#301858 - 03/09/2007 18:50 Display extender install - 1st steps...
So, as phase 1 of getting the display extended empeg installed I need a remote phono switch....
(Phase 0 was a success )
I'll have a two stereo pairs of phono signals in the boot (trunk), 1 from the empeg, 1 from the onboard hifi; I'd like to select which pair goes to the amp.
Rather than route them to the cabin and then switch them and route the signal back to the boot (too much chance of interference and too bulky), I'd like to install a switch in the cabin that operates an electronic switch in the boot.
It doesn't need soft-switching or anything - I'll turn the amp down when I switch to avoid pops. Anyway, it'll be discarded in phase 3 or 4.
Any suggestions?
I'm low-level competent with a soldering iron and understand simple circuits (no problems building IR transmitters/receivers - no clue how to design one ) so I'd be more than happy to buy parts and make something up on some stripboard...
PS when I say 'goes to the amp'... The Jag has a complex amp that takes an encoded audio signal and decodes it - I need to tap into the pcb somewhere and take a line-level feed; this will then go to the switch and be replaced by the empeg signal.
In a future phase, this signal will go to the empeg as an aux with a vox switch as per here.
I'll then replace the OEM amplification/speakers with something nicer...
#301859 - 18/09/2007 01:59 Re: Display extender install - 1st steps... [Re: LittleBlueThing]
FireFox31
Loc: East Coast, USA
You could try my favorite, the PIE MPSS-4 source switching relay. It switches not with a button, but based on which device is sending audio.
Two of my installs use it this way:
- The empeg is powered on all the time.
- When the empeg plays, its audio goes to the amp.
- When the empeg is in standby, the radio/CD player turns on and sends audio to the amp.
- Whenever a button is pressed on the empeg to wake it from standby, the radio/CD is turned off instantly and the empeg has control of the amp again.
If you can find an amp turn on lead on the stock radio, than this will work even better. If not, the amp will be on all the time, which may cause pops.
I'm having a bit of trouble with two MPSS-4's I bought recently. I'm working with tech support to resolve it. If you'd like to try one, I've got an extra and could sell it to you.
FireFox31
#301860 - 18/09/2007 04:58 Re: Display extender install - 1st steps... [Re: FireFox31]
mtempsch
Really? My understanding of it is that it is controlled by 2 12V inputs typically connected to the head units remote wires,
with one of the inputs having priority if both inputs are active. Regardless of any unit actually sending audio.
(Which looks to be just what you describe later on) For manual control, just wire the control leads to a switch/switches instead.
There are circuits that will switch due to actual audio signal, located one for a guy on another forum some years ago for
getting GPS voice prompts over the main speakers. Downside is that it takes a fraction of a second to react
and switch over, but that was OK in his case as the prompts started off with an 'attention signal'.
IIRC it was a commercial 'assemble-it-yourself' kit. VOX source switch into google ought to bring up something...
#301861 - 02/10/2007 22:31 Re: Display extender install - 1st steps... [Re: mtempsch]
FireFox31
I seem to think the switch is not controlled by the amp remote wires, rather that IT controls them. Since it doesn't rely on the 12V remote wires, at least one of the sources can simply not have a remote wire; hence my iPod switching install.
I don't know, though, maybe you're right. Either way, turn off one source and the other turns on. Works like a champ (unless it's improperly manufactured like two I bought recently).
Good to see you again Mike. I'm finally finishing the iPod install which you gave me electrical information for a while ago!
FireFox31
#301862 - 03/10/2007 18:08 Re: Display extender install - 1st steps... [Re: FireFox31]
mtempsch
Glad to hear it's coming together - though I have no recollection at all what the issue was :-)
Remotes controlling it or the other way around - a matter of perspective I guess, and exactly how you use/wire the switch. I see what you mean though.
But I'm a little surprised that you seem to get a remote out signal even if no remote in is active (I thought the switch effectively OR'ed the remotes from the 2 units together. IE active only if one or both inputs were active...) Or is the non-empeg remote input somehow wired to the iPod or to some other source for 12V? Or is the amp controlled totally independently?
#305515 - 28/12/2007 14:56 Re: Display extender install - 1st steps... [Re: mtempsch]
I had a look at these suggestions - thanks guys \:\)
I couldn't find anything similar in the UK so after some digging I remembered about latching relays so I've decided to either go down that route or just use the remote-amp-on wire with a vanilla relay to select the audio source - simple really (and to be honest, probably the kind of approach/idea I was after).
I finally got round to removing the OEM kit from the boot/trunk today and I have Empeg sound coming from the speakers - good start \:\)
The next thing I need to do is actually mount the display extender itself. Has anyone else done this yet?
#305551 - 29/12/2007 14:13 Re: Display extender install - 1st steps... [Re: LittleBlueThing]
FireFox31
I'm waiting to follow your lead (once I get the same car in 2011 or so). Good luck.
FireFox31
#305613 - 31/12/2007 10:58 Re: Display extender install - 1st steps... [Re: FireFox31]
Well, here's the install in the boot:
There is an empeg there... see:
And there was some install work too:
No display yet smile
Edited by LittleBlueThing (31/12/2007 11:05)
Edit Reason: added images inline
#306967 - 06/02/2008 19:54 Re: Display extender install - 1st steps... [Re: LittleBlueThing]
So the ribbon cable is now installed and the end pieces need crimping on.
Is this easy? It looks like the crimps just need a straight clamping force. Would I get away with just aligning the ribbon and using a G-clamp?
#306979 - 06/02/2008 23:02 Re: Display extender install - 1st steps... [Re: LittleBlueThing]
Or a vice is better... If you use a G clamp, use some pieces of wood or similar to spread the force all the way across the connector. If you try and clamp one end or the middle, you'll break it.
#307026 - 08/02/2008 00:31 Re: Display extender install - 1st steps... [Re: Shonky]
FireFox31
Do you plan to make the face removable as a theft deterrent?
FireFox31
#307064 - 08/02/2008 21:39 Re: Display extender install - 1st steps... [Re: FireFox31]
No. Three reasons: 1. No-one is going to make the decision to break in to this car based on the presence of an empeg. In fact it's likely to be a deterrent wink
2. It's just not going to be practical - and that probably goes for anyone doing an extender install.
3. You probably can't see it from outside anyway.
I've actually been working on the mount tonight - piccies tomorrow I hope.
#307082 - 09/02/2008 14:34 Display extender - DONE! [Re: LittleBlueThing]
Well, it's done smile
It was quite scary but really not that hard.
Description: These relays switch between Empeg and CD when the Empeg is powered.
Description: I needed some thin steel for a bracket...
Description: So mark it out
#307084 - 09/02/2008 14:36 Re: Display extender - DONE! [Re: LittleBlueThing]
It needed a bracket to mount it...
Description: and then hack...
Description: make sure it looks OK
Description: and doesn't foul the buttons
#307085 - 09/02/2008 14:38 Re: Display extender - DONE! [Re: LittleBlueThing]
so here's one I made last night,
Description: test assemble
Description: some nibbling later and then with filter
#307087 - 09/02/2008 14:40 Re: Display extender - DONE! [Re: LittleBlueThing]
This morning I walked outside with a Stanley knife in my hands to cut this...
I swear my hands were trembling.
Description: The victim - little does she know...
Description: That's the spot...
Description: That was permanent marker pen.
#307088 - 09/02/2008 14:42 Re: Display extender - DONE! [Re: LittleBlueThing]
Getting down to it
Description: I did ask if a G-clamp would work. It did!
Description: Thank god there *was* room behind there after all.
Description: Hmm, not quite right
#307089 - 09/02/2008 14:44 Re: Display extender - DONE! [Re: LittleBlueThing]
That's better
Description: The bracket goes in the hole.
Description: boot cable is attached.
Description: AND WE HAVE EMPEG GOODNESS!!!
#307090 - 09/02/2008 14:48 Re: Display extender - DONE! [Re: LittleBlueThing]
I swear the Empeg was set on random play. However I think I'll call this the "married bliss playlist"...
Description: Those tags need to go - but it could look quite good like this... if the buttons didn't keep falling off. At this point we had to drive 30 miles to get the headlamp replaced - good test - and Denise caught the buttons every time we went over a bump :)
Description: when we got home I was actually thinking at this point that I might NOT have made a dreadful mistake :D
Description: So the trimmed filter fits in well
#307091 - 09/02/2008 14:50 Re: Display extender - DONE! [Re: LittleBlueThing]
and finally - it was done...
Description: From the passenger side, powered off.
Description: Head on
Description: and a close up. It really does look quite neat :)
#307092 - 09/02/2008 14:53 Re: Display extender - DONE! [Re: LittleBlueThing]
A *final* shot from the drivers side.
I'm really pleased with it - all the OEM sound works perfectly of course; the empeg is just spliced into the AI-Net for the OEM Alpine head unit/amp.
Sound quality is OK but not mind blowing. I think I'll look at replacing the speakers next...
Mainly we're delighted to have the Empeg back again smile
Description: In context
#307095 - 09/02/2008 15:00 Re: Display extender - DONE! [Re: LittleBlueThing]
I thought they got rid of the J-gate shifter.
#307105 - 09/02/2008 21:16 Re: Display extender - DONE! [Re: LittleBlueThing]
Looks great!
How is it at night?
(Handy thing, that dimmer feature)
Edited by mlord (09/02/2008 21:17)
#307106 - 09/02/2008 21:21 Re: Display extender - DONE! [Re: mlord]
Wow - I'd have been nervous cutting that too. You must be very happy it all worked and came out looking excellent.
#307112 - 09/02/2008 23:18 Re: Display extender - DONE! [Re: frog51]
Just with the crimp connector: there should have been 3 parts to it. The third is a strain relief. You double back the cable and clip it on. Not explicitly necessary and in this situation probably OK to go without it since there shouldn't be anything tugging on the cable. Just an FYI.
Nice install. I must admit I thought that the first few images with permanent marker and the hole looked a bit rough and ready. End result is nice though. How is it to keep having to look up?
#307119 - 10/02/2008 06:07 Re: Display extender - DONE! [Re: Shonky]
Scary!
But it looks so nice up there, good job with that. Love the fact that you can prod the buttons on the headlining, the action just instantly makes me think of a aircraft pilot.
Just brilliant. Well done!
#307124 - 10/02/2008 13:14 Re: Display extender - DONE! [Re: frog51]
Eventually - this was probably the very last model to have them. The next year's XK/R was the new shape.
Looks great!
How is it at night?
Thanks...
Found out last night - it's *BRIGHT*.
It's high enough not to distract though.
I hadn't originally planned on wiring up the dimmer sensor - I will though.
Oh yes - I was really worried it'd look rough. Especially the shape without the handle. It looks nice though - I think that because we know the handle should be there it looks a touch odd - but I'll ask people who have no idea why it's T-shaped and see what they think.
Don't recall seeing a strain relief in the box/bag or on the short 'just so I know it works' run provided - the boot end comes on and off when the unit comes in and although it has lots of slack it may benefit. The main unit has no strain at all.
I tidied the edges and the hole up before finishing - the headlining is actually thin fibreglass sheet, 2mm brittle foam, another thin fibreglass sheet, 1mm soft foam and then the fluffy liner. I had to trim the fg sheets a few mm in from the fluffy liner to allow extra material for the edge. Then I dug out the static foam for a few mm to allow the headlining to compress nicely. I already had plenty of photos and I doubt anyone else is nuts enough to install a display extender in the exact same car so you didn't see that bit smile
Looking up is odd - but OTOH I won't be having glare issues!
Originally Posted By: sein
Scary!
Cheers mate smile
It does indeed feel very aircraft like - and you (or the passenger) needs a steady hand to press the buttons on the move.
It's very solid though.You need to come for a quick flight to see for yourself wink
#307326 - 16/02/2008 13:51 Re: Display extender - DONE! [Re: LittleBlueThing]
FireFox31
That install is purely surreal! Who would ever imagine an empeg sticking out of the roof! Great pictures.
So, you ran the display cable from the boot in the headliner??
FireFox31
#307339 - 16/02/2008 20:03 Re: Display extender - DONE! [Re: FireFox31]
Thanks - it is different. All the work everyone put into those extenders - it's just great.
Yes - we'd just got a rather large bill for new tyres and a new headlamp glass so the garage ran the cable for free whilst it was in there. I was looking forward to doing it myself but the headlining is easy to damage apparently so I took the freebie wink
#311641 - 29/06/2008 00:41 Re: Display extender - DONE! [Re: LittleBlueThing]
caseyse
Loc: CA, USA
Thank you for posting your project. It looks great! It has given me the motivation to start my display extender installation. I'll be stuffing mine (somewhere) into a gen-IV Viper. I have a free year of Sirius satellite radio that doesn't come close to my Empeg. I'll get something posted when done.
#311857 - 07/07/2008 14:33 Re: Display extender - DONE! [Re: caseyse]
Just wanted to say I was so impressed seeing this in person. Very cool hack.
