#186826 - 26/10/2003 05:08
jEmplode 47
Loc: Richmond, VA
new installers, source, docs, jars, etc ... once I'm comfortable that the big problems are fixed, I'll move this over to jempeg.org. jEmplode autoupdate is turned off right now.
http://www.inzyme.com/rio/empeg
FIXED the ability to interact with the interface while syncing is dope, but takes a lot of getting used to. theres no indication on the main screen when i hit sync that anythings happening. can the transfer bar share the bottom half of the playlists tab? the details can stay where they are.
FIXED whenever i sync with emplode, when i go back to jemplode, it gives me a "Playlists referred to a missing tune or playlist with ID 272".
FIXED some of my files are not syncing thru. it gives a UTF16-LE error for the reason.
FIXED jemplode allows you to exit while a sync is happening. really bad, since the bar is invisible to an unknowing user. did that accidentally.
FIXED WMA files arent supported.
FIXED Hijack autoupdate = broken
FIXED starting jemplode right pane is on nothing. if you drag files to the pane, it goes to the all soup without getting into any playlist. suggest to default starting the right pane in the "Playlists" folder.
FIXED you try to add some files (about 60 albums), not sync and revert changes, then readd the files, and the transfer queue goes crazy, with a lot of duplicates and nullpointerexception. my guess is that the revert changes function doesnt clear the queue correctly. didnt even want to see what happens if i hit sync.
FIXED i was able to crash the v2final player by doing the following. i tried to upload the 60 albums again, then before syncing, deleted everything with "remove completely". it left me with a lot of "Updating Playlists" in the transfer details, so i synced, then without restarting jemplode, i readded the albums, synced again. can recreate the crash doing the same steps.
ms
#186827 - 26/10/2003 05:09
Re: jEmplode 47
[Re: mschrag]
Loc: Richmond, VA
Note that if you want to just download jars, you need to replace graphics.jar and jemplode.jar (graphics.jar contains the logoedit, animedit, and screen grab plugins).
#186828 - 26/10/2003 05:18
OS X
[Re: mschrag]
Loc: Richmond, VA
By the way -- the OS X installer appears to set the JVMVersion to 1.3.1 instead of 1.4.1 ... if you want the beginnings of the newer look and feel on OS X (still looks a little funky -- I haven't spent any time cleaning up the layout), you can go into your Applications/jEmplode/jEmplode.app/Contents and edit Info.plist ... Look for the JVMVersion tag and change the value to 1.4.1. You'll get the brushed metal look and the Panther UI (probably have to have Panther to get that last part). I'll figure out why it's not defaulting to 1.4.1 for the next build.
ms
#186829 - 26/10/2003 09:50
Re: jEmplode 47
[Re: mschrag]
Cool. Jemplode no longer gives me any errors on the Jupiter. Time to mess with it more.
You think I should risk a synch or two with the Jupiter?
#186830 - 26/10/2003 09:57
Re: jEmplode 47
[Re: mschrag]
Since rebuilding my XP machine, I havn't gotten to reinstall Jemplode. Am I still going to need the "XP fix" so I don't get a blue screen? EDIT: IIRC, my issue was due to my ATi graphics card, not XP.
Wish List Item: Installing 3rd party aps would be like installing a Palm OS ap. Just click on the install.exe for it, and you are told "program will be installed next time you run Jemplode."
But I love what you have here. Builtin logo editor, animation editor, auto updates, etc etc. Awesome.
Edited by SE_Sport_Driver (26/10/2003 10:05)
#186831 - 26/10/2003 10:08
Re: jEmplode 47
[Re: SE_Sport_Driver]
Loc: Richmond, VA
I run XP .. Not aware of anything special you have to do to make it work (it "just works" for me).
The 3rd party apps thing was a request a while ago ... It's sort of a big addition, so I just haven't gotten around to it yet. Now that I'm getting back in the swing of things, I'll look into that again.
ms
#186832 - 26/10/2003 10:08
Re: jEmplode 47
[Re: mschrag]
Ah, I understand what you mean by drag and drop now
You mean from the OS to Jemplode...
Is there any chance we'll be able to drag tracks from the "All Tracks" right hand pane to a playlist to add them to a playlist?
At the moment you have to copy them and when you right click on the playlist to select paste, it gets the fcus and you lose your place in the 'All Tracks' pane.
What I'm doing BTW, is browsing all my files and thinking "yeah, that one. And that one. Nah, nah, nah, yep, nah. yep etc etc etc"
Running twin 30's
#186833 - 26/10/2003 10:09
Re: jEmplode 47
Loc: Richmond, VA
I'm not so bold as to promise that you won't have problems, but I personally /think/ it will work. I can't imagine why it would cause problems. At least now the sync queue is visible, so you can see what it's going to do to your poor device. However, if you set your house on fire running it, I'm not claiming any responsibility
ms
#186834 - 26/10/2003 10:11
Re: jEmplode 47
[Re: LittleBlueThing]
Loc: Richmond, VA
I'm not sure why I've never bothered to write this ... Laziness mostly. I've been meaning to for a long time. I'll look into it.
#186835 - 26/10/2003 10:17
Re: jEmplode 47
I don't get the error either. Unless I am missing where to turn it on jemplode doesn't have the soup views anymore so how would a sync work ?
#186836 - 26/10/2003 10:21
Re: jEmplode 47
[Re: msaeger]
Loc: Richmond, VA
jEmplode has soup views -- they're just not any added in by default ... You can just right-click=>Add Soup Playlist and select "only in jEmplode" (if you don't want to add them to the device).
ms
#186837 - 26/10/2003 10:25
Re: jEmplode 47
[Re: mschrag]
OK, I guess my problem WAS with my ATi card when I exited Jemplode. But maybe that was "fixed" somehow in a Windows update or Jemplode 45 vs. 44. Who knows, but it's working now!
#186838 - 26/10/2003 10:26
Re: jEmplode 47
[Re: mschrag]
I didn't know about the "only in jemplode" part I thought that only made them on the player oops.
#186839 - 26/10/2003 10:31
Re: jEmplode 47
Loc: Richmond, VA
More than likely it's because I'm including the latest version of Java in this installer, which probably fixed the problem.
#186840 - 26/10/2003 10:32
Re: jEmplode 47
[Re: msaeger]
It just sits at syncronizing and doesn't do anything for me.
#186841 - 26/10/2003 10:56
Re: jEmplode 47
[Re: mschrag]
Loc: Switzerland
Hello Mike,
Thanks a lot for the new version...I found a small bug with the umlauts....
bye
#186842 - 26/10/2003 11:20
Re: jEmplode 47
[Re: mschrag]
Okay, I take it back. I guess opening Jemplode, connecting to the player and closing Jemplode wasn't enough to induce the crash. I had to do a sync then I get the blue screen reboot when I close Jemplode.
Mike PM'd me to recommend adding "sun.java2d.noddraw=true" in my jemplode.lax file. Remembering now, this fixed it last time. Just an FYI for anyone else out there with XP and an ATi card.
#186843 - 26/10/2003 11:25
Re: jEmplode 47
[Re: crazymelki]
Loc: Richmond, VA
Can you explain more about the screenshot? What's it doing vs what is it supposed to do?
ms
#186844 - 26/10/2003 11:25
Re: jEmplode 47
Loc: Richmond, VA
Incidentally, I have XP + ATI Radeon 9700 Pro and run w/o problems, so it's not all ATI cards ... I would make sure you have the latest ATI drivers. Other than that, yeah, I guess disabling ddraw acceleration in the VM is the only route. Maybe lowing your hardware acceleration settings in the ddraw config might help too, but then you take a hit everywhere.
ms
#186845 - 26/10/2003 11:29
Re: jEmplode 47
[Re: msaeger]
Loc: Richmond, VA
#186846 - 26/10/2003 13:13
Re: jEmplode 47
[Re: mschrag]
Loc: Switzerland
If you look at the second line of the playlist the name of the artist ist Dani König, but JEmplode shows some strange characters...The same is on the third last line.
We are calling this "äöüéè" umlauts....And JEmplode does not showing up them correctly. The same is, if I download them form my Empeg back to my PC...The file names contains this wrong characters...
bye
#186847 - 26/10/2003 14:34
Re: jEmplode 47
[Re: mschrag]
Ta - fingers x'ed
I also sent a bug report that mentioned this to feedback@jempeg.org recently (I don't know if you get them - anyway ...  )
In it I also said:
I have noticed a problem on my system (WinXP JAVA_HOME=D:\apps\j2sdk1.4.0_01)
When I click a column to sort by it the column does sort but visually the up/down arrow stays on the first column I do this with and doesn't change.
Not critical but FYI...
Running twin 30's
#186848 - 26/10/2003 14:34
Re: jEmplode 47
[Re: crazymelki]
Even Dani is asking what his name is!
#186849 - 26/10/2003 14:51
Re: jEmplode 47
[Re: mschrag]
How do I get Jemplode to skip m3u imports? I hope I'm not just missing something really easy!
#186850 - 26/10/2003 15:12
Re: jEmplode 47
Loc: Richmond, VA
Hmm .. Right now you can't ... I can add an option though.
#186851 - 26/10/2003 15:14
Re: jEmplode 47
Loc: Richmond, VA
Whoops .. fixed in the next release
#186852 - 26/10/2003 15:39
Re: jEmplode 47
[Re: mschrag]
That'd be awesome. But I'm happy enough the way it is, so don't take it as anything but a "wish". I just have m3u's in all my album folders so draging a folder into Jemplode creates two references of everything.
#186853 - 26/10/2003 15:59
Re: jEmplode 47
Loc: Los Angeles, CA
is it possibe to even have two references contained in the same playlist? i thought jemplode would automatically see that theres one in there already, and call the next one a dupe.
#186854 - 26/10/2003 16:45
Re: jEmplode 47
[Re: image]
It creates a copy of that playlist in the playlist itself... Maybe I should do a screenshot, but if I had a playlist called "Album 1", if you looked at its contents, you'd see all the tracks belonging to that playlist as well as another copy of the same playlist.. It is smart enough to not import 2 copies of each song to the hard drive, but the extra playlist is still there.
#186855 - 26/10/2003 20:59
Re: jEmplode 47
[Re: mschrag]
Sorry too many things going on in this thread at once.
I tried to do a sync to my rio central. I just edited the info for a track and tried to sync. After I start the sync jemplode just stays at synchronizing and the progress bar doesn't move.
#186856 - 26/10/2003 22:56
Re: jEmplode 47
oic what you're saying. playlist in a playlist.
#186858 - 04/11/2003 14:38
Re: jEmplode 47 and columns order bug
[Re: mschrag]
Loc: Qc, Canada
Hi!
I just tried the new v47 and i really appreciate the "sync and forget" function. Really great to be able to continue to retag during sync'ing.
Now, to my bug: I added the track # column and placed it second, right after title column using move up/down and it worked. But when I entered the colums settings again, it reverted the columns to their default position, where ever I placed them before.
And just for curiosity, do you plan/work on the "build database in PC" feature? This would be a such good improvement over the original emplode!!
Patrick
#186859 - 04/11/2003 14:41
[Re: elperepat]
Loc: Richmond, VA
I'll look into that bug ...
As far as database rebuilding, it's on the list of things to work ... No real commitment of when I'll do it at this point, though, but it /is/ on the list.
ms
#186860 - 04/11/2003 15:07
Re: jEmplode 47 and "Set playlist order..." bug
[Re: mschrag]
Loc: Qc, Canada
Thanks for your quick answer
Here's an other one:
I just can't seem to be able to "Set playlist Order..." anymore. The form containing options never appears.
Thanks!
Patrick
#186861 - 04/11/2003 15:12
[Re: elperepat]
Loc: Richmond, VA
I don't think jEmplode ever had a dialog like Emplode does ... I think Set Playlist Order takes the current sort order of the playlist view and commits that as the natural order of the playlist. I don't use that option, so I'm not sure it is still working, but if you show the "Position" column, you should see the values change when you Set Playlist Order.
#186862 - 04/11/2003 19:03
[Re: mschrag]
oh, what i've noticed is that playlists arent being grouped together when there are also tracks in the root playlist (or any playlist for that matter). its just in alphabetical order. bug or feature? =) it probably did this before, just never combined nested playlists and tracks in a playlist til now.
#186864 - 05/11/2003 15:14
[Re: mschrag]
yeah, thats what i'm saying. dont have my empeg right now to see if thats the same behaviour on emplode. just bugged me a bit since its basically universal in operating systems to group folders and files seperately.
#186865 - 05/11/2003 17:54
[Re: image]
emplode does the same thing and it kills me!  But they are "playlists" not folders!
#186866 - 06/11/2003 03:24
better start naming all my playlists like _<playlist_name>_. but i dont want any passenger of mine to think i'm somewhat l33t with all the additional special characters.
#186867 - 06/11/2003 06:26
[Re: image]
I tried (Playlist Name) for all of mine in emplode but then emplode got "smart" and sorted alphabetically by first letter (skipping any symbols) rather than by first character.
I'm with you on this one, I'd like playlists to stay up top.
#186868 - 06/11/2003 06:59
emplode 2.0-final has a nifty menu option in the Tools menu that "does the right thing". Playlists are sorted at the top alphabetically, and tracks are sorted at the bottom by track number. It's recursive.
#186869 - 06/11/2003 09:58
[Re: Roger]
wow. tools -> ordering in emplode "fixed" the play order perfectly. it changes all playlists below it, and then starts working on the tracks. i'm not sure what it does to the tracks though, since i thought that the ordering is stored in the playlists. i dont suggest paul g do this on his root playlist as it will do whatever it does to every track contained on his empeg.
#186870 - 06/11/2003 11:22
[Re: Roger]
Roger, very nice! You guys are always sneaking stuff in there eh?
#186871 - 06/11/2003 14:12
[Re: image]
Loc: Lochcarron and Edinburgh
Really? Not in any locale I've ever used! Directories and files sort alphabetically in C and UK locales on the platforms I have ready access to (Linux, HP-UX, Solaris, AIX). I guess that if you really want to sort by type, there is a "type" tag provided that you could use after sorting on title.
I'd hate to see Mike break the current (working, intuitive) behaviour of sorting on the requested column - I have quite a few artist playlists that are sorted chronologically, but containing a mix of albums and loose tunes (the latter mainly from compilations or bonus tracks). It would be counterintuitive to add an implicit "sort-by-type" (and hard to undo if there were no way to disable it).
#186872 - 06/11/2003 20:45
[Re: tms13]
crap, you're right in unix-centric oses. i've just been spoiled by windows and aliasing ls to group in linux.
#186873 - 09/11/2003 09:21
Re: jEmplode 47
[Re: mschrag]
Okay keen as ever to get bleeding edge but i have tryed replacing the current jemplode jar with the jar on the site and whenever i try starting it it just spits the dummy and won't start.
Running panther on a 12inch g4 powerbook.
Aberdeen Scotland
#186874 - 09/11/2003 10:02
Re: jEmplode 47
[Re: thinfourth2]
Loc: Richmond, VA
if you run java -jar jemplode.jar from the commandline, do you get any output on the console?
#186875 - 09/11/2003 11:24
Re: jEmplode 47
[Re: thinfourth2]
10.3 on a 15inch and replacing the jar worked on mine.
#186876 - 09/11/2003 12:24
Re: jEmplode 47
[Re: mschrag]
i have no idea what you mean
but typed that into terminal
and i got this
[Paulallison:~] paulalli% java -jar jemplode.jar
HotSpot not at correct virtual address. Sharing disabled.
Exception in thread "main" java.util.zip.ZipException: No such file or directory
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:112)
at java.util.jar.JarFile.<init>(JarFile.java:117)
at java.util.jar.JarFile.<init>(JarFile.java:55)
Aberdeen Scotland
#186877 - 09/11/2003 12:51
Re: jEmplode 47
[Re: mschrag]
47 is just sooooo sluggish and slow for me... it's painful. I'm guessing my "ATi" fix is what did it..
#186878 - 09/11/2003 13:09
Re: jEmplode 47
[Re: Daria]
XP on dual-headed 19" - and it works for me too
(Damn I wish 2.6.0-test9/Xfree did dual-head )
Running twin 30's
#186879 - 09/11/2003 20:01
Re: jEmplode 47
[Re: thinfourth2]
Loc: Richmond, VA
can you make sure you're in the same directory as jemplode.jar and run that again? that HotSpot not at correct virtual address thing is pretty suspicious sounding ... never seen that before ...
#186881 - 10/11/2003 01:58
Re: jEmplode 47
[Re: mschrag]
Will do just need to use my new book
unix for OS X
needed an excuse anyway
Aberdeen Scotland
#186882 - 10/11/2003 03:06
Re: jEmplode 47
[Re: thinfourth2]
Loc: Phoenix, AZ
The hotspot thing is a bug in Panther.. see this.
#186883 - 11/11/2003 11:47
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
I'm having problems on both of my machines (XP and 2000)with the new jemplode (47) ... jemplode finds my empeg (ethernet) and connects successfully. It downloads the database and gets stuck on "Updating Interface". Does anyone have any ideas as to how to fix this?
Thanks,
RioCar 60gb
#186884 - 11/11/2003 12:19
Re: jEmplode 47
[Re: crazymelki]
You're running v3.00 alpha, right?
This is UTF-8 that's being displayed as iso8859-1.
When migrating to v3, your player database is being converted
from iso8859-1 to UTF-8. That alone could cause touble for
third party apps.
But things can even get more confusing. I don't think
the tag files that are used to reconstruct the player database
are converted themselves, leaving them iso8859-1 encoded.
But newly uploaded tag files may be UTF-8 encoded, so I'm
not sure how emplode and jemplode cope with this.
Pim
#186885 - 11/11/2003 12:26
Re: jEmplode 47
[Re: pim]
Loc: Switzerland
yeee I am using 3.00 alpha....
bye
#186886 - 14/11/2003 19:40
Re: jEmplode 47
[Re: crazymelki]
Loc: Meridian MS
Can somebody help?
I am getting an error at the end of installation V47, as soon as I click done it gives me this error.
Wjview.exe application error
The instructions at "ox77f52610" referenced memory at "oxo4993db0". The memory could not be "written".
Click on ok to terminate the program.
But version 45 works with no problems? Also I have tried v47 on my laptop and it works fine. Running XP on both.
Dalewoodian
#186887 - 15/11/2003 01:22
Re: jEmplode 47
[Re: dalewoodian]
Loc: Richmond, VA
wjview.exe is Microsoft's Java VM, I believe ... Make sure you have java installed from www.java.com and try again, maybe?
#186888 - 23/11/2003 15:09
Re: OS X
[Re: mschrag]
Loc: Utah, USA
Mike,
Do you have just the Mac OS X binary that you can post? The install.zip consistently crashes on my machine after the "Choose Alias Folder" screen.
I've got 10.3.1. Have you run the installer successfully on that version? If not, is there any sort of incompatibility between InstallAnywhere and this version or something?
-Aaron
#186889 - 26/11/2003 02:29
Re: OS X
[Re: adavidw]
Loc: Utah, USA
FYI, In trying to solve this problem, I tracked down my backup of 10.2.8. The installer actually works on that, so I think there must just be some InstallAnywhere problems with Panther, or else something's really screwed up on my system since the upgrade.
-Aaron
#186890 - 26/11/2003 09:16
Re: OS X
[Re: adavidw]
Loc: Richmond, VA
It installs on my Panther, so it's not Panther-specific ... When I do the next build I'll do a zip also.
#186891 - 04/12/2003 09:47
Re: jEmplode 47
[Re: mschrag]
Loc: Edinburgh, UK
I've found a small bug in jEmplode 47. When selecting new playlists or soups the status bar doesn't automatically update the total track count for the playlist. If you do a "select all" though, the status bar does update itself.
This may just be a problem using my Sun 1.4.2 JavaVM in Linux.
#186892 - 04/12/2003 10:24
Re: jEmplode 47
[Re: zexpe]
Loc: Richmond, VA
If you just click on anything on the right side, will it update, or do you have to do select all?
#186893 - 04/12/2003 16:04
Re: jEmplode 47
[Re: mschrag]
Loc: Atlanta, Georgia
I think I may have found a small issue.. (Didn't see it mentioned in any thread here..)
Fresh, FRESH install of 3.00a3. There was no CONFIG.INI file. (Causing Emplode 2.01 to crash.) Fill out 'Player Config' in 47. Sync. *STILL* no CONFIG.INI file. Even right after clicking the 'Save/Sync' button, when try to exit, get the message "The Database is not in sync.." message. Never would sync up new config.ini. So first issue - no new config.ini if missing. (Maybe a bug in actual player? But no, because..)
Loaded up 44, made CONFIG.INI perfectly fine. Re-run 47, loads config.ini fine. Still won't save anything.. :/
I like the sync and continue working function, however! Very smooth! It'd be nice to have a little textbox type window with a status bar, so you can see past activities.. Instead of having just a small line telling you..
Good job!
Me.
Mike 'Fox' Morrey
128BPM@124MPH. Love it!
2002 BRG Mini Cooper
#186894 - 04/12/2003 22:42
Re: jEmplode 47
[Re: foxtrot_xray]
Loc: Richmond, VA
So basically 47 neither adds nor updates config.ini?
#186895 - 05/12/2003 09:07
Re: jEmplode 47
[Re: mschrag]
Loc: Edinburgh, UK
Yeah, clicking on a track on the right-hand side so that something is selected will cause the status bar to update. Basically you just need to have something selected before jEmplode will tell you the total number of tracks in the list. Whereas jEmplode 44/45 would update the status with the total number of tracks in the list whenever you click on a list in the left-hand panel.
#186896 - 05/12/2003 10:00
Re: jEmplode 47
[Re: mschrag]
Loc: Edinburgh, UK
I can confirm that that jEmplode 47 isn't updating the config.ini file. It does read the file, but it doesn't update any changes after a sync.
#186897 - 05/12/2003 11:08
Re: jEmplode 47
[Re: zexpe]
What he said.
Of course, I'm testing on v3.00a3. Have not tested on v2.00..
Me.
Mike 'Fox' Morrey
#186898 - 18/12/2003 09:42
Re: jEmplode 47
[Re: sirmanson]
Loc: Tucson, AZ USA
Does anyone have any ideas as to what I should check to fix this issue?
RioCar 60gb
#186899 - 18/12/2003 10:36
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
If you run from the console (java -jar jemplode.jar) do any errors get printed out?
ms
#186900 - 19/12/2003 08:47
Re: jEmplode 47 *DELETED*
[Re: mschrag]
Loc: Tucson, AZ USA
Post deleted by sirmanson
RioCar 60gb
#186901 - 19/12/2003 09:16
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
So nothing prints out to the console? How about running it
java -Ddebuglevel=31 -jar jemplode.jar
and mail me the output -- mschrag@pobox.com
ms
#186902 - 19/12/2003 09:34
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
Here is the output :
Unable to open connection to device. caused by:
org.jempeg.music.protocol.ConnectionException: Unable to connect to device using Ethernet.
at org.jempeg.music.protocol.SocketConnection.open(SocketConnection.java:132)
at org.jempeg.empeg.protocol.EmpegProtocolClient.open(EmpegProtocolClient.java:351)
at org.jempeg.empeg.protocol.EmpegProtocolClient.open0(EmpegProtocolClient.java:943)
at org.jempeg.empeg.protocol.EmpegProtocolClient.isDeviceConnected(EmpegProtocolClient.java:173)
at org.jempeg.empeg.protocol.discovery.UnicastNetworkEmpegDiscoverer.discover(UnicastNetworkEmpegDiscoverer.java:53)
at org.jempeg.empeg.protocol.discovery.CompoundEmpegDiscoverer.discover(CompoundEmpegDiscoverer.java:66)
at org.jempeg.empeg.manager.EmpegDiscoveryManager.refresh(EmpegDiscoveryManager.java:161)
at org.jempeg.empeg.manager.dialog.ConnectionSelectionDialog.refresh(ConnectionSelectionDialog.java:240)
at org.jempeg.empeg.manager.dialog.ConnectionSelectionDialog$RefreshRunnable.run(ConnectionSelectionDialog.java:310)
at java.lang.Thread.run(Unknown Source)
RioCar 60gb
#186903 - 19/12/2003 09:35
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
That's it? There's no other output?
#186904 - 22/12/2003 09:19
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
That's all she wrote. You had me change it to use Unicast only when connecting to the empeg and now there is no output at all.
RioCar 60gb
#186905 - 22/12/2003 09:35
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
Same behavior in the UI? Just sits there at Downloading Database?
#186906 - 23/12/2003 10:05
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
It finishes downloading the database and stops at "Updating Interface"
RioCar 60gb
#186907 - 23/12/2003 10:56
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
Can you run it from the console again, and when it gets to the point when it hangs, switch to the console and press Ctrl-Break (or on Linux Ctrl-Backslash, I think) and send me the full output ...
ms
#186908 - 23/12/2003 15:18
Re: jEmplode 47
[Re: mschrag]
Loc: South Bay, CA: USA
Mike,
I just uploaded some files with 47 (nice work). I noticed that it caught the duplicates in the dialog, but strangely enough, it uploaded them dups anyways. The only reason this is somewhat bothersome is that I generated a soup called "newstuff" which only has recently uploaded material based on the create date. With 47, the duped stuff also showed up in newstuff since it was re-uploaded.
Is this pilot error?
-Ted
#186909 - 24/12/2003 02:16
Re: jEmplode 47
[Re: TedP]
thats how its supposed to work. it creates a reference to the track in the offending playlist.
#186910 - 24/12/2003 10:32
Re: jEmplode 47
[Re: image]
Loc: Richmond, VA
That's with a regular playlist ... with a soup playlist it should use the alternate implementation which doesn't do that (you don't want multiple instances appearing in soups)
#186911 - 24/12/2003 13:24
Re: jEmplode 47
[Re: mschrag]
wow. i can't believe i didnt notice this. where is the Ignore as Child option in the properties of playlists? it seems to be gone in v47.
#186912 - 24/12/2003 15:21
Re: jEmplode 47
[Re: image]
Loc: Richmond, VA
Hmm .. May have accidentally been sacrificed to the gods of shared Karma code ... I'll bring it back in the next build.
ms
#186913 - 24/12/2003 19:45
Re: jEmplode 47
[Re: mschrag]
May have accidentally been sacrificed to the gods of shared Karma code ... Which would be a real shame, seeing as how the last time I checked, the Karma actually correctly honors the ignore-as-child flag in nested playlists.
#186914 - 24/12/2003 20:58
Re: jEmplode 47
Loc: Richmond, VA
Yeah -- I just didn't realize that at the time ... There were a lot of pieces to pickup after I got the Karma code working.
#186915 - 28/12/2003 09:22
Re: jEmplode 47 : ID3V2 "genre" question
[Re: mschrag]
Loc: Waardenburg, The Netherlands
I just switched to jEmplode 47 (by replacing the jEmplode.jar file and adding the graphics.jar file).
Works nice, especially the updated sync method (previously I used the 44 version).
One question:
When I upload an mp3 using version 44, the tag "genre" of the file reflected the correct value (e.g. Rock).
When using version 47, new files get the full tag "(17)Rock" added (i.e. with the old ID3V1.x numerical code).
I checked the binary contents of the file, the full "(17)Rock"it is present in the file, also when I upload the file using jEmplode 44; The only difference seems to be the behaviour of jEmplode 47.
Is there any way to keep using version 47 without getting the numerical code automatically added? Or did something go wrong when updating from jEmplde 44 to jEmplode 47 on my system?
Jelle
NB: tested on SuSE 8.2 Linux system, with j2re1.4.2_01 as java engine
Empeg M2A Blue # 010101908 80Gb Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#186916 - 28/12/2003 18:49
[Re: juenk]
Loc: Richmond, VA
When you say upload, do you mean when you import the file from your computer to your empeg?
If I'm reading this correctly, you're saying the MP3 file has "(17)Rock" set as its genre ... Where are you seeing this value displayed in jEmplode -- if the playlist table view or somewhere else?
#186917 - 28/12/2003 22:40
[Re: mschrag]
you're saying the MP3 file has "(17)Rock" set as its genre I don't know if this has any bearing on the conversation, but sometimes when I download (Empeg->Computer) with Jemplode and it writes the ID3V2 tag to the file the genre field comes out as "(-1)".
#186918 - 29/12/2003 15:18
[Re: mschrag]
When you say upload, do you mean when you import the file from your computer to your empeg? Yes
If I'm reading this correctly, you're saying the MP3 file has "(17)Rock" set as its genre ... Where are you seeing this value displayed in jEmplode -- if the playlist table view or somewhere else? The 3 following screendumps probably explain my comments a little more:
(1) the first part (hexdump) of the original mp3 file.
(2) the genre as displayed in my ID3 tag editor ("Easytag")
(3) the result in jEmplode (the existing mp3, and the freshly added mp3 (with dupe check disabled)).
As can be seen, the new upload with jEmplode 47 results in the "(17)Rock" genre (in contrast to the existing one, uploaded with the pre-47 version).
NB: According to the ID3V2.3 specs, it is possible to have the old ID3V1.x numerical code to be present in the ID3V2.3 genre code (from this site)
NB2: It is still possible that this is due to incorrect upgrade from 44 to 47, so I'm really interested if anyone can confirm or deny this behaviour in their own setup with v47
#186919 - 29/12/2003 15:19
[Re: juenk]
ANd the second attachment (tag editor display)
#186920 - 29/12/2003 15:20
[Re: juenk]
third attachment (jEmplode display)
#186921 - 29/12/2003 16:45
Re: jEmplode 47
[Re: mschrag]
ive noticed that i can not change the name of either of my empegs using jemplode. it also wont set any other 'configure player' settings through a synch. such as phone number, name, email...
#186922 - 29/12/2003 17:11
Re: jEmplode 47
[Re: RobotCaleb]
Loc: Richmond, VA
#186923 - 30/12/2003 02:31
Re: jEmplode 47
[Re: mschrag]
Loc: Sweden
Thanks for a great program!
Just tried out v3a3/5 on the empeg and jEmplode everything works as expected but one thing - the swedish characters(åäöÅÄÖ).
I think it has to do with the fact that the database now is in UTF? It looks like a typical UTF-chars in a ISO8859-1 enviroment in the playlist in jEmplode (Everything looks ok in the empeg)..
Running Linux(Gentoo with 2.6-kernel), LANG=en_US
/Fredrik
#186924 - 08/01/2004 16:28
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
Ok, I upgraded to Jemplode 50 and still gettting the same issue... Here is my screen dump :
Full thread dump Java HotSpot(TM) Client VM (1.4.1_01-b01 mixed mode):
"DestroyJavaVM" prio=5 tid=0x00234AE8 nid=0x64c waiting on condition [0..6fadc]
"jEmplode: Download" prio=5 tid=0x0ACD0B78 nid=0x564 waiting on condition [cb4f0
00..cb4fd88]
at com.inzyme.model.LongVector.<init>(LongVector.java:60)
at com.inzyme.model.LongVector.<init>(LongVector.java:73)
at com.inzyme.model.LongVector.<init>(LongVector.java:82)
at org.jempeg.nodestore.FIDPlaylist.checkForProblems(FIDPlaylist.java:76
2)
- locked <04646DB8> (a org.jempeg.nodestore.FIDPlaylist)
at org.jempeg.nodestore.PlayerDatabase.checkForProblems(PlayerDatabase.j
ava:580)
at org.jempeg.manager.SynchronizeUI.download(SynchronizeUI.java:193)
- locked <0302BCD0> (a org.jempeg.empeg.protocol.EmpegSynchronizeClient)
at org.jempeg.manager.SynchronizeUI$2.run(SynchronizeUI.java:155)
"TimerQueue" daemon prio=5 tid=0x0C170960 nid=0x754 in Object.wait() [cb0f000..c
b0fd88]
at java.lang.Object.wait(Native Method)
- waiting on <0302BDB0> (a javax.swing.TimerQueue)
at javax.swing.TimerQueue.run(Unknown Source)
- locked <0302BDB0> (a javax.swing.TimerQueue)
"Thread-4" prio=5 tid=0x0C161FA8 nid=0x698 runnable [cabf000..cabfd88]
at java.net.PlainDatagramSocketImpl.receive(Native Method)
- locked <0302DE28> (a java.net.PlainDatagramSocketImpl)
at java.net.DatagramSocket.receive(Unknown Source)
- locked <0302DE58> (a java.net.DatagramPacket)
- locked <0302DE78> (a java.net.DatagramSocket)
at org.jempeg.protocol.discovery.SSDPDiscoverer$1.run(SSDPDiscoverer.jav
a:63)
"Thread-3" prio=5 tid=0x0C158FB8 nid=0x898 in Object.wait() [c60f000..c60fd88]
- waiting on <0302DDE0> (a java.lang.Thread)
at java.lang.Thread.join(Unknown Source)
- locked <0302DDE0> (a java.lang.Thread)
at org.jempeg.protocol.discovery.SSDPDiscoverer.startDiscovery0(SSDPDisc
overer.java:106)
at org.jempeg.protocol.discovery.AbstractDiscoverer.startDiscovery(Abstr
actDiscoverer.java:45)
at org.jempeg.protocol.discovery.CompoundDiscoverer$1.run(CompoundDiscov
erer.java:50)
"jEmplode: Refresh Connections" prio=5 tid=0x0C158540 nid=0x720 in Object.wait()
[c57f000..c57fd88]
- waiting on <0301C468> (a java.lang.Thread)
- locked <0301C468> (a java.lang.Thread)
at org.jempeg.protocol.discovery.CompoundDiscoverer.startDiscovery0(Comp
oundDiscoverer.java:64)
at org.jempeg.empeg.manager.DiscoveryManager.refresh(DiscoveryManager.ja
va:186)
nectionSelectionDialog.java:258)
able.run(ConnectionSelectionDialog.java:328)
"AWT-EventQueue-0" prio=7 tid=0x0ACE8A00 nid=0x380 waiting for monitor entry [bf
7f000..bf7fd88]
at org.jempeg.nodestore.model.AbstractFIDPlaylistModel.playlistStructure
Changed(AbstractFIDPlaylistModel.java:98)
- waiting to lock <04646DB8> (a org.jempeg.nodestore.FIDPlaylist)
- locked <04806F00> (a org.jempeg.nodestore.model.FIDPlaylistTreeNode)
at org.jempeg.nodestore.model.AbstractFIDPlaylistModel.ensureChildrenLoa
ded(AbstractFIDPlaylistModel.java:245)
at org.jempeg.nodestore.model.AbstractFIDPlaylistModel.isLeaf(AbstractFI
DPlaylistModel.java:66)
at javax.swing.tree.DefaultTreeModel.isLeaf(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$NodeDimensionsHandler.getNodeDimen
sions(Unknown Source)
at javax.swing.tree.AbstractLayoutCache.getNodeDimensions(Unknown Source
at javax.swing.tree.FixedHeightLayoutCache.getBounds(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.getPathBounds(Unknown Source)
at com.sun.java.swing.plaf.windows.WindowsTreeUI.ensureRowsAreVisible(Un
known Source)
at javax.swing.plaf.basic.BasicTreeUI.toggleExpandState(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.handleExpandControlClick(Unknown S
ource)
at javax.swing.plaf.basic.BasicTreeUI.checkForClickInExpandControl(Unkno
wn Source)
at javax.swing.plaf.basic.BasicTreeUI$MouseHandler.handleSelection(Unkno
wn Source)
at javax.swing.plaf.basic.BasicTreeUI$MouseHandler.mousePressed(Unknown
Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
"Java2D Disposer" daemon prio=10 tid=0x0ACCE260 nid=0x264 in Object.wait() [bf3f
000..bf3fd88]
- waiting on <02F665E8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <02F665E8> (a java.lang.ref.ReferenceQueue$Lock)
at sun.java2d.Disposer.run(Unknown Source)
"AWT-Windows" daemon prio=7 tid=0x0AC9D078 nid=0x1f4 runnable [aecf000..aecfd88]
at sun.awt.windows.WToolkit.eventLoop(Native Method)
at sun.awt.windows.WToolkit.run(Unknown Source)
"AWT-Shutdown" prio=5 tid=0x00957D08 nid=0x484 in Object.wait() [ae8f000..ae8fd8
8]
- waiting on <02F1B928> (a java.lang.Object)
at java.lang.Object.wait(Unknown Source)
at sun.awt.AWTAutoShutdown.run(Unknown Source)
- locked <02F1B928> (a java.lang.Object)
"Signal Dispatcher" daemon prio=10 tid=0x008B8660 nid=0x6a0 waiting on condition
[0..0]
"Finalizer" daemon prio=9 tid=0x008FBB00 nid=0x640 in Object.wait() [ab4f000..ab
4fd88]
- waiting on <02EFFAF8> (a java.lang.ref.ReferenceQueue$Lock)
- locked <02EFFAF8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=10 tid=0x008FAE90 nid=0x5a8 in Object.wait() [ab
0f000..ab0fd88]
- waiting on <02EFFB60> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <02EFFB60> (a java.lang.ref.Reference$Lock)
"VM Thread" prio=5 tid=0x008F9C58 nid=0x504 runnable
"VM Periodic Task Thread" prio=10 tid=0x008B70B8 nid=0x35c waiting on condition
"Suspend Checker Thread" prio=10 tid=0x008B7C78 nid=0x584 runnable overer.java:106)
erer.java:50)
[c57f000..c57fd88]
va:186)
7f000..bf7fd88]
known Source)
ource)
wn Source)
wn Source)
Source)
000..bf3fd88]
8]
[0..0]
4fd88]
0f000..ab0fd88]
00..cb4fd88]
2)
ava:580)
b0fd88]
a:63)
overer.java:106)
erer.java:50)
[c57f000..c57fd88]
va:186)
7f000..bf7fd88]
known Source)
ource)
wn Source)
wn Source)
Source)
000..bf3fd88]
8]
[0..0]
4fd88]
0f000..ab0fd88]
---- Every time I press CTRL-BREAK this outputs again --- I can't get Jemplode to exit without end-tasking it...
Edited by sirmanson (08/01/2004 16:30)
RioCar 60gb
#186925 - 08/01/2004 16:32
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
Just for grins, can you update to JDK 1.4.2 and try again? I'll look at what is going on in the code at these stack points as well ...
ms
#186926 - 08/01/2004 16:46
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
By the way, that output is what I wanted ... It's not supposed to quit. That sends a signal to the VM to display a dump of exactly what is executing.
ms
#186927 - 08/01/2004 16:48
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
So interestingly it doesn't appear to be a deadlock ... Maybe an infinite loop. Maybe there's a bug in the loop checker and you have a loop in your playlists or something. When 51 comes out, I'll include some extra debug statements so maybe we can find out what the hell it's doing.
#186928 - 08/01/2004 16:53
Re: jEmplode 47
[Re: mschrag]
Loc: Tucson, AZ USA
I upgraded to the JDK that you suggested and the same thing is happening. Do you want me to do a dump again as well?
RioCar 60gb
#186929 - 08/01/2004 16:55
Re: jEmplode 47
[Re: sirmanson]
Do you want me to do a dump again as well? I'm sorry, I just came over from reading the Bathroom Etiquette thread, and was temporarily confused...
#186930 - 08/01/2004 17:13
Re: jEmplode 47
[Re: sirmanson]
Loc: Richmond, VA
Yeah if you don't mind .. 1.4.2 has some nicer features
#186931 - 08/01/2004 19:53
Re: jEmplode 47
Loc: Northern Ireland
You and me both!
Geoff ---- ------- Mk1 Blue - was 4GB, now 16GB Mk2 Red - was 12GB, now 60GB
#186932 - 09/01/2004 08:17
Re: jEmplode 47
Loc: Tucson, AZ USA
Since Tony didn't link to the thread, I thought it would be appropriate for me to.
RioCar 60gb
#186933 - 24/01/2004 22:19
I don't know if this has any bearing on the conversation, but sometimes when I download (Empeg->Computer) with Jemplode and it writes the ID3V2 tag to the file the genre field comes out as "(-1)"..
Just for the record:
Issue is solved. It was probably due to a combination of a bug in Easytag and the (correct) logic in jEmplode.
I reinstalled jEmplode, updated it to V52, and upgraded Easytag to 0.30c (according to its logs they updated the id3v2.x part)
Now I get these results in the hexdump of the files:
if id3-tag is one of the 'standard' tags, only the numerical code is stored, e.g. "(80)". If it is a non-standard tag, only the text is stored (e.g. "Hollands"). Both situations are handled perfectly by jEmplode, resulting in correctly tagged files on the empeg.
Jelle
