#318928 - 08/02/2009 21:26 Visual Autochange bug
Dviant
So apparently I have the rare Visual auto change bug (Visuals change with track despite settings). I don't exactly know when I picked up this bug as I haven't really done anything but sync the device in several years. I just never noticed till I recently changed vehicles and its new install location is much more visible.
Currently running 2.01 dev. No Hijack currently but upgraded to v508 before I reflashed to try to get rid of it. I don't *think* have I ever installed anything beta (been a while, but I'm not the type - I like things to just work), I didn't even start to run Hijack till late in the game.
There isn't too much posted on the forum, found a couple threads but they aren't too helpful. Its a rare bug. Lucky me. whistle
Any thoughts of what to do about it? I know just re-flashing doesn't work.
#318936 - 09/02/2009 13:07 Re: Visual Autochange bug [Re: Dviant]
Strange, I've never heard of this bug before.
One way to tackle it might be to just clear the flash savearea, but first I'd like to see if anyone else here knows (more) about it.
#318941 - 09/02/2009 15:04 Re: Visual Autochange bug [Re: mlord]
Dviant
Guess that's why I only found a few posts on it smile One 5 years old several others 7.
#1. With 2.00b11 though
#2. Version unlisted.
These seem to describe the problem I was having. I don't think I ever installed a beta though, Ive been running 2.01 for years (and I have likely had the bug just as long).
#318951 - 09/02/2009 18:13 Re: Visual Autochange bug [Re: Dviant]
Just out of curiosity, does your player currently have a problem with an exessively large config.ini file?
#318961 - 09/02/2009 19:02 Re: Visual Autochange bug [Re: mlord]
Here. Install this special hijack kernel, boot once or twice with it, verify that the visuals now behave (without rebooting), and then re-install a regular (hijack) kernel over top of it again (regardless).
Totally untested, of course. smile
Edited by mlord (09/02/2009 19:03)
#319001 - 10/02/2009 01:38 Re: Visual Autochange bug [Re: tfabris]
Dviant
Re: Excessive Config.ini: It shouldn't but I'll look into it while I still have the "ancient" pc out of storage for serial port access.
Re: Special Hijack: I'll see what happens and post back. Can't do any permanent damage. Thanks!
Edit: Well, I underestimated how ancient my old PC was. Upon start up into win2k I heard the familiar sound of a hard disk trying to die "Spin up, click, spin, click, spin". Luckily it was only the storage drive. The old IBM 75GXP finally bit the dust.
Edited by Dviant (10/02/2009 02:41)
#319003 - 10/02/2009 02:37 Re: Visual Autochange bug [Re: Dviant]
Dviant
Took a peek at the Config.ini using Emplode. It looks pretty standard. Least not random ranges of garbled characters described in the FAQ.
#319005 - 10/02/2009 02:54 Re: Visual Autochange bug [Re: mlord]
Dviant
Hmmm... used Logoedit to upload the special hijack. The player does not boot with it though. When I put power to it the power light flashes once, goes off, and then it just hangs and is unresponsive.
I guess we can safely say the test was a failure smile
But for posterity here is the Hyperterminal readout after applying the "special" Hijack version:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #20 Tue Jul 6 15:36:06 BST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101954)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHT2080AT, ATA DISK drive
hda: FUJITSU MHT2080AT, 76319MB w/8192kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:a
2
Partition check:
empeg-pump v0.03 (19980601)
change_root: old root has d_countTrying to unmount old root ... okay
Mounting proc
No secondary hard disk
Starting player
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #5 Mon Feb 9 16:01:25 EST 2009
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101954) 16MB DRAM
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
show_message("ffff.-1 sigkill err")
Unable to handle kernel NULL pointer dereference at virtual address 00000000
memmap = C0004000, pgd = c0004000
*pgd = c0133801, *pmd = c0133801, *pte = c000000b, *ppte = c000000a
Internal error: Oops: 0
CPU: 0
pc : [<c00bb28c>] lr : [<c00bb094>]
sp : c0003dec ip : c0111a30 fp : c0003e14
r10: c00fa74c r9 : 00000000 r8 : c010dc28
r7 : c010dc34 r6 : 0000ffff r5 : 00000000 r4 : d0004280
r3 : 00000000 r2 : c01233a4 r1 : c010dc34 r0 : c0126208
Flags: nzCv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c0003000)
Stack:
c0003dc0: c00bb0
94
c0003de0: c00bb28c 20000093 ffffffff d0004280 00000005 c0003ea0 c010dc34 c010dc
28
c0003e00: c010dc38 c00fa74c c0003e48 c0003e18 c00bb094 c00bb250 c0016314 000000
00
c0003e20: c012fff0 c0003ea0 00000001 c010c790 c0126714 00000000 c0003e80 c0003e
7c
c0003e40: c0003e4c c00c9154 c00bb020 c0003eac 00000000 c0112eb8 c0003e80 000000
01
c0003e60: c010c790 c0126714 4401a11b c0008580 c0003f34 c0003e80 c00c977c c00c91
2c
c0003e80: fa050000 c0003ef4 00000001 c001994c 60000013 ffffffff 00000001 c0003f
24
c0003ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000
00
c0003ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000
00
c0003ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000
00
c0003f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000
00
c0003f20: 206f6972 c010dcc8 c0003f58 c0003f38 c00bc63c c00c972c 0000006f 000000
20
c0003f40: fe100000 fe100020 c01233e8 c0003f74 c0003f5c c00bd060 c00bc550 000000
01
c0003f60: c0104768 c0125a5c c0003f84 c0003f78 c00b0ef8 c00bcf04 c0003f94 c0003f
88
c0003f80: c00a1440 c00b0ec4 c0003fb4 c0003f98 c0046c58 c00a143c 00000001 c01047
68
c0003fa0: c0125a5c c010c790 c0003fdc c0003fb8 c0009ab8 c0046c54 00000000 c0009b
8c
c0003fc0: c012f9dc c0104760 c0104764 c0104988 c0003ffc c0003fe0 c0009b9c c00099
c0
c0003fe0: c0009b8c c012f9dc c0104760 c0104764 c0103fd8 c0004000 c000b6ec c0009b
98
Backtrace:
Function entered at [<c00bb244>] from [<c00bb094>]
r10 = C00FA74C r9 = C010DC38 r8 = C010DC28 r7 = C010DC34
r6 = C0003EA0 r5 = 00000005 r4 = D0004280
Function entered at [<c00bb014>] from [<c00c9154>]
r10 = C0003E80 r9 = 00000000 r8 = C0126714 r7 = C010C790
r6 = 00000001 r5 = C0003EA0 r4 = C012FFF0
Function entered at [<c00c9120>] from [<c00c977c>]
r10 = C0008580 r9 = 4401A11B r8 = C0126714 r7 = C010C790
r6 = 00000001 r5 = C0003E80 r4 = C0112EB8
Function entered at [<c00c9720>] from [<c00bc63c>]
r5 = C010DCC8 r4 = 206F6972
Function entered at [<c00bc544>] from [<c00bd060>]
r6 = C01233E8 r5 = FE100020 r4 = FE100000
Function entered at [<c00bcef8>] from [<c00b0ef8>]
r6 = C0125A5C r5 = C0104768 r4 = 00000001
Function entered at [<c00b0eb8>] from [<c00a1440>]
Function entered at [<c00a1430>] from [<c0046c58>]
Function entered at [<c0046c48>] from [<c0009ab8>]
r7 = C010C790 r6 = C0125A5C r5 = C0104768 r4 = 00000001
Function entered at [<c00099b4>] from [<c0009b9c>]
r8 = C0104988 r7 = C0104764 r6 = C0104760 r5 = C012F9DC
r4 = C0009B8C
Function entered at [<c0009b8c>] from [<c000b6ec>]
r7 = C0104764 r6 = C0104760 r5 = C012F9DC r4 = C0009B8C
Function entered at [<c00096c4>] from [<c00098b0>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0125F30 r6 = C0125E84 r5 = C0130430 r4 = C0130430
Code: e5925000 e5903000 (e5853000) e5902000 e59f01b8
e000 v1.04
Copying kernel...
l.
CPU: 0
Stack:
c0003dc0: c00bb0
94
28
00
7c
01
2c
24
00
00
00
00
20
01
88
68
8c
c0
98
Backtrace:
r4 = C0009B8C
Edited by Dviant (10/02/2009 03:29)
#319016 - 10/02/2009 12:10 Re: Visual Autochange bug [Re: Dviant]
Ouch.. I guess the flash driver doesn't appreciate the beauty of recursion. smile
Okay, try this one instead.
Slightly different procedure required:
1. flash the new kernel.
2. boot with it.
3. suspend the player (push top button until it goes to sleep).
4. wake it up again after a few seconds.
5. wait until the disk stops spinning.
6. power it off.
7. flash a normal kernel again.
Any luck?
#319039 - 10/02/2009 19:13 Re: Visual Autochange bug [Re: mlord]
Dviant
YES! That one worked beautifully. Everything now seems to be working as is should.
Upon booting with the second flash immediately upon reboot a message saying "Settings Lost" appeared. But it proceeded to boot up and act like it should.
Awesome! Thank you very much!
#319073 - 11/02/2009 01:29 Re: Visual Autochange bug [Re: Dviant]
Super. And of course I completely forgot to get a savearea dump before we fixed it -- could have been useful in having Hijack automatically detect/fix this kind of thing in the future.
Silly me. smile
Actually, the old (bad) settings are probably still in flash (it takes 32 suspend/poweroff cycles on average before they get wiped). But it's not really worth the fuss.
The visual autorepeat settings are saved as a bunch of 2-bit bitfields in the flash, and I suspect accidental sign-extension is happening to one of them when the field next door isn't all zeros. Or something like that.
#319089 - 11/02/2009 12:24 Re: Visual Autochange bug [Re: mlord]
Dviant
Well, hindsight IS 20/20. Hopefully I won't, but if I see this problem again I'll post back. Somehow I doubt it as evidenced by the few are far between posts on the problem.
#323920 - 02/07/2009 18:52 Re: Visual Autochange bug [Re: Dviant]
Coyttl
Hey all. New here and I hate to revive an old thread, but..
I have this issue as well (for the last year or so!) figured I would finally see if there was a fix. I was going to apply Mark's kernel, but before I did wondered if anyone still cared to get an image of my flash area. (I doubt it, since development seems to have been stopp? That's a shame. frown - But I thought I'd ask.)
Cheers all,
Mike.
#323921 - 02/07/2009 19:10 Re: Visual Autochange bug [Re: Coyttl]
Naw, just nuke it. smile
#323922 - 02/07/2009 19:47 Re: Visual Autochange bug [Re: mlord]
Coyttl
Okay, done. (Or doing.. It seems that Vista x64 is not a happy camper with COM port and the upload utility. Grr.)
Thanks. laugh
