#230120 - 08/08/2004 08:33
empeg keeps rebooting
Loc: AC, Germany
hello,
since a week or so (i donßt use my car every day, lately) my empeg will boot; play music for 1-2 seconds then freeze and reboot; sometimes it freezes at the second boot, sometimes it plays music again but is uncontrollable and sometimes the display stays black; what can be the cause for this behavior?
EDIT: it's a mk2 running 2.00 and HiJack v362 at the moment, but I tried with v410 too.
Edited by Lupo (08/08/2004 08:38)
#230121 - 08/08/2004 09:56
Re: empeg keeps rebooting
[Re: Lupo]
#230122 - 08/08/2004 12:56
[Re: pgrzelak]
Loc: AC, Germany
Hi;
I thought of that too, but it does so even in tuner mode...it seems "more complicated"; just now it worked again but i bet if I try to start it now, it won't work...
is there something more I can do to explain the problem?
#230123 - 08/08/2004 13:31
[Re: Lupo]
The bad track might be choking the player even if you quickly go to tuner mode. You might want to check out Paul's link just in case to eliminate it.
#230124 - 08/08/2004 13:42
[Re: SE_Sport_Driver]
Loc: AC, Germany
Hi,
I tried it and the player booted fine; but I get "memory violation" errors in Hyperterminal; I append the file.
229003-log2.TXT (160 downloads)
#230125 - 08/08/2004 13:51
[Re: Lupo]
Nothing in that file. You have to keep the size down. ZIP it or something.
#230126 - 08/08/2004 14:14
[Re: Roger]
Loc: AC, Germany
D*oh... here it is: Quote:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 7, serial number 80000456)
Command line: mem=12m
Memory: 10940k/12M available (996k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c8
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
change_root: old root has d_count Trying to unmount old root ... okay
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
hijack_do_execve: execve() failed, errno = 2
hijack_exec("/programs0/empacman"), rc=-2 (ERROR)
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
khttpd: listening on port 80
kftpd: listening on port 21
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
empeg:/empeg/bin# / ./player -i
bash(12): memory violation at pc=0x02033000, lr=0x00000000 (bad address=0x00000000, code 2)
pc : [<02033000>] lr : [<00000000>]
sp : bffffe5c ip : bffffe70 fp : bffffe6c
r10: 40155128 r9 : 0200fbd0 r8 : 0207bc58
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 02084380
r3 : 00000000 r2 : 00000000 r1 : 00000035 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: D038117D Table: D038117D DAC: 00000015
Function entered at [<02012054>] from [<020121b0>]
r4 = 00000000
Function entered at [<020120fc>] from [<02011e78>]
r8 = 0206459C r7 = 0200F224 r6 = 0207BC80 r5 = 00000001
r4 = 00000000
Function entered at [<02011d44>] from [<0201041c>]
r5 = 00000000 r4 = 02080F38
Function entered at [<0200fbd0>] from [<4008d040>]
r6 = 4000C2A8 r5 = 00000001 r4 = BFFFFF24
Function entered at [<4008cee4>] from [<0200fb40>]
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 0200FB1C r5 = 00000000 r4 = 4001E5EC
Shell exit
Starting player
Vcb: 0x4054d000
[27] player: old system call.
Function entered at [<5f5f3625>] from [<00006f66>]
Unable to handle kernel paging request at virtual address 5f5f3629
memmap = D0380000, pgd = c0b80000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00e5de0>] lr : [<c0019710>]
sp : c0383f88 ip : c0383f44 fp : c0383fb0
r10: 00000008 r9 : 00000001 r8 : 0000000c
r7 : 00000000 r6 : 5f5f3625 r5 : 7079745f r4 : 021233e4
r3 : 60000013 r2 : c01061e4 r1 : 00000001 r0 : 021233d4
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 27, stackpage=c0383000)
Stack:
c0383f60: c0019710 c00e5de0
c0383f80: 60000013 ffffffff c0383fb8 0214f0c0 00cf3731 40000013 c0383ff4 c0010810
c0383fa0: 021233bc 00000000 c0383fb4 c000a0a4 c0010790 021233bc 021549d8 00000001
c0383fc0: 00000008 021549d8 021233bc 0214f0c0 021233d0 0214f0f0 02152f98 00000001
c0383fe0: 00000008 021233e4 0214d744 0214f0d0 0207d924 021233fc 20000010 021549d8
Backtrace:
Function entered at [<c0010784>] from [<c000a0a4>]
r4 = 021233BC
CoRestored terminal settings
Player received signal 11
Starting bash.
empeg:/empeg/bin#
#230127 - 09/08/2004 19:13
Loc: AC, Germany
Quote: The bad track might be choking the player even if you quickly go to tuner mode. You might want to check out Paul's link just in case to eliminate it.
thinking of this: is it possible that a bad track gets the player to reboot even if it's not the track actually playing? If so I could erase everything and reload artist by artist and checking if it works with every track and maybe that way I find a bad track?
But what remains are the "memory violation" messages I get while the player is booting.
#230128 - 09/08/2004 19:46
[Re: Lupo]
From that command line, can you try a "player -i" command? The memory violation error is something I would expect if the player application hits a bad track. Or (almost) anything else bad, for that matter.
#230129 - 09/08/2004 19:57
[Re: pgrzelak]
Loc: AC, Germany
Quote: From that command line, can you try a "player -i" command? The memory violation error is something I would expect if the player application hits a bad track. Or (almost) anything else bad, for that matter.
Yes, the "./player -i" comand is in there somewhere; I should have shortened the text a little..
I think I should shoot a 5 min movie of the empeg to show the problem, it's kinda bizarre...
#230130 - 09/08/2004 20:47
[Re: Lupo]
Hmmm... Okay. I see the player -i now. Assuming this is a one disk player, have you noticed any previous problems with the audio that might be signs of disk issues? Have you tried reapplying the 2.0 upgrade file? Do you have any other programs running on your player?
#230131 - 09/08/2004 20:58
[Re: pgrzelak]
Loc: AC, Germany
Hi;
It's a one-disc player.
No, until now it worked great. I think it froze one or two times since I use it (18 months), but no audio quality degradation or such; I reapplied 2.0beta13, then 2.0final and I also tried different HiJack versions but still the same. Wa I write, it's been playing music since 25 minutes without problems (it's not connected to the PC so I can't see what the serial port is putting out, but I guess it's okay); but before that I had to unplug the cord at least 3 times.
Software running should be empire and empacman; do you think I should temporarily delete them just to see what happens? Still, I think it would be strange if it worked because both programs are running since august last year.
I'm pretty clueless...
#230132 - 09/08/2004 21:03
[Re: Lupo]
Hmmm... I am not sure either. Do you see the problem both at home and in the car? Has it been a long time since the drive was checked with fsck? It should not be the third party software, but...
#230133 - 09/08/2004 21:11
[Re: pgrzelak]
Loc: AC, Germany
Hi,
I tried to manually FSCK twice; the first time it seemed to work, but then problems started soon after and after the second try 3 days later it hung just after rebooting...
The problem is there on AC and DC; could it be the hard drive giving up?
#230134 - 09/08/2004 21:37
[Re: Lupo]
Possible, but I would have expected some other symptoms - clicking, distortion, skips, etc. It might be the header, though. Have you inspected your drive cable for loose connections?
#230135 - 09/08/2004 21:46
[Re: pgrzelak]
Loc: AC, Germany
Hi,
yes, checked that too, and to make sure it's ok I connected the hard drive to the connector that's for the second harddisk (I moved the drive); and the header on the mainboard is ok too...I really hope it's not an Hardware problem of any kind...
#230136 - 09/08/2004 21:48
[Re: Lupo]
I am wondering if it could be a dry solder joint. After that, I would start to think hardware - maybe memory. Do you notice if there is any pattern at all to the failures? The unit being hot or cold? You might want to try a boot with a control-T to get into the self test.
#230137 - 09/08/2004 21:52
[Re: pgrzelak]
Loc: AC, Germany
There's not really a pattern; I would even say no pattern at all, it just happens, and that is what buggers me...I never dropped it, it worked flawless for way over a year and now it's starting making problems...
I tried the "Ctrl-T" test, and got nothing strange out of it...
I'm going to bed now as it's 2 in the morning here, but I'll check the mainboard for some partially disconnected components that may be due to a dry solder joint?
thanks for your help, paul; I really hope we can sort this out...
#230138 - 09/08/2004 22:14
[Re: pgrzelak]
Would anything goofy in the config.ini file along with those 3rd party aps that could cause this if something was corrupt?
#230139 - 10/08/2004 09:31
[Re: Lupo]
Either comment-out or remove the ;@EXEC and ;@EXEC_INCE lines in the config.ini file and then try again. You can use Hijack FTP to access the file, even with the player crashing away in the background. Eg. Something vaguely like this sequence: Code:
ftp your.players.ip.address cd /empeg/var get config.ini quit
<<edit the file on your pc>>
ftp your.players.ip.address cd /empeg/var site rw put config.ini site ro quit
#230140 - 10/08/2004 18:57
Loc: AC, Germany
Quote: Either comment-out or remove the ;@EXEC and ;@EXEC_INCE lines in the config.ini file and then try again. You can use Hijack FTP to access the file, even with the player crashing away in the background.
Eg. Something vaguely like this sequence:Code:
Hi,
this seems to have made the empeg way more stable, I justl got a reboot twice since 4 hours ago; will do a "long-term test" until next week, so maybe it's ok now.
What still buggers me is why it went ok for so long before starting this bizarre behaviour?
#230141 - 10/08/2004 22:54
[Re: Lupo]
Well, running v3a8 will do that to ya! It uses a lot more memory than some earlier releases, and every byte counts.
If you want to restore pacman etc.. then you could (1) stick them on ;@MENUEXEC lines instead of ;@EXEC lines, and then just select them from the Hijack menu on demand; or (2) try adding a ReserveCache=64 line (or similar) to config.ini on the player.
#230142 - 13/08/2004 10:24
Loc: AC, Germany
Hi,
I guess I was too optimistic. It still behaves like before.
Today I wantewd to check if there are some dry solder joints or such and I found a "bridge" between 2 of the "legs" of the "smsc" chip near the ethernet connector; the bridge is on the ethernet connector side too, for orientation. I guess thic chip is for the ethernet connection, so maybe it doesn't affect the player.
The pic is small, but I hope it's understandable; my question is: is this correct or could this be the cause for at least some problems I'm having?
EDIT: I found this on 2 other chips, the one with the "crystal" logo and the other is a smaller one; just near the intel StrongARM, labeled P98AB LVX4245 (2 of them side by side)
Edited by Lupo (13/08/2004 11:20)
#230143 - 13/08/2004 12:38
[Re: Lupo]
It won't be the solder joints, so leave the board alone!
Next step, if you have not tried it yet: Actually, this should have been the first thing to try:
Connect to the player's serial port, hit "control C" to get a shell prompt (developer s/w required -- upgrade if necessary), and the do "player -i".
#230144 - 13/08/2004 14:56
Loc: AC, Germany
Hi Mark,
don't be afraid, I am not trying to make things worse here; I just noticed these things and thought that maybe it could be something. I'm the first to think that it can't be these "bridges" that I saw because until now the player was fine and these bridges can't just have come out of nothing.
I've done that; in the boot log I posted on page 1 in approx. the middle of the text there's the line where I sent that comand; and what happened afterwards.
Now I have another thing in my mind: I could delete all the tunes from the empeg, format the drive and start from scratch; could this be helpful?
TIA
#230145 - 13/08/2004 23:35
[Re: Lupo]
Those "bridge" solder joints are likely to be correct. The pins are simply connected to each other via a track on the board. Because of this, when they are reflowed, the solder easily flows and bridges the two pins.
Because this makes visual inspection difficult, we try not to do this and instead run a small loop out of one pad into the other rather than straight between them.
I agree with Mark, not your problem.
#230146 - 14/08/2004 04:51
[Re: Shonky]
Loc: AC, Germany
Quote: Those "bridge" solder joints are likely to be correct. The pins are simply connected to each other via a track on the board. Because of this, when they are reflowed, the solder easily flows and bridges the two pins.
Thanks for the explanation.
#230147 - 14/08/2004 09:19
[Re: Lupo]
What version of player software is this?
If it is not v2final or v2.01final, then reinstall one of those two. Actually, just *do it* anyway. This will fix any corrupted binaries that might be the problem here. The log messages indicate that /bin/sh is failing, due to lack of memory or corruption (bad bits) in the file itself. I think the latter is extremely unlikely though, so it's almost certainly lack of memory.
This is a Mk2 unit, with only 12MB, NOT ENOUGH for any of the v3alpha releases to run reliably on. So.. (re)install v2final or v2.01final on it.
If *that* then fails, it's time for the disk builder software to blow everything away. But I think that should never be necessary, and in the past has nearly always proven a waste of time.
#230148 - 14/08/2004 09:35
Loc: AC, Germany
Hi Mark, the player is running 2.00 (I downloaded it from the empeg.com site and reinstalled it 2 days ago), but it's been running on 2.00 for some months now.
I will reinstall it once again. I guess a memory upgrade would really be worth getting at this point..
#230149 - 14/08/2004 10:07
[Re: Lupo]
Okay, good. And please post an updated boot log afterward, if it's still failing. It's important for us to see *exactly* what is currently happening (as opposed to what was there a few days ago) -- there may be subtle differences to pick up on.
