#324828 - 01/08/2009 18:15 "Checking Media" when synching
Yeah, the usual thing -- computer locked up during synch, had to kill Emplode, now it does the Checking Media thing every time I try anther synch. With two 80GB drives, this is rather time consuming.
I did the manual fix as described in the FAQ:
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
but it apparently failed with an error message. I have attached the Hyperterminal log.
I rebooted the empeg, it started up normally, I started Emplode, and it started up normally so I figured I was home free. But when I did a synch, it did the "Checking Disc Integrity" thing for about 90 minutes before successfully completing the operation. That's where I am now, Emplode is still up and connected, and I don't want to shut it down in case there is something I should do while it is still running.
What should my next step be?
hyperterm out.doc (411 downloads)
#324830 - 01/08/2009 19:28 Re: "Checking Media" when synching [Re: tanstaafl.]
Post the log again as a text file.
#324833 - 01/08/2009 21:40 Re: "Checking Media" when synching [Re: wfaulk]
TextEdit opened it fine:
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon swapfile
swapon: cannot stat swapfile: No such file or directory
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1515/4096 files (0.5% non-contiguous), 9458/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
no room for private writable mapping
error: -12
fsck.ext2: Memory allocation failed while retrying to read bitmaps for /dev/hda4
empeg:/empeg/bin#
#324834 - 01/08/2009 22:07 Re: "Checking Media" when synching [Re: drakino]
swapon /swapfile
not "swapon swapfile"; the missing "/" did you in there.
#324839 - 02/08/2009 15:19 Re: "Checking Media" when synching [Re: peter]
swapon /swapfile
Oh, picky, picky, picky! Why can't my computer do what I want it to do instead of what I tell it to do? smile
I re-ran the process (this time with all the commands spelled correctly) and it almost was completely successful.
When I did my Emplode synchronization, everything went normally right up to the end, in the "Restarting Player" phase. It hung there, with Emplode saying "Waiting". I still had hyperterminal running, and it showed "Fan Controller Error" (I have the optional fan installed in my player), which is something I see occasionally on the player's display. I am going to assume that this was a one-time glitch that stopped Emplode (ignorance is bliss, right?) and pretend that everything is all right now. Hopefully the next time I synchronize with Emplode I won't find out differently.
Thanks, Peter, for the sharp-eyed help!
#324925 - 06/08/2009 16:43 Re: "Checking Media" when synching [Re: tanstaafl.]
benjammin
Loc: Champaign, IL
Fan Controller Error shouldn't stop it.
I was seeing that on my unit until I changed the resistor values and then mlord changed the timing...
Is it my fan controller you're using?
What version of hiJack are you running?
-Ben
#324940 - 06/08/2009 19:31 Re: "Checking Media" when synching [Re: benjammin]
-Ben
I didn't know there might be more than one fan controller. You'd have to ask Stu at Eutronix... he's the one who did the fan installation for me.
My version of hiJack is whatever the latest version was as of last week. (It's version 508.)
I won't be doing another synchronization until next week sometime, I guess we'll find out then if all is right with the world.
#324951 - 07/08/2009 00:51 Re: "Checking Media" when synching [Re: tanstaafl.]
maczrool
Loc: Louisiana, USA
-Ben
Yep. Ben I installed one of your controllers for him back in February 2005.
Hope you've got this resolved smile .
Stu
