#211651 - 30/03/2004 21:46 PCA tuners: input attenuation
az_max
Hi,
Is it possible to attenuate the output signal from the tuner module? I find certain stations seem to be overdriving the signal causing clipping at the Empeg. I would like to cut it down a couple db to prevent this. Suggestions?
#211652 - 30/03/2004 22:34 Re: PCA tuners: input attenuation [Re: az_max]
The tuner module has a local/DX function built-in, but it is not (yet) exposed to the GUI. If you bribe me enough, I may hack it into Hijack sooner rather than later
#211653 - 30/03/2004 23:28 Re: PCA tuners: input attenuation [Re: az_max]
adavidw
Loc: Utah, USA
If it's only particular stations, the local/DX things may be helpful, but if you want to turn the whole thing down, try volume_boost_FM as described here
-Aaron
#211654 - 31/03/2004 00:25 Re: PCA tuners: input attenuation [Re: az_max]
genixia
You might also want to try disable_bassboost_FM=1. You should verify the syntax in the hijack FAQ.
