#316767 - 29/11/2008 00:41 Another Hard Drive Not Found
Joe Gorman
Loc: Oak Hill, WV, USA
Hello,
My empeg hard drive went missing on my birthday, and I suspect it's due to a bad IDE cable (problem was intermittent, then I recrimped it; problem is now permanent). Without knowing what to look for, it was hard to do a search for similar boot logs. Hopefully there will be some obvious clues here:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 30102965)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:9
5
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
Thanks in advance,
-Joe Gorman
joe.madpj7@gmail.com
#316791 - 30/11/2008 05:25 Re: Another Hard Drive Not Found [Re: Joe Gorman]
It's clearly one of the things listed in the usual place.
- It's not the cable crimp, you did that.
- It's not the CS4231A chip, the boot log looks fine in that area.
It's not finding the hard disk at all, so it's got to be one of the other things in that list.
If you had a version of Hijack installed, we might be able to get a little more data about why it's not finding the hard disk. Hijack prints out some extra hard-disk debugging information to the serial console at boot time. But my money is on IDE header solder joints.
