#325728 - 05/09/2009 22:48 Bad RAM?
FieroSTi
First power up with one of Patrick's RAM boards installed:
e000 v1.04
Copying kernel...
Calling linux kernel...
(undefined instruction vector)
Second power up, going through the RAM test:
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
0101 memory error at c0000000 (00000000!=00000000)
01f0 ram test done
0200 ide detect
0210 command issued
0212 drq=1 but irq=0 (no drive connected?)
...and finally, after going through all of my solder joints, carefully double-checking everything and re-flowing a few possibly questionable joints:
Here's my question...did I bugger anything up permanently, or do I just need to go over my solder joints again? Just thought I'd ask to see if anybody knew right off the top of their head what I'm up against. Just as an fyi, the unit is a MKIIa that was in sad shape when I found it at an estate sale (believe it or not). Had a fried CS4231A, broken fill nipple on the VFD, and a bad rotary encoder. Fixed all of that save for the CS4231A, so I was just hoping you guys could help me resurrect it fully. I haven't booted it up yet (because it won't, haha) so I honestly don't even know if everything else functions. I'd like to find out, though with my luck I'd get it booted up only to find a fried DSP chip too.
Edited by FieroSTi (05/09/2009 23:23)
#325729 - 05/09/2009 22:53 Re: Bad RAM? [Re: FieroSTi]
FieroSTi
Meh, wasn't careful enough...I found a few more bad joints. I'll fix them and report back.
#325730 - 05/09/2009 23:26 Re: Bad RAM? [Re: FieroSTi]
FieroSTi
I need to get a filter on that brain-to-mouth thing. I rescued it. And good news, it works fine! Just needed a new display board and hard disk. I've seen Mark Lord's CS4231A resurrection, so maybe I'll try that when I get a little more brave. I honestly don't use the visuals, so I probably won't ever bother, haha.
#325731 - 06/09/2009 00:33 Re: Bad RAM? [Re: FieroSTi]
Come on.. you WANT the visuals.. do it! wink
#325732 - 06/09/2009 03:59 Re: Bad RAM? [Re: mlord]
FieroSTi
Haha, well it can't be a whole bunch harder than activating the 4th bank Of RAM with the RA3 line from the StrongArm. Flancedoor entertains me, haha.
Edited by FieroSTi (06/09/2009 04:01)
