#295536 - 19/03/2007 22:57 Help EMPEG has locked up and refuses to unlock.
estocks
Loc: Reading UK
Herro
When I start my EMPEG it is freezing at the point when it should begin playing the music. I cannot unfreeze it and the USB and LAN sockets are not functioning.
I have taken this log from the serial port. I can see it is not getting me to the command prompt before it freezes. It continues to echo characters to the screen but they have no effect.
Can you clever chaps tell me how to fix it please? I have searched the FAQs.
Cheers.
SW is V3.11. Audio was a .OGG.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #16 Mon Jul 25 18:54:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101510)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: WDC WD600VE-75HDT1, ATA DISK drive
hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e
6
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 587:empeg-car 3.00-al
pha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#295537 - 19/03/2007 23:14 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
Hit Control^C on the serial port after the log you posted appears.
#295538 - 20/03/2007 00:04 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
As Mark said, ctrl-C or ctrl-break at some point during the boot sequence will drop it to the shell prompt before it tries to play the bad track.
The one you're looking for, and the thing that Mark is suspecting (and I am too) is this problem.
See if that fixes it for you.
#295539 - 20/03/2007 22:47 Re: Help EMPEG has locked up and refuses to unlock. [Re: tfabris]
estocks
Loc: Reading UK
OK here is my log of pressing Control C, sorry!
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005000).
6
Partition check:
Freeing unused kernel memory: 4k initPlayer received SIGINT, user interruption
cStarting bash.
no shell!
Shell exit
cPlayer received SIGINT, user interruption
Shell exit
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Shell exit
Shell exit
CProlux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
^HPlayer received SIGINT, user interruption
Starting bash.
no shell!
Shell exit
Starting bash.
no shell!
Shell exit
Vcb: 0x4073a000
Starting bash.
no shell!
Shell exit
Starting bash.
no shell!
Shell exit
Vcb: 0x4073a000
#295540 - 21/03/2007 10:14 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
mtempsch
Been a while since 'I read an empeg boot log, but I believe you've got the consumer version of the software loaded on the player - it doesn't provide a shell. Load the 'developer' version instead and try again!
#295541 - 21/03/2007 10:34 Re: Help EMPEG has locked up and refuses to unlock. [Re: mtempsch]
Which you can find at the Latest Software link at the top of the page. I'd recommend the v2.00 developer edition if you have an unmodified empeg.
#295542 - 21/03/2007 13:52 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
Starting bash.
no shell!
Shell exit
You definitely have the consumer version of the firmware installed. You can't fix the problem unless you install the developer version of the firmware.
Remember above, where I said...
... Well, that link I gave is very specific on that point: you need the developer firmware installed to fix it. Please follow the steps at that link carefully.
#295543 - 21/03/2007 15:21 Re: Help EMPEG has locked up and refuses to unlock. [Re: tfabris]
Tony, you might want to correct the "Hypterterminal" typo at that link.
#295544 - 21/03/2007 15:46 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
dr_dos
Loc: Bendorf, Germany
What also should help is hitting the "forward" button during the boot process repeatedly until it skips the song that locks up the player. I had the same problem recently and it worked for me.
#295545 - 21/03/2007 15:49 Re: Help EMPEG has locked up and refuses to unlock. [Re: dr_dos]
Yeah. Happens to me about once a month. I've learned how to skip it on bootup so it's not a big deal any more.
#295546 - 21/03/2007 16:10 Re: Help EMPEG has locked up and refuses to unlock. [Re: Roger]
Gah. Done.
#295547 - 21/03/2007 21:05 Re: Help EMPEG has locked up and refuses to unlock. [Re: estocks]
n2toh
Loc: New Jersey, United States
My Empeg also locks up when displaying the birth days.
I'm running v3.00 A11.
The only difference between science fiction and reality is about 60 years.
100GB MK2 Green 080000171 + OEM tuner
v3.00a11 hijack v450 jEmpload v70
#295548 - 23/03/2007 21:45 Re: Help EMPEG has locked up and refuses to unlock. [Re: mtempsch]
schofiel
Hey Mike. Long time no see. How's things?
#295549 - 24/03/2007 07:55 Re: Help EMPEG has locked up and refuses to unlock. [Re: schofiel]
mtempsch
Reasonably well - though it sucks still not being allowed to drive...
#295550 - 21/05/2007 21:27 Re: Help EMPEG has locked up and refuses to unlock. [Re: mtempsch]
schofiel
I am sure Anita will be only to happy to sort that out for you
