only thing that will get your motherboard back to the correct FSB setting. That or slap an older slower processor in it under 1200... Resetting the CMOS does nothing... Apparently this problem isn't just experienced with shuttles... but anything using the nvidia nforce chipsets... and possibly other nvidia chipsets
That is if this is your problem....
Just did a bit of checking.. you do have n-force on that board.. try holding the insert key down... then set your fsb at a lower setting... I ended up having to use a lower fsb then what the system was supposed to be able to handle to just provide stability... I was kind of pissed, but it's still pretty damn fast so I don't mind so much
Brett 60Gb MK2a with Led's
#163246 - 29/05/2003 09:34 Re: My new motherboard is dead? [Re: lopan]
I did not try *any* overclocking of any kind during this. My plan of attack was to get everything running at stock speeds first, THEN apply some O/C. So this isn't what's happening.
#163247 - 29/05/2003 09:35 Re: My new motherboard is dead? [Re: robricc]
Yeah, it's just really fishy that the user manual would say that the connector is "optional." Like "Optional If You Want Your Motherboard To Work?" Or "We Just Wanted to Put it There so You'd Have a Place to Put the Funny-Looking 4-Pin Connector" kind of optional? Very odd. I will try attaching it tonight to see if it has any effect.
And, again, the thing was working properly without the auxilliary connector. Why the hell did they need to introduce yet another 12V power connector???
Edited by yn0t_ (29/05/2003 09:36)
#163248 - 29/05/2003 09:47 Re: My new motherboard is dead? [Re: tonyc]
genixia
Dunno.....maybe because modern P4s use more power than the old ATX connector can safely provide?
#163249 - 29/05/2003 09:57 Re: My new motherboard is dead? [Re: genixia]
Some of the people here (myself included) reckon that PC motherboards should supply 48v to all of their components, and let individual subsystems switch it down from there as necessary.
#163250 - 29/05/2003 10:10 Re: My new motherboard is dead? [Re: genixia]
Ah, so the auxiliary connector jobbie is dedicated to powering the CPU?
#163251 - 29/05/2003 10:54 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
I wasn't really overclocking either when the first set of strange behavior happened, so I went into the bios and began playing with things, when I beefed the front side bus all the way up is when I got the same behavior you described. I actually originally had the fsb set for what the machine was supposed to be able to handle.... Your boards behavior just seems similar to what was happening with mine. Everything lights up but nothing happens... Heres an article explaining the issues, it does mention abit boards with the nforce chipset...
Edited by lopan (29/05/2003 12:02)
#163252 - 29/05/2003 11:05 Re: My new motherboard is dead? [Re: tonyc]
http://www.theregister.co.uk/content/3/11706.html
Note the date on the article. I knew about these, and I haven't purchased a computer since then, much less built one. You need to find the person that's supposed to keep you up to date on such things and give them a good talking to.
#163253 - 29/05/2003 11:41 Re: My new motherboard is dead? [Re: tonyc]
Attack
Loc: Florida
The new connector is for 5v line for the CPU's I believe.
I know one reason this connector was added: The power connector/ power supply cable on the older Athlon Dual motherboards based on the MP chipset would melt if you used CPU's that draw alot of power.
Also have you tried your old Duron CPU in this motherboard. If that works then you know it's the CPU it fails and you put it back in the old motherboard and it works. Then it's the new motherboard.
If the CPU is bad most Athlon motherboards will not beep the PC speaker. Yes this is LAME!
Chad
#163254 - 29/05/2003 11:42 Re: My new motherboard is dead? [Re: Roger]
genixia
Hmm...There is a good question.
48V would certainly have some advantages. But you might have some issues with regards to the -12V that is still usually provided for legacy RS232 use. At that point you have 60V (nominally) of potential difference between 2 points on the motherboard. Given that most PSUs today are switching supplies and that unloaded voltages usually exceed specified loaded voltages, it is easy to see that we would exceed the 60V 'Low Voltage' classification, hence requiring greater safety precautions. Given the fact that such a large percentage of PC users open their PCs and upgrade stuff themselves (many of whom are, quite frankly, clueless about electricity) I'm not sure that this is so desirable.
On the other hand, ATX is getting a bit long in the tooth. There's too much provision for legacy whilst too many upcoming technologies are battling for space. I think that it's nearly time for a new form factor to become prominent. But I don't think that any of the existing alternatives have got it right yet. Perhaps a new form factor specification would eliminate RS232 (in favor of USB dongles when necessary) and include 48V supplies.
But I'd quite happily see 24V used as a compromise.
#163255 - 29/05/2003 11:45 Re: My new motherboard is dead? [Re: Attack]
12V for the CPU.
#163256 - 29/05/2003 11:47 Re: My new motherboard is dead? [Re: genixia]
eliminate RS232
But that would preclude having a serial console, at least without additional hardware.
#163257 - 29/05/2003 12:06 Re: My new motherboard is dead? [Re: tonyc]
So that when I built my new system, I'd have yet another wire coming from the PS that I would have to tie back somehow. It's quite annoying.
#163258 - 29/05/2003 12:26 Re: My new motherboard is dead? [Re: lopan]
[->Brett]
Hmm. Thanks for the link. That's definitely me, though this is "Revision 2.0" of the Abit NF7-S, and I think a lot of the BIOS-related problems were fixed. That doesn't mean I'm out of the woods, though. I will give the "hold insert key" thing a shot, among other tricks I have planned this evening.
[->Bitt]
I guess I saw this coming but thought it would just affect P4 users. I guess that's what ABit means when they say it's "optional." They're probably just providing it so that people with those connectors don't feel like they forgot to connect something. <those famous last words>But I guess if it's optional, it can't hurt to have extra juice available... </those famous last words>
[->All]
Boy this is fun stuff!
#163259 - 29/05/2003 12:35 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
One way to know if you have one of the boards that doesn't suffer, from the article I'm gathering is if there is a jumper to reset the FSB, also, the insert key trick might not work on all the boards with this issue... That might just be a shuttle thing, if you have an old athlon processor with 100mhz fsb, you might have to use that to force the board back into 100mhz mode... And from what I'm gathering it might be a pain in the ass to get it back to POSTing properly if in fact this turns out to be your issue.
BTW, I bought my shuttle less then 3 weeks ago, the guy had literly pulled it off the truck, and I had this crap happening
Edited by lopan (29/05/2003 12:39)
#163260 - 29/05/2003 12:44 Re: My new motherboard is dead? [Re: lopan]
Hmm. Sounds like I'll try my Duron in there and see if he's happy. The fact that the article mentions that is very reassuring, I thought that 100 FSB processors wouldn't work in newer mobos. I'm gonna give this a shot tonight if the other strategies don't achieve the desired effect.
#163261 - 29/05/2003 12:51 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
I didn't think so either til all that happened with my shuttle, but really if you have the option in the bios to set it to 100 FSB why wouldn't it? It's not like the pin config is changing or it's a completely new architecture. I'm just agitated I didn't find that article before I took the machine back... would've saved me 25 bucks
#163262 - 29/05/2003 13:02 Re: My new motherboard is dead? [Re: wfaulk]
genixia
eliminate RS232
Maybe. Alternatively, consider changing to TTL level 3-wire serial over an RJ connector, and fix the bios issue at the same time. Nearly (if not) all modern RS232 transceivers and UARTs are capable of supporting this. That might introduce less robustness in the signalling (and hence shorter maximum cable lengths) but for 99+% of applications that probably isn't ever going to be an issue. For local admin of headless servers then a short cable is fine, and for remote admin, current server densities virtually dictate a terminal server per rack anyway.
#163263 - 29/05/2003 17:56 Re: My new motherboard is dead? [Re: genixia]
Well, I have progress to report... Tried the "easy" tests (hold down insert, mobo outside case, etc) with no joy. Swapped in the Duron 800 from my other box and it POSTed, I had display, a single beep, etc. So it would appear my Athlon XP 1700 is dead. Which I don't get, because CPU temps never went high, I never changed the voltage, etc. No cracked die or sign of any "damage" to the CPU... But given the fact that the mobo/RAM are okay for at least POSTing, the CPU would seem to be the culprit. Which really bites.
So I guess I've got to send it back to NewEgg, and pay their damn 15% restocking fee, not to mention they subtract for "current market value" of the CPU. I'm now debating whether to return it to them for a replacement or just return it for a refund and look elsewhere for another Athlon CPU.
I just wish I had some idea of what went wrong with this thing. When I looked in the "health monitor" the CPU temperature never went over 52 or 53 degrees. Don't they do burn-in tests of these things before they ship?
Oh well. Time to put everything back together and pack up the frickin' CPU. Thanks for all the tips, guys. Glad I didn't send my motherboard back!
#163264 - 29/05/2003 18:26 Re: My new motherboard is dead? [Re: tonyc]
Weird. I've had a CPU just die on me as well though.
I was building 4 identical systems and the parts were all bought from the same supplier and at the same time. One of them just wouldn't stay up for more than an hour or two before it would reboot by itself. In the end by swapping components between the machines I found out that the CPU was just bad. Sent it back to be replaced and it's been working fine ever since.
- Trevor
#163265 - 29/05/2003 19:00 Re: My new motherboard is dead? [Re: tman]
Yeah. I'll see how it goes. Sucks that NewEgg is in California so I won't be seeing a replacement for 2 weeks, if I'm lucky.
#163266 - 29/05/2003 19:41 Re: My new motherboard is dead? [Re: tonyc]
Well, if you were an asshole, you could purchase one at a local retailer and then return the defective one to them.
#163267 - 29/05/2003 19:50 Re: My new motherboard is dead? [Re: wfaulk]
Well, if you were an [censored], you could purchase one at a local retailer and then return the defective one to them.
They charge a 15% restocking fee to cover such situations. Besides, I'm sure they'd notice the serial# or manufacture date were different, or something like that. And 1700XP+'s are becoming scarce, as AMD pushes newer, faster chips into the market.
Oh, and I'm not an [censored]. At least not in that particular way.
#163268 - 30/05/2003 01:32 Re: My new motherboard is dead? [Re: tonyc]
Well, whenever I wanted to check if a CPU was really dead I'd put my finger on it and then turned on the computer. If I could feel the CPU heating up, I was pretty sure it wasn't dead and something else was causing the problem. If I couldn't feel it heating up, I knew it was dead.
This method has always worked for me in the past.
Disclaimer : I've ALWAYS used this method on Intel CPU's, never on AMD's. The result should be the same, except that AMD's get a LOT hotter A LOT quicker.
If you try this method, be careful not to burn yourself.
#163269 - 30/05/2003 02:44 Re: My new motherboard is dead? [Re: BartDG]
I can attest to that, I nearly had an athlon shaped burn on the palm of my hand a couple of weeks ago as a result of a failed CPU fan.
#163270 - 30/05/2003 03:40 Re: My new motherboard is dead? [Re: BartDG]
Not sure how good of an idea it is to do this to Athlon's! Some of the older ones had no thermal control hardware built in.
The Athlon would actually start to smoke after a few seconds without a heatsink. And once you've let the magic smoke out then won't work anymore.
- Trevor
#163271 - 30/05/2003 03:50 Re: My new motherboard is dead? [Re: tman]
True. I would suggest not running the CPU longer than 1-2 seconds without a heasink. (then just pull the power-plug)
That should be more than suffient to diagnose whether it heats up or not.
I do agree however that this method is better suited for Intel CPU's than AMD.
#163272 - 30/05/2003 07:23 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
Did you try putting it back in after you tried the old duron? It might be fine.... If the fsb thing was the issue. Mine was...
#163273 - 30/05/2003 07:29 Re: My new motherboard is dead? [Re: BartDG]
lopan
Loc: Manassas VA
I wouldn't even suggest that... I burned an older athlon (can't remember the speed, but it was 2 years ago) before the mother board had a chance to beep. Even when testing keep the heatsink on even if you have to hold it there by hand.
#163274 - 30/05/2003 07:52 Re: My new motherboard is dead? [Re: lopan]
Yeah, tried that, no dice. Right now I'm running with my Duron in the new motherboard, and I'm sending the AthlonXP back to Newegg. I might swap the Athlon in one more time before I send 'er out just in case, but it definitely seems to be the CPU that's to blame.
#163275 - 30/05/2003 08:27 Re: My new motherboard is dead? [Re: lopan]
Oh, another goofy thing that's happening with my system as presently constituted... I've got a CD-RW drive and a CD-ROM drive on my secondary IDE channel, but when they're both connected, the CD-RW drive doesn't work, regardless of what Master/Slave settings are used. I've tried:
CD-RW Master, CD-ROM Slave
CD-ROM Master, CD-RW Slave
Both drives Cable Select (with both combinations of Master/Slave via cable select)
The symptoms are weird. As the BIOS bootup messages scroll by with the listing of the IDE drives, the CD-RW drive shows up with a goofy garbled text string (with lots of high ASCII characters and such) as if some kind of corruption is going on. Without the CD-ROM drive, it shows up properly and works fine.
So, my question is, has anyone ever seen a situation where two drives on an IDE chain don't play nicelky together? It's always the CD-RW drive that gets messed up, the CD-ROM drive works fine in either configuration, but it seems to be screwing up the CD-RW.
I don't think this is related to my new motherboard, since I never tried these two drives together on my old one.. I'm operating under the assumption this is due to one of the drives being flaky, not something related to the motherboard. But I've never seen anything like this, so I figured I'd ask.
#163276 - 30/05/2003 08:47 Re: My new motherboard is dead? [Re: tonyc]
lopan
Loc: Manassas VA
Sorry to hear about the processor, that sucks... as far as the IDE thing goes, are you using one of those newer "aerodynamic" cables? You know the ones that are round to create better air circulation in your case like this? I've had nothing but problems with cables like this, dunno it may just be me. But I always end up using regular flat cables to avoid issues. But yes I've seen flakiness like that..
#163277 - 30/05/2003 09:12 Re: My new motherboard is dead? [Re: lopan]
Nah, standard flat ATA100 cable. Very weird. I love this motherboard, but kinda miss having 4 IDE chains to play with.
#163278 - 30/05/2003 09:17 Re: My new motherboard is dead? [Re: lopan]
That's a good point. I had problems with my hard disks in my new system when I put it together, and switching out the fancy round silver cables for the boring grey things that came with the mobo worked like a charm.
Although, I seem to remember having this problem before as well, and it wasn't related to the cables or anything (I think). My solution may have been to simply stop using one of the drives, althought that's not a very graceful one.
I don't remember seeing a situation where they did I hate the whole system.
#163279 - 30/05/2003 09:21 Re: My new motherboard is dead? [Re: Dignan]
Yeah. I *really* wanted these two to work in this system, since the CD-ROM drive is 52X and my CD-RW is only 40X. The CD-ROM has much faster audio extraction as well. This is what I get for taking parts from three different computers and thinking I will get a working system in the end.
#163280 - 30/05/2003 09:28 Re: My new motherboard is dead? [Re: tonyc]
Last winter, I attempted to have 3 drives in my PC: a DVDROM, CD-RW, and DVD±RW. The CD-RW was on a SCSI drive so I knew that would work. Unfortunately, the Toshiba DVDROM didn't want to play nice with the newer, bigger, better Sony DRU500, so it pouted and wouldn't play at all. I figured hey, this drive could easily replace the other two (which were both about 3 years old). Hell, every spec was superior to the old drives in every category.
I think the DVD burner is the only one hooked up now
#163281 - 30/05/2003 10:23 Re: My new motherboard is dead? [Re: tonyc]
davekirk
Loc: Las Vegas
Obvious but necessary question: Have you tried using a different cable? How long is the IDE cable you're trying to use? I have had devices that were extra-sensitive to this and work fine with shorter runs.
Also, have you looked for firmware updates for the drives in question?
#163282 - 30/05/2003 11:02 Re: My new motherboard is dead? [Re: davekirk]
The cable is pretty standard length. The two drives are at the top of my mid-tower case and the cable just barely reaches. All the cables I have are the same length and, yes, I tried swapping in another cable, with the same results. In fact, the exact same sequence of goofy high-ASCII characters when it reports the drive's name and model number.
Yeah, but to apply the firmware, I need to be able to boot to DOS, and, interestingly enough, neither of my floppy drives are working. Can you tell it hasn't been my finest hour in my PC building career? I planned on making a bootable DOS CD-RW, but didn't get to it last night amongst all the other problems.
#163283 - 30/05/2003 12:20 Re: My new motherboard is dead? [Re: tonyc]
Sounds like there's some bad karma there...When that sort of thing happens to me, I usually just return the board, memory, and CPU...It's not worth the trouble of wrestling with it for the remainder of its life. In my experience, even if you get it working...a flakey board never works quite right.
#163284 - 30/05/2003 12:27 Re: My new motherboard is dead? [Re: JBjorgen]
But it sounds like he doesn't know exactly what it is. Though I suppose the only clean solution would be to return it all, like you said.
My dad's work machine had bizzare issues. It would load certain things, like network drives, veeeery slowly. Eventually the Dell representative replaced the memory, ghosted to a new hard drive, upgraded to Win2K (from 98SE), and finally replaced the whole mobo. When those problems still wouldn't go away, they said screw it and put it in a low traffic area. Never did solve it. I guess some machines are just duds
#163285 - 30/05/2003 19:03 Re: My new motherboard is dead? [Re: tonyc]
genixia
For kicks try an older 40 wire cable. I had a bizarre problem where I couldn't get a bios to recognise a DVD drive using an 80 wire cable but worked fine with the older cable.
#163286 - 30/05/2003 19:35 Re: My new motherboard is dead? [Re: tonyc]
Laura
Loc: Greenhills, Ohio
Did you try one drive on the primary as a slave and the other on the secondary? Might work that way even if it is a longshot.
Laura
MKI #017/90
whatever
#163287 - 30/05/2003 22:39 Re: My new motherboard is dead? [Re: Laura]
Not just a long shot, but a long reach. The two CD drives are high on the case, the HD's are low. Splitting a single chain between the two just won't reach with the cables I have.
Might try to swap in a 40 connector cable soon "just for kicks."
#163288 - 31/05/2003 05:56 Re: My new motherboard is dead? [Re: tonyc]
I had a similar problem recently, with all jumpers/combinations failing equally. So I tossed the ATA100 cable and replaced it with a new one from my bin'o'cables. Works fine now.
Page 1 of 3 1 2 3 >
