#178650 - 10/09/2003 09:35 Dying IDE Cable
Dist
How do I get a new one? My player died on the way to work. Is a e-mail to carsupport@xs4all.ln still the only option? (I've heard about long delays)
Thanks,
-Dave
#178651 - 10/09/2003 09:37 Re: Dying IDE Cable [Re: Dist]
No, the other option is to fix it yourself (assuming it's really the cable that's the problem). It's not difficult.
#178652 - 10/09/2003 09:42 Re: Dying IDE Cable [Re: Dist]
mtempsch
One could buy the connectors and flat wire as parts and build a new cable oneself.
You'd have to be very careful to get everything straight and properly pressed. As I have access to a proper crimper at work, I made a new wire for my MkI as I upgraded to two drives (the MkI uses 2 wires, each with a connector at each end, as it has 2 IDE headers on the mainboard) about 2.5 years ago.
It is certainly doable, but I wouldn't try it without the proper crimping tool...
Edit: unless, as Tony points out, it's just a fixable bad crimp on the original wire. I've fixed one of those in a small bench vise.
#178653 - 10/09/2003 11:36 Re: Dying IDE Cable [Re: tfabris]
Dist
I saw that FAQ entry before I posted, I just wanted to see if there was a way to get the cables if it didn't fix the problem.
I disassembled the player this morning and the cable was starting to seperate. I was able to get it back together and it seems like the Empeg is working again.
Thanks all,
-Dave
#178654 - 14/09/2003 18:56 Re: Dying IDE Cable [Re: Dist]
StoreCareMgt
Loc: Encinitas CA, USA
If you have the same problem again or wish to replace the cable, let me know.... see my other post for more info.
Jeremy Briggs www.carplayer.com
