#260996 - 20/07/2005 16:12
Mk2a wont power up in car/dock, but fine in ac
Hi, all.
When I put my spare Mk2a in the dock I bought from Boxer (thanks, Boxer!) after having put on some Greenlights buttons, the only thing that happened was the blue light flashing. This was the first time I have tried it on dc power (I might have tried it in the car a long time ago). When I applied ac power it booted up normally, so I tried it in the car in case there was something wrong with the dock wiring, but the same thing happened in the car...
When I connected up the serial and applied power (in the dock), I got: empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) , quick boot Power down Power down Power down Power down Power down ...
The bootlog in ac is normal. I also reflashed it to 2.01 developer (was 2.00 developer) and installed Hijack 434, but no change.
Anyone have any good ideas?
Stig
#260997 - 20/07/2005 16:54
Re: Mk2a wont power up in car/dock, but fine in ac
[Re: StigOE]
Bootlog, please....
#260998 - 20/07/2005 17:43
[Re: schofiel]
The bootlog from when I plugged in the power in the dock is what I wrote in my previous post.
Bootlog when powered in ac:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v434 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Jun 23 22:37:21 EDT 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: passed. c1100000: passed. c1200000: passed. c1300000: passed. c1400000: passed. c1500000: passed. c1600000: passed. c1700000: passed. c1800000: passed. c1900000: passed. c1a00000: passed. c1b00000: passed. c1c00000: passed. c1d00000: passed. c1e00000: passed. c1f00000: passed. c2000000: wrote ffffffff, read 00000000 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101202) 32MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 31232k/32M available (984k code, 20k reserved, 528k data, 4k init) Dentry hash table entries: 4096 (order 3, 32k) Buffer cache hash table entries: 32768 (order 5, 128k) Page cache hash table entries: 8192 (order 3, 32k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 32768 bhash 32768) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004800). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IC25T060ATCS05-0, ATA DISK drive hda: IC25T060ATCS05-0, ATA DISK drive hda: IC25T060ATCS05-0, ATA DISK drive hda: IC25T060ATCS05-0, ATA DISK drive hda: IC25T060ATCS05-0, ATA DISK drive hda: IC25T060ATCS05-0, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:04:b2 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... •Ô¿'¤S«¹Ñ•‘�Û½½Ñ�¡*áÑÉ�2¥±•ÍåÍÑ•µ¥ƒ’•…‘½¹±å¹{jþchange_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: CET Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 Using non-standard cache size 374 (bonus 16Mb, adjustment 0) player.cpp : 385:empeg-car 2.01 2004/07/06. Prolux 4 empeg car - 2.1434 Jul 5 2004 Vcb: 0x4176d000
To me it looks normal...
Stig
#260999 - 20/07/2005 20:00
[Re: StigOE]
Hmmm... Have you tried it in a different car sled or one of Mark's docks? That would isolate an issue with the specific sled.
Edit: Hmmm... rereading your first post, it happens in both a dock and a sled. That implies something bad on the power lines of the player itself or the connector, specifically on the DC link.
#261000 - 21/07/2005 20:54
[Re: StigOE]
Hmm, this was strange. I opened the player to see if I could see anything obviously wrong (which I didn't), when I remembered Tony had some problems with his ac sensor. But I didn't remember what the symtoms were, so I did a search and found this post, which looked to be the same problem as mine. When I connected the sled connector from my spare sled and applied power to check the diode, it powered up properly... even in the sled and after I had re-assembled the player... So now it works again.  Maybe the electrons were flowing in the wrong direction or the phase of the moon was a bit wrong or something the other day...?  Stig
#261001 - 21/07/2005 21:07
[Re: StigOE]
So to recap, it works in one sled but not in another sled, but your Empeg MkII works in both sleds?
EDIT: Never mind, I reread your orginal post, and we're not talking about a blown sled fuse as you're using a ML Dock.
Edited by matthew_k (21/07/2005 21:19)
#261002 - 21/07/2005 21:16
[Re: matthew_k]
Quote: So to recap, it works in one sled but not in another sled, but your Empe MkII works in both sleds?
If that's the case, then his problem is very specifically this problem.
#261003 - 21/07/2005 21:20
Yeah, that's what I was getting at. But I reread the thread and I don't think that's it.
#261004 - 22/07/2005 05:02
[Re: matthew_k]
Yep, you're right. It isn't...  It wouldn't boot up in neither car nor ML dock, but no problems on ac. Stig
