#186556 - 24/10/2003 06:06 SUBWOOFER CROSSOVER
NT2OOO
Loc: ITALY
hello,
is it possible to have an menu to select frequency cut to use rear output with a sub without an external crossover?
SUBOUT: 50/80/120 or 50 to 150 Hz cut; like this:
|FRONT 2/3WAY| ------(front full range)--<-- |empeg| -->--(Rear XX Hz)---- |SUBWOOFER|
thanks for any reply
Alberto
Rio Green 60Gb
#186557 - 24/10/2003 10:23 Re: SUBWOOFER CROSSOVER [Re: NT2OOO]
No. Do not attempt to use the equalizer as a crossover. It doesn't work that way because you cannot adjust the Q and the deflection correctly to do the same thing that a crossover does.
Instead, use an amplifier that has a proper crossover built-in. Or, if you don't have a crossover on the amp, use F-mods.
#186558 - 24/10/2003 12:32 Re: SUBWOOFER CROSSOVER [Re: tfabris]
NT2OOO
Loc: ITALY
no with equallizer but with a new menu only for SW out selectable
Rio Green 60Gb
#186559 - 24/10/2003 12:34 Re: SUBWOOFER CROSSOVER [Re: NT2OOO]
NT2OOO
Loc: ITALY
this is a work for mark lord ) for a new feature for his hijack
Rio Green 60Gb
#186560 - 24/10/2003 12:36 Re: SUBWOOFER CROSSOVER [Re: NT2OOO]
No, there is no option for that on the empeg. It has four full-bandwidth channels with no crossovers.
I seem to recall that Stu of Eutronix was work on an add-on module for a separate subwoofer out, I don't know if it's something you can buy right now though.
If you are looking for an additional subwoofer output in addition to your existing four channels, the click here.
