#226051 - 08/07/2004 16:09
My player doesn't start up :-(
Loc: Berlin DE
Hi there,
Does anyone could help me? The player won't start, the Display stays blank and the Standby LED dims up and down.
here is the stuff from hyperterminal :
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)12cc6c00
Funct empeg re If there is anyone present who wants to upgrade the flash, let them speak now, 0000000ceg usb initialised, PDIUSBD12 id 1012t [<40002bf8>] from [<4000e320>] or forever hold their peace...it seems not. Let fly the Penguins of Linux!0000BC r8 = 000005C4 r7 = 4001E3B8 r10 = 00000000 r9 = init
e000 v1.04violation Copying kernel...lr=0x4000b738 (ba Calling linux kernel...15 r6 = 0000 Uncompressing Linux..................................... done, booting the kerne8 r9 = 00013878 r8ion at r10 = 4001D858 r9 = 0001 Function entered at [<4= l.00 Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi : [<4000b738>]4 = 4001E16050>] lr : [<4000b738>] r6 = 00000002400 Function on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 200101e070 fp : bffffa68 r10 = 4001D858 r5 = 00000000 r4 Processor: Intel StrongARM-1a NET4: Linux TCP/IP 1.0 for NET4.00000 r9 = 00000000 r8 = 0000000 IP Protocols: ICMP, UDP, TCP r9 = 0 Function entered at TCP: Hash tables configured (ehash 16384 bhash 16384)R_32 Segment user8>] r6 r10 = 4001D858 r9 = 0000 IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)r5 = Function ente Function entered at [< Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )r10 = 4001D858 r5 = 0 Function entered at [ init(1): memory viol ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )8 = BFFFFEFtered at [<4000a7 = 4001E3B8 : 000 r10 = 00000000 r9 = 00000000 r Starting kswapd v 1.598>]20001E43C r5 = 4 SA1100 serial driver version 4.27 with no serial options enabled Function enter r10 = 4001D858 r9 = 00000002aa4>]7D Table: C empeg state support initialised 0089/88c1 (save to d0004400). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: TOSHIBA MK4018GAS, ATA DISK drive hda: TOSHIBA MK4018GAS, ATA DISK drive hda: TOSHIBA MK4018GAS, ATA DISK drive hda: TOSHIBA MK4018GAS, ATA DISK drive hda: TOSHIBA MK4018GAS, ATA DISK drive hda: TOSHIBA MK4018GAS, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: TOSHIBA MK4018GAS, 38154MB w/0kB Cache, CHS=4864/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:2 0 Partition check: hda:hda: status timeout: status=0x84 { Busy } hda: drive not ready for command
seems that there is some problem on communication between player and hdisk...
kind regards from berlin/germany
Dave
#226052 - 08/07/2004 16:33
Re: My player doesn't start up :-(
[Re: megadave]
Loc: Ada, Oklahoma
I think your flux capacitor is broken...  Have you made any drive changes recently?
-Michael West
#226053 - 08/07/2004 16:49
[Re: mwest]
The hyperterm transcript is a little muddled, but it certainly looks like a drive communication issue. This one is slightly new to me (status timeout and drive not ready for command), but I would recommend you try the hard drive troubleshooting steps in the FAQ before anything else.
#226054 - 08/07/2004 16:50
[Re: megadave]
Not certain, but the kernel appears to be crashing before it even gets to the hard disk detection. (Based on the errors and the "function entered" being listed before the HD detection lines. That's if the listing above is accurately what's being output and isn't messed up in the translation somehow.)
Perhaps the flash memory got corrupted somehow. Try doing a RAM Test. If it passes the RAM test, try putting a fresh Hijack kernel into place and see if that fixes it.
#226055 - 08/07/2004 17:01
I thought it was more just a hyperterminal capture glitch. The registers start appearing in what looks like the protected boot code, before the kernel even starts loading.
#226056 - 08/07/2004 18:11
The reason why the boot log is so weird looking is Hyperterminal being it's usual crap self. It's overlaying the latest lines over the old ones which makes it look like the bootloader is printing out the oops.
The empeg is detecting the HD and then dying with a memory violation when it tries to load init. Check the cable?
#226057 - 08/07/2004 20:03
[Re: tman]
Ah, OK. Yeah, if he's having disk trouble, then as everyone else said, start going through the usual troubleshooting steps. Strange, I've never seen Hyperterminal do that to me.
#226058 - 08/07/2004 20:25
Nor I (at least, not in that exact manner), but hyperterminal has a bad reputation at best. You have to capture to a file, otherwise you get messy results. I tend to get a lot of drops in the text and sessions blending with each other if I just capture text from the screen.
#226059 - 10/07/2004 10:37
[Re: megadave]
Loc: Berlin DE
hi guys,
thanks for the help so far.
here is the copied stuff from hyperterminal from the ramtest
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) r10 = 00000000 r9 = 00000000 r8 = 00000000 r7 = If there is anyone present who wants to upgrade the flash, let them speak now, r6 = 00000000 r5 = 00000000 r4 = 00000000ode USER_32 Se or forever hold their peace... 0100 ram test starting 0110 testing ic 1 (0-15mb, low word) 0120 testing ic 2 (0-15mb, high word) 01f0 ram test done 0200 ide detect 0210 command issued 0220 drive id TOSHIBA MK4018GAS 02f0 ide ok 0300 dsp/i2c test 03f0 dsp/i2c ok 0400 temperature detect 0410 temperature is 00 04f0 temperature ok 0500 usb detect 0510 usb rev 1012 05f0 usb ok 0600 ethernet detect 0610 ethernet rev 334b 06f0 ethernet ok 0700 cs4231 detect 0710 cs4231 rev a0 07f0 cs4231 ok 00f0 tests complete
it seems that everything is ok. the cable won't be the problem. i have two players and changed harddrives in between. but the player won't start. next step i guess is a fresh hijack kernel. thanx, dave
#226060 - 10/07/2004 11:01
[Re: megadave]
Loc: Berlin DE
well, the clean hijack kerne did not help but programmed successful...
here is the actual hypertpaste
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)bing primary interface... r10 = 4001D If there is anyone present who wants to upgrade the flash, let them speak now, hda: TOSHIBA MK4018GAS, ATA DISK drive
or forever hold their peace...it seems not. Let fly the Penguins of Linux!F hda: TOSHIBA MK4018GAS, ATA DISK drive
e000 v1.04SHIBA MK40 Copying kernel...ive00000 r4 = 00 Calling linux kernel... hda: TOSHIBA MK4018GAS Uncompressing Linux..................................... done, booting the kerneon irq 6 init(1): memory violation at pc= hda: TOSHIBA MK4018GAS, 38154MB w/0kB l.ch Linux version 2.2.17-rmk5-np17-empeg52-hijack-v395 (mark@rtr.ca) (gcc version 2.peg-flash driver initializedr10: 4001d858 r9 : 00000000 smc chip id/revision 95.3 20010315 (release)) #2 Sun Jun 27 17:52:49 EDT 20046 by Erik Stahlman (erik@vt.edu) Processor: Intel StrongARM-1100 rev init(1): memory viol Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)C: 000000157 = 40000230 Dentry hash table entries: 2048 (order 2, 16k)m [<40003998>]20 r4 = 4001E16050>] lr : [< Buffer cache hash table entries: 16384 (order 4, 64k) r10 Page cache hash table entries: 4096 (order 2, 16k)00000]p : bff IP Protocols: ICMP, UDP, TCP Function entered at TCP: Hash tables configured (ehash 16384 bhash 16384)f994 r4 = 00000000 IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) r10 = 4001D858 r5 = 00000000 r4 = Starting kswapd v 1.55d35c r4 : 4012cc6c0 SA1100 serial driver version 4.27 with no serial options enabled Function entered at [<400023e0>] fro ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART0062c r0 : 000 ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART r10 = 00000000 r9 = 0000000 ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART
empeg dsp initialised sp : bffff968 ip : empeg audio-in initialised, CS4231A revision a0 Function entered at [<40002 empeg remote control/panel button initialised.4001d858 r9 : 00000000 r8 : bffff99400 empeg usb initialised, PDIUSBD12 id 1012r10 = 4001D858 r5 r7 empeg state support initialised 0089/88c1 (save to d0004780). Function empeg RDS driver initialised
empeg power-pic driver initialised (first boot)1e440 r1 : 0000062c r0 : 0000000c = 00000000 RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE r6 = 40
hda: TOSHIBA MK4018GAS, ATA DISK drive000000 r5 = 00000000 r4 = 00000000od ide0 at 0x000-0x007,0x038 on irq 6 hda: TOSHIBA MK4018GAS, 38154MB w/0kB Cache, CHS=4864/255/630b750, lr=0x4000b738 (bad address=0x8003c660000015 empeg-flash driver initialized SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:2 0 Partition check: hda:hda: status timeout: status=0x84 hda: drive not ready for command ide0: reset timed-out, status=0x84 hda: status timeout: status=0x84 hda: drive not ready for command ide0: reset timed-out, status=0x84 hda: status timeout: status=0x84 end_request: I/O error, dev 03:00 (hda), sector 0 hda: drive not ready for command unable to read partition table RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). Timezone: /usr/share/zoneinfo empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...attempt to access beyond end of device 03:05: rw=0, want=2, limit=0 dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1 EXT2-fs: unable to read superblock Kernel panic: VFS: Unable to mount root fs on 03:05
what could i try now??
thanx for ur all help! dave
#226061 - 10/07/2004 11:03
[Re: megadave]
My suggestions of the RAM test and fresh kernel were based on the messed-up hyperterminal log. It turns out there is nothing wrong with RAM or flash, so those things are not going to help. It's more likely a problem with the disk drive, the cable, or the IDE header. Definitely start going through the entire list of possible causes for hard disk trouble methodically, one by one.
