#307802 - 02/03/2008 12:38 cant connect to emplode
K.A.W
HI
Have som trouble connecting to emplode. serail port and ethernet wount work.the player is a mk2 running 2.0 hijack.
I have emplode 2.0.
Her is what i got out of HyperTerminal.
If there is anyone present who wants to upgrade the flash, let
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 7, serial number
Command line: mem=12m
Memory: 10960k/12M available (976k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bhas
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Forced DC/Car mode
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg audio-in initialised, CS4231A
empeg state support initialised 0089/88c1 (save to d0005500).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N030ATDA04-0, ATA DISK drive
hdb: IBM-DARA-218000, ATA DISK drive
hda: IC25N030ATDA04-0, 28615MB w/1806kB Cache, CHS=58140/16/63
hdb: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:d
f
Partition check:
EXT2-fs warning: checktime reached, running e2fsck is recom
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
hijack: removed menu entry: "Tuner RDS Control"
q
e000 v1.04
Copying kernel...
l.
empeg-car player (hardware revision 7, serial number 80000223)
Forced DC/Car mode
empeg state support initialised 0089/88c1 (save to d0005580).
f
Partition check:
empeg-pump v0.03 (
Mounting proc
Starting player
0000 empeg-car board test version 0.04 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IC25N030ATDA04-0
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 38
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
This tells me nothing.
Hope some of you know what i have to do.
#307805 - 02/03/2008 14:10 Re: cant connect to emplode [Re: K.A.W]
Well, nothing looks wrong with the empeg, so you'll have to elaborate on your software problems, and perhaps someone else here can help with those.
cheers
#307807 - 02/03/2008 15:40 Re: cant connect to emplode [Re: K.A.W]
Since you can get a good serial boot log from the player, I'm surprised to see that you can't get emplode to connect with serial.
If ethernet won't connect, try the troubleshooting steps here.
What are the exact steps of the problem? Please describe in detail how the player is plugged in, exactly what you are clicking on, and precisely what error messages are appearing on the screen when you do.
#307809 - 02/03/2008 19:16 Re: cant connect to emplode [Re: tfabris]
K.A.W
I have 2 players.One riocar that is working fine whit ethernet and wount connect whit serial port.It run 2.0 13 beta.
The ethernet cabel is connectet through a hub.
I have tryed the players on a diffrent computer whit the same result.
Its nothing wrong whit the serial cabel.tryed it on another riocar.
The serial cabel is connected in the back of the player and in to the computer.
The other one is a empeg whit 2.0 hijack and wount connect at all.
I dont get any error messages it`s just searching when i try to connect whit emplode.
#307847 - 03/03/2008 19:41 Re: cant connect to emplode [Re: K.A.W]
Can you ping the empeg from your computer?
-get the empeg's IP address from the ABOUT screen
