#17648 - 13/09/2000 21:40 Revert to factory settings
craigelliott
Loc: Boothwyn, PA
I shut off my car (Audi A4) like any other day when I arrived at work. When I got back in my car after work, I noticed that the same song that was playing when I left the car was no longer playing when I got back in the car. Hmmm.
I noticed that the first song in the playlist (entire collection) was playing [1/xxxx] and they were playing in the order that emplode lists them. Shuffle mode had been turned OFF. Hmmm.
The sound quality was also off. I navigated to the equalizer and the first preset (FLAT) was chosen, instead of the third present (CUSTOM) that I spent hours tweaking. Luckily the settings were still saved, empeg just decided to use it. Hmmm.
It seems that the empeg may have reverted to the default factory settings. Anyone else experience these same symptoms? This also brings to mind another concern... it would be nice if there was a way "export" the EQ settings from emplode. Let's take it a step further... the ability to copy/delete/edit EQ settings in emplode.
Craig Elliott
Craig Elliott
elliott@g-cnet.com
#17649 - 14/09/2000 13:40 Re: Revert to factory settings [Re: craigelliott]
You definitely have my vote on this one. And I can just about promise you that Tony feels the same way after his hard drive crash!
#17650 - 14/09/2000 14:14 Re: Revert to factory settings [Re: tanstaafl.]
Actually, I'd been fiddling with the EQs just a few days before (in conjunction with my loudness experiments) and I wasn't completely satisfied with the settings on the day the drive died. So it wasn't a huge loss- I was going to be twiddling EQs in the near future anyway, the crash just forced me to knuckle down and do it. I'm actually happier with the sound now than I was before the crash. Go figure.
#17651 - 14/09/2000 14:32 Re: Revert to factory settings [Re: tfabris]
I'd been fiddling with the EQs just a few days before... the drive died.
Aha! There's your smoking gun! Fiddling with the EQs kills your hard drive. Better just leave everything at the flat settings to play it safe.
#17652 - 15/09/2000 16:12 Re: Revert to factory settings [Re: tanstaafl.]
If you had a VERY big sub I guess this could be possible
#17653 - 17/01/2002 02:36 Re: Revert to factory settings [Re: rob]
meast
So... erm... back to the matter at hand. Is total loss of settings (Volume to -INFINITY, play counts reset to 0, EQ to FLAT, Dimmer and Loudness hosed, etc.) on the internal bug list? This has happened to me twice now after removing the player from the dash, leaving it for a while, returning to my car, putting it back in the dash and starting the engine.
MEast 40GB MK2a in '04 BMW 330CiC with BSW 300w Amp & 10" Custom Sub
#17654 - 17/01/2002 12:38 Re: Revert to factory settings [Re: meast]
As I reported in the other thread, this "loss of flash" has happened to me and it was discussed on the internal alpha mailing list. So the empeg team knows about it.
Mark Lord mentioned that he thought he saw something in the default factory kernel that might have been related, but did not know if this was the cause. If it was, I do not know whether it has been corrected in the factory kernel yet. Mark's Hijack kernel supposedly has this thing corrected (whatever it was) so it's possible that using Mark's recent kernels may prevent the problem. I know I haven't had it happen since I've been using the corrected versions of Mark's kernels. But it was very intermittent to begin with so that doesn't mean much.
#17655 - 17/01/2002 16:30 Re: Revert to factory settings [Re: tfabris]
beaker
Loc: England
There was a period recently where this was happening to me quite frequently. It seems to have been behaving itself lately though. Actually, I think it's been since Mark discovered the suspected problem code in the kernel.
#17656 - 28/01/2002 15:36 Re: Revert to factory settings [Re: craigelliott]
danthep
Loc: new zealand
Yeah has happened to my mark1 many times over the years, very annoying.
Often combined with rebooting the empeg just as it is booting
