#316389 - 15/11/2008 00:19 Troubleshooting without a display
NormAbram
Hi everyone,
I'm hoping that someone can help me solve my empeg woes and bring some life back into my commute. My empeg suffered a fall some months ago which broke the VFD fill nipple. The unit was still in good working order without a display until recently, and now it powers up for a short time, then shuts down. Before it shuts down the front panel LED is steady on for 10 seconds and the drives spin for 20 seconds. After that everything is quiet and dark except for the red LED on the motherboard. The unit is a Mk2 running v2.00 and emphatic and a newish version of Hijack. Any advice on how to proceed would be appreciated. This community has already helped me through 2 repair jobs and I am very happy to see that it is still going!
Thanks,
Norm
#316391 - 15/11/2008 01:53 Re: Troubleshooting without a display [Re: NormAbram]
Serial port..
#316392 - 15/11/2008 01:55 Re: Troubleshooting without a display [Re: mlord]
Oh, and the VFD can be replaced on the displayboard if you want. Various people have spares and whatnot.
#316397 - 15/11/2008 03:03 Re: Troubleshooting without a display [Re: mlord]
Couldn't you see what the screen was trying to say via weblite?
I guess a boot log would be the first thing to check, though.
#316495 - 18/11/2008 15:35 Re: Troubleshooting without a display [Re: Robotic]
NormAbram
Okay, my bootlog is as follows:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000459) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (992k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x99b78
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
hdb: IC25N040ATCS04-0, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c
b
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 74 (adjustment 10)
Vcb: 0x404ad000
Nothing jumps out at me as being strange, but I'm certainly not an expert on this sort of thing.
Also, while I was messing around I discovered that through Hijack's web interface, I can stream files off of the player, but I can't get the unit to actually play anything. (not in the car or plugged into my home stereo)
-Norm
#316496 - 18/11/2008 16:55 Re: Troubleshooting without a display [Re: NormAbram]
Since you have Hijack installed, it means you can run this.
Try it out and let's see what you get.
#316509 - 18/11/2008 19:54 Re: Troubleshooting without a display [Re: tfabris]
How is that different to weblite?
Sorry- no empeg here to poke around and figure things out. Just a quick question.
#316512 - 18/11/2008 20:57 Re: Troubleshooting without a display [Re: Robotic]
It's got a faster refresh time than weblite. :-)
#316514 - 18/11/2008 22:36 Re: Troubleshooting without a display [Re: Robotic]
It's uni-platform, so it works only for some people rather than for all of us.
#316515 - 18/11/2008 22:37 Re: Troubleshooting without a display [Re: NormAbram]
Are you sure the unit isn't simply in standby mode? Tap the top button on the front once after it finishes powering-up.
#316520 - 19/11/2008 11:46 Re: Troubleshooting without a display [Re: mlord]
NormAbram
It's working again! When I went to bed yesterday after installing weblite and trying to use it, the front panel was still dark and the weblite display was showing no activity. I was frustrated with it and went to bed, forgetting to unplug the empeg. When I woke up, the front panel LED was steady on, so I decided to give it another go. I tried to start a playlist through weblite and got the visuals to start on the weblite display. I moved the router to the next room so I could try the empeg on my stereo while it was still on the network. It was sweet music to my ears, literally. I've already tried it in my truck and it seems to be working perfectly. Thank you everyone for your help!
Thanks,
Norm
#316521 - 19/11/2008 11:48 Re: Troubleshooting without a display [Re: mlord]
NormAbram
I would be very interested in obtaining one of these. Anyone who has one please let me know what you want for it.
#316522 - 19/11/2008 13:43 Re: Troubleshooting without a display [Re: NormAbram]
Yay! Glad it worked out.
