#224355 - 01/01/2004 16:27 ARM problems
treyco
OK...I have an original Rio Receiver. I am using ARM 1.0.3. Although when I look at a log of the music import, it says that all of my songs are being added to the database (cuurently 962 songs), when I try to pull up a list by artist on the receiver, it is missing some of my artists. I have checked that all of my ID3 tags are correct. This happens whether I use the original reciver software or TRio. Any ideas? Anyone know where I can get the 1.0.4 software?
Also, I have tried three times now to install and run JReceiver (XP system) and can't get it to work. I have to run ARM in order for the receiver to boot, but Jreceiver gives me a message that it cannot bind to an address when I try to start it up. Does anyone have any easy to follow instructions for getting JReceiver up and running?
Thanks for any help.
#224356 - 01/01/2004 23:40 Re: ARM problems [Re: treyco]
Bigdoe101
Hi,
Here is the link to Rio's Site. You should be able to download the software from there.
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=99
I'm have trouble trying to get XP to work with ARM. How did you get it to see the rio receiver?
David
Rio Central....and might be getting a rio receiver too
#224357 - 02/01/2004 09:25 Re: ARM problems [Re: Bigdoe101]
treyco
I didn't do anything special, I just installed it on XP and plugged the receiver in. That seemed to be the easy part.
#224358 - 02/01/2004 12:31 Re: ARM problems [Re: treyco]
It is most likely this problem.
