#288653 - 23/10/2006 20:39 SATA card help
I just bought an SATA RAID card, but I don't want a RAID. I just want single drives, and my mobo only has two ports. So I just want the expansion. Can anyone tell if this is possible with the card I bought?
Newegg
The manual is here
I spent all last night attempting to configure it correctly, but it will only let me make arrays, and only two of them at that. It looks like it will allow for single drive operation, but it doesn't say how.
I'd greatly appreciate any help.
#288654 - 23/10/2006 21:06 Re: SATA card help [Re: Dignan]
It should work just fine as a normal drive controller with Linux.
#288655 - 23/10/2006 23:10 Re: SATA card help [Re: mlord]
Well I figured it should work fine with Windows, too. But it seems to insist on creating arrays, starting at the card's BIOS. I can't seem to tell it to just see all the drives independantly.
Even if I can't get it to work "properly", I may keep it. It's $40 for a 5-port RAID card (after rebate), and I might use it on a MythTV box I'd like to build sometime.
#288656 - 24/10/2006 00:37 Re: SATA card help [Re: Dignan]
Have you tried letting it create an array of *one*?
The first review from the NewEgg link says:
Other Thoughts: VERY HELPFUL INFORMATION: After you create your array, any time you restart your PC, you have to re-initialize it through the windows based application. double click icon in task bar, select top drive, hold shift and down arrow until all disks highlighted, then create, apply changes.
If you have to highlight the drives to create your array, maybe just highlight one drive at a time?
/totally inexperienced with RAID cards
Edited by Robotic (24/10/2006 00:43)
#288657 - 24/10/2006 01:00 Re: SATA card help [Re: Robotic]
Thanks for responding.
Unfortunately, I don't think that's going to work. I didn't see that either, and it sounds kind of crummy if you're actually running an array (I'm beginning to have doubts about this card).
One thing I thought might work is if I created a not-really-RAID 0 for each drive, so that each drive would have an array. The card only allowed me to create an array for two drives. Apparently two arrays is the maximum.
#288658 - 24/10/2006 19:49 Re: SATA card help [Re: Dignan]
Does anyone have any suggestions? I think that for the time being, I might just send this thing back.
