#292447 - 17/01/2007 14:23 Hijack v467 Button Names: complete list
Here (and also attached) is a complete listing of "button names" known to Hijack v467.
Enjoy!
There are two primary chunks of software on the Empeg/Rio Car player.
One is the Hijack (Linux) operating-system kernel, referred to as "Hijack".
The other is the original application software, referred to as "the player".
The Hijack kernel includes support for remapping button functions
(the "ir_translate" feature), button macros, and PopUp menus of buttons.
Originally, button codes had to be entered in hexadecimal notation
(still valid), but eventually a "button name" dictionary was added to Hijack.
This complete "button dictionary" is documented herein, as of Hijack v467.
Below, are lists and descriptions of several categories of buttons.
This includes "virtual" buttons which do not have any default correspondence
to real buttons on any of the remote controls, as well as the physical
buttons found on the Empeg/Rio front-panel, the original Kenwood remote,
the production Rio Remote, and the Sony RM-XS4 "stalk".
These names produce the exact same effect as pressing the buttons themselves.
The exact functionality depends upon the state the player software is in.
Some buttons are known by more than one name, indicated by "(alternate)".
Although the descriptions below use a mix of upper/lower case spellings
for the button names, Hijack ignores upper/lower case differences when
processing its configuration info from the config.ini file.
Hijack has several "virtual" ("fake") buttoncodes for its own use,
which trigger specific features of Hijack rather than of the player.
NAME ACTION
PopUp0 pop-up a special button menu onto the front-panel display
PopUp1 pop-up a user-defined button menu
PopUp2 pop-up a user-defined button menu
PopUp3 pop-up a user-defined button menu
VolAdjLow set automatic-volume-adjust to the "Low" setting
VolAdjMed set automatic-volume-adjust to the "Medium" setting
VolAdjHigh set automatic-volume-adjust to the "High" setting
VolAdjOff set automatic-volume-adjust to the "Off" setting
BassAdj activate the bass-adjustment pop-up screen
TrebleAdj activate the treble-adjustment pop-up screen
KnobSeek activate the "knob seek" pop-up: for radio tuning or track skipping
Clock pop-up a date/time display
NextSrc cycle among the MP3,TUNER(,AUX) sound inputs
SaveSrc remember current sound input for later recall
SaveAux do SaveSrc and then switch to AUX input
RestoreSrc return back to previously saved sound input
AM switch to AM radio sound input
FM switch to FM radio sound input
Reboot try to simulate switching the power off and on again
VolAdj activate the Automatic-Volume-Adjustment pop-up screen
QuickTimer activate the Countdown-Timer pop-up screen (like a "sleep timer")
HijackMenu pop-up the main Hijack-Menu screen
VisualSeek activate a pop-up screen which uses the knob to select among visuals
Initial ??
null do nothing: used to insert a short delay between buttons inside a macro
PrevVisual Select previous player visualization-graphic in sequence
This group lists the names which correspond to the buttons
on the front-panel of the Empeg/Rio Car main unit.
NAME ACTION
Top front-panel top button
Bottom front-paenl bottom button
Left front-panel left button
Right front-panel right button
KnobLeft anti-clockwise twist of front-panel knob
KnobRight clockwise twist of front-panel knob
Knob press of front-panel knob
SeekTool press of front-panel knob (alternate)
This next group are the names which correspond to the buttons
of a Rio Remote.
NAME ACTION
Power the Source/Power button
Source the Source/Power button (alternate)
One the 1//Time button
Time the 1/Time button (alternate)
Two the 2/abc/Artist button
Artist the 2/abc/Artist button (alternate)
Three the 3/dev/Album button
Album the 3/dev/Album button (alternate)
Four the 4/ghi button
Five the 5/jkl/Genre button
Genre the 5/jkl/Genre button (alternate)
Six the 6/mno/Year button
Year the 6/mno/Year button (alternate)
Seven the 7/prs/Repeat button
Repeat the 7/prs/Repeat button (alternate)
Eight the 8/tuv/Swap button
Swap the 8/tuv/Swap button (alternate)
Nine the 9/wxy/Title button
Title the 9/wxy/Title button (alternate)
Zero the 0/qz/Shuffle button
Shuffle the 0/qz/Shuffle button (alternate)
Tuner the Tuner/Bank button
SelectMode the SelectMode button
SelMode the SelectMode button (alternate)
Cancel the Cancel/Mark button
Mark the Cancel/Mark button (alternate)
Search the Search button
Sound the Sound/Equalizer button
Equalizer the Sound/Equalizer button (alternate)
Prev the |<< / << button
PrevTrack the |<< / << button (alternate)
Track- the |<< / << button (alternate)
Next the >>| / >> button
NextTrack the >>| / >> button (alternate)
Track+ the >>| / >> button (alternate)
Menu the Menu/OK button
Ok the Menu/OK button (alternate)
VolDown the Volume-\/ button
Vol- the Volume-\/ button (alternate)
VolUp the Volume-/\ button
Vol+ the Volume-/\ button (alternate)
Vol the Volume-/\ button (alternate)
Info the Info/Detail button
Detail the Info/Detail button (alternate)
Visual the Visual button
NextVisual the Visual button (alternate)
Pause the >|| / Hush button
Play the >|| / Hush button (alternate)
Hush the >|| / Hush button (alternate)
of the original Kenwood Remote. Not all of the Kenwood buttons
are available here by name. For example, Hijack uses the Volume
and Track buttons of the Rio Remote (above) instead of those
from the Kenwood remote. The same applies for the number pad.
This can be fixed (in Hijack) if anybody really requires them.
NAME ACTION
AM- the AM- / REW button
FM+ the FM+ / FF button
Direct the DIRECT OK button
Star the * button
* the * button (alternate)
Radio the TUNER button
Tape the TAPE button
Auxiliary the TAPE button (alternate)
CD the CD button
Player the CD button (alternate)
CDMDCH the CD-MD CH button
DNPP the DNPP button
The last group here represents the default mappings for
the Sony RM-X4S, a wired steering-wheel remote control "stalk".
The stalk has a special SHIFT function (think "shift key" on
a computer keyboard), used to provide double meanings for each button.
SHIFT is activated by pressing in on the PRESET/DISC/VOL collar,
and then pressing any other button while SHIFT is held.
NAME ACTION
KOff the OFF button (convex circle)
KSource the SOURCE button (inset, on end of stalk)
KAtt the ATT button (concave circle, with dimple)
KFront no label (larger trapezoid)
KNext clockwise rotation of SEEK/AMS collar
KPrev anti-clockwise rotation of SEEK/AMS collar
KVolUp clockwise rotation of PRESET/DISC/VOL collar
KVolDown anti-clockwise rotation of PRESET/DISC/VOL collar
KRear no label (rear, smaller trapezoid, with dash [--])
KBottom no label (bottom, smooth rectangle)
KSOff SHIFT + the OFF button (convex circle)
KSSource SHIFT + the SOURCE button (inset, on end of stalk)
KSAtt SHIFT + the ATT button (concave circle, with dimple)
KSFront SHIFT + no label (larger trapezoid)
KSNext SHIFT + clockwise rotation of SEEK/AMS collar
KSPrev SHIFT + anti-clockwise rotation of SEEK/AMS collar
KSVolUp SHIFT + clockwise rotation of PRESET/DISC/VOL collar
KSVolDown SHIFT + anti-clockwise rotation of PRESET/DISC/VOL collar
KSRear SHIFT + no label (rear, smaller trapezoid, with dash [--])
KSBottom SHIFT + no label (bottom, smooth rectangle)
293231-hijack_buttons.txt (160 downloads)
Edited by mlord (17/01/2007 14:57)
#292448 - 17/01/2007 14:58 Re: Hijack v467 Button Names: complete list [Re: mlord]
The master copy of this file is how hosted on the Hijack site (link at top of this BBS page).
#292449 - 17/01/2007 15:25 Re: Hijack v467 Button Names: complete list [Re: mlord]
Also added to the empeg wiki hijack docs.
