#32802 - 18/06/2001 06:12 Can't read blue screen!
Hi Guys.
I have a Mack II Blue 12Gb Player. Just Great. I've been using it for almost two months, every day, and I am absolutely happy about it. Just one problem: the BLUE screen looks GREAT, but during the day I just can't read it! Unless it's cloudy, there's almost no way to read it clearly. How can I solve this? I already have the brightness set to its maximum value. Does anybody have any solution? Also, empeg guys, my suggestion is that you make a brighter display for future versions of RIOCAR. Thank you all. Taym
#32803 - 18/06/2001 07:54 Re: Can't read blue screen! [Re: Taym]
It should be easy to read, unless the sun is shining directly onto it. Do you know anyone near you with a player for comparison?
#32804 - 18/06/2001 08:08 Re: Can't read blue screen! [Re: rob]
Unfortunately not.
Maybe it depends on the fact that on my car (VW Polo III, latest model) the empeg is pretty much exposed to the sun. However I guess several cars may have the same layout. Is there any way to increase the brightness even more?
empeg mack II blue 12Gb
#32805 - 18/06/2001 10:33 Re: Can't read blue screen! [Re: Taym]
Congrats on your new toy.
Have you checked out this FAQ entry on the subject?
#32806 - 18/06/2001 12:59 Re: Can't read blue screen! [Re: Taym]
mtempsch
Hmmm... A somewhat unrelated data point; I also have a new Polo
(00/01) and my MkI with the blue face (which, IIRC, is different than
the MkII blue), mounted in the upper slot of the double DIN opening,
was quite readable except when the sun shone right at it.
#32807 - 18/06/2001 15:19 Re: Can't read blue screen! [Re: tfabris]
I have a bit of information that might be relevant as far as the FAQ goes...
This weekend I finished my empeg installation on my bicycle (yes, really!) and it works just fine---except that the display is virtually invisible on a sunny day, whether the sun is shining on the display or not.
In my car, it is readable even when the sun shines through the rear window directly onto the display.
The difference? On my bicycle, the empeg is powered by means of a small 12-volt battery hooked to the "Home" power input on the back of the empeg -- so the empeg "thinks" it is at home, not in the car (or bicycle). And of course in the "Home" mode, there is no brightness setting. Is the display in "Home" mode significantly dimmer than the range of settings available in the "In-Car" mode?
Is it possible that the people who have problems reading their display "In-Car" on bright days have displays that are functioning in "Home" mode? I can tell you that my empeg is completely unreadable outdoors on a bright day when operating in "Home" mode, but is extremely readable in the same environment when in the "In-Car" mode.
Just a thought...
#32808 - 18/06/2001 15:45 Re: Can't read blue screen! [Re: tanstaafl.]
This is good information, if it can be verified. Is the display deliberately dimmed a little when running on the AC adaptor?
#32809 - 18/06/2001 16:41 Re: Can't read blue screen! [Re: tfabris]
Another thought: are any of the drive spin controls or the caching different for different power settings? Is there a "power saver" mode for car installations?
Paul G.
SN# 090000587 (40GB Clear)
#32810 - 18/06/2001 16:47 Re: Can't read blue screen! [Re: pgrzelak]
I'm reasonably sure that the drives and cache behave the same regardless of where the power is coming from.
To verify this yourself, you can activate the player's hard drive icon the next time you're poking around in Emplode.
#32811 - 19/06/2001 02:29 Re: Can't read blue screen! [Re: tanstaafl.]
No, the display is locked at 100% when "at home".
It may be your battery is sagging a bit under the load, though ISTR the switch-mode 60v PSU manages to keep stable down to about 8 or 9 volts.
#32812 - 19/06/2001 06:11 Re: Can't read blue screen! [Re: tfabris]
Ok. A brief update concerning this problem:
I just realized there are both AR and non-AR screens. First of all thanks to all among you who told me this. I am new in this forum, so please forgive me for not knowing previously discussed issues.
So, guess what, I found out my screen is non-AR, so I just contacted carsupport@riohome.com to order a new blue AR screen for my Mack II. As a matter of fact, what I noticed is that, although not extremely bright, the screen would still be readable during the day if not because of the reflections. So here is the first question:
1) Is there anybody in here who replaced his/her "plain" screen with a AR screen, and actually saw real improvements in the readability? I would assume so...
Second, I read the FAQ regarding this issue. Again, thank you to those who poiinted that out, I did not think about it. I made the "dim" test, as suggested, to find out whether my screen is broken or nor. Well, during a quite bright day I set the screen dim to 0 and could still read it by going very close to it. I assume this means that at night I should be able to read it without significant problems. I'll test it. However, without going very close to the screen, I would just seen few dfots here and there.
2) Does anybody confirm this is normal?
Also, I got my empeg in amber, with a blue screen as a "gift". This is because I had ordered a blue one, but they were all sold out, so empeg guys, very nice as usual, decided to give me this special treat :)
3) Is it possible that when I replaced the amber screen with this non-AR blue I made some mistake and now it is not working properly and not giving me the full, optimum brightness?
Also, in the faq it is said that " the VFD should be so bright that it hurts your eyes if you've got it at full brightness during the night. (...)" .
That is not really my case. I ALWAYS have it at full brighthness, during the night, and it is just as bright as the rest of my car intrumentation. Maybe somewhat dimmer. I have a Polo III with the new VW blue instrumentation light set at maximum, so some of you who have the same car can give me an answer. So
4) Is my screen broken?
Thank you all in advacnce. You're just great. This BBS is precious, it reminds me of the good old times when I was a Fidonet SysOp! :)
If it can help, my empeg SN is 090000923
#32813 - 19/06/2001 06:47 Re: Can't read blue screen! [Re: Taym]
fvgestel
Loc: Netherlands
I've reinstalled my green non-AR screen after driving with a blue AR screen for about 3 months. I do personally think the non-AR screen is better readable when the sun shines in directly. This is due to the fact that the AR screen diffuses the light making the entire display unreadable. A non-AR screen works like a mirror, so only a small section of display is unreadable. An AR screen also makes the display more fuzzy...
These observations are probably specific to my car; it is impossible to have the sun shine on the display and reflect the light direct into my eyes, because the empeg is mounted very low in the dash...
Frank van Gestel
Frank van Gestel
#32814 - 19/06/2001 07:54 Re: Can't read blue screen! [Re: fvgestel]
That is surprising. However my empeg is mounted very high in the dash, so the sun actually hits id directly quite often. I see that it really reflects light a lot, so I was assuming that a AR screen would work better... I don't know...
S/N: 090000923
#32815 - 19/06/2001 08:52 Re: Can't read blue screen! [Re: tfabris]
Could you please explain this better? My HDD icon (is that the one on the top right of empeg display) actually turns on when the empeg is reading from the hdd when IN THE CAR
S/N: 090000923
#32816 - 19/06/2001 09:32 Re: Can't read blue screen! [Re: Taym]
Right, that's the one. Whether or not it's activated is a setting option, you can turn it on and off from the configuration screen in Emplode. The icon shows when the unit is reading the hard disk. The icon changes depending on exactly what the hard drive is doing, there's a FAQ entry describing this as well. The icon works equally for home and car. My point was that, by looking at the icon, you should be able to notice that the disk behavior does not change between home and car.
#32817 - 19/06/2001 09:41 Re: Can't read blue screen! [Re: Taym]
This means that your display doesn't have the "known problem" where there's a blown circuit. This is both a good thing (at least it's not faulty), and a bad thing (there's no obvious reason why you shouldn't be able to read your display).
Unlikely, unless you damaged some circuitry on the display board. If you were careful, you probably didn't hurt anything.
Also, in the faq it is said that " the VFD should be so bright that it hurts your eyes if you've got it at full brightness during the night. (...)" . That is not really my case. I ALWAYS have it at full brighthness, during the night, and it is just as bright as the rest of my car intrumentation. Maybe somewhat dimmer.
Assuming you've set it to 100 percent in "lights on" mode, this surprises me. I don't own your particular kind of car, so I don't know how bright its instruments are. But in my experience, these VFD displays are distractingly bright at night. When I owned the Mk1 (before they had dimmers), my wife made me turn off the visuals and text at night because it was painfully bright. Bright enough that she would hold her hand in front of the display until I switched it off.
#32818 - 19/06/2001 14:10 Re: Can't read blue screen! [Re: Taym]
The problem with diagnosing this is that it is extremely subjective. I consider a blue empeg display (AR coated or not) easy to read on a sunny day provided the sun is not reflecting directly onto the screen. Another person, looking at the exact same setup, may have a different perception.
It doesn't sound like you have a faulty display, as those really are VERY dim - about the equivalent of 20% brightness of a normal working unit. But then, I can't rule it out either. Your comments are far from typical of most owners.
We can ship the unit back and find out instantly if it has a problem, but if it were working perfectly we would have to charge you for the carriage. It would be much better if you could see another owner's player - if anyone in Italy reads this perhaps they could make themselves known.
altman - 2:252/102
rob - 2:252/106
many years ago
#32819 - 19/06/2001 15:35 Re: Can't read blue screen! [Re: rob]
Yes, and Rob was one of the first to run my BBS software (ARM-based, naturally - and this was '88-'89) :)
#32820 - 19/06/2001 18:33 Re: Can't read blue screen! [Re: Taym]
jwickis
Loc: India
I think it really does depend on the vehicle, the mounting angle, how high it's mounted & so forth. For me the 'AR' works better since it's high it doesn't reflect everything that passes by the windows like my 'non-AR' did. If it was mounted lower like my car there's not much to reflect off of because of the seats. It seemed the 'non-AR' Blue screen was somewhat brighter than the 'AR' Green I had, especially at night, but I haven't been able to compare the same color of both types. During the day, the 'non-AR' Blue reflected more of the scenery coming thru the windows, making it hard to read not because of the brightness but from stuff constantly passing what looked like in front of it, so your eyes focus on the scenery more.
#695empeg-car Mk2GRN& a mere 12Gig
"buyers regrets,NO"
#32821 - 19/06/2001 19:55 Re: Can't read blue screen! [Re: rob]
Fidonet in 88/89? WOW That was the beginning! I knew you guys had to be in Fidonet in the past! I was 2:335/633, in Fidonet snce 1993 :) A directory with Maximus, Binkley, Squish and all the rest is still on my HDD .
Going back to empeg (no off topic posts :)) I'll test the amber screen. Maybe that's AR. Unfortunately I don't have it here, so I'll have to wait few days. Just by curiosity, is there any way to know whether the fascia shipped with a specific player is AR from the player SN (see my signature)?
It seems to me that if it wasn't for the reflections the display would be readable, so trying an AR display would definitely help to understand.
FYI, my Polo's intruments light is exactly as bright as the Beetle's, and of the same color. I assume. Still VW. Maybe this helps to give you an idea of how bright it is at night. And the blue does match almost perfectly with that of the car. My empeg at night is slightly dimmer that the instruments. I'll keep you posted.
10x again.
______________________________
empeg mk II blue 12Gb
090000923
#32822 - 19/06/2001 21:30 Re: Can't read blue screen! [Re: Taym]
Terminator
Loc: Dallas, TX
The screen that shipped with your player had an AR screen on it-based on the serial number.
Sean
#32823 - 20/06/2001 02:52 Re: Can't read blue screen! [Re: Terminator]
Actually it probably didn't have AR - very few empeg players shipped with AR screens fitted.
#32824 - 20/06/2001 02:56 Re: Can't read blue screen! [Re: altman]
Yes, and you charged me 90 quid for it *ouch* - my contribution to your MX5 I suppose
At least one ArcBBS board is still online: http://www.arcade.demon.co.uk/
#32825 - 20/06/2001 16:13 Re: Can't read blue screen! [Re: rob]
Terminator
Loc: Dallas, TX
Doh. I just made a bad assumption. Are the rios shipping without a/r on the screen? I thought that after several people complained about daytime readibility, empegs would ship with a/r screens.
Sean
#32826 - 20/06/2001 19:10 Re: Can't read blue screen! [Re: Terminator]
xanatos
Loc: Denver, CO
They do ship with A/R Screens. I can tell because mine is one ^_^
Damien Heiser
RioCar 12GB Blue SN: 120001043
- Damien - Mk2a 24G Blue SN: 120001043
#32827 - 21/06/2001 01:43 Re: Can't read blue screen! [Re: rob]
EngelenH
Loc: Belgium/Holland
2:292/113 back in 88 as well. Towering Inferno it was called, ran on everything from Frontdoor to Binkley. Huge phonebills too. But then I doubt anybody needs reminders of those.
Hans
Mk2 - Blue - 080000431
32209- (350 downloads)
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#32828 - 21/06/2001 04:17 Re: Can't read blue screen! [Re: Terminator]
All Rio players have AR screens - only the very last of the empeg players did.
#32829 - 21/06/2001 13:59 Re: Can't read blue screen! [Re: rob]
srhodes
Loc: Derbyshire, UK
My empeg came with an non-AR blue. I wanted a Green screen to try and match my car display and those kind and wonderful empeg people shipped out an AR one for free. I found that the brightness was greater on the Blue than the Green and the Green was was slightly easier to read in sunlight. It was mounted high up in a Golf dash. I have now changed my empeg into my Escort where it is mounted quite low and at a slight angle. I recently had to contact those those kind and wonderful people at empeg about my control knob and asked when the screens would be available on the site. Within 2 days I got a new control knob and an Amber display. I have found that this is not as bright as the Green screen and is difficult to read in sunlight. Not much more than the Green, actually. But, when it's sunny I tend to be wearing sunglasses and this doesn't help. I find if I peer under the glasses then I can make out the display.
I am seriously considering going back to the Blue for several reasons. First, the Amber didn't match my display as I'd hoped. Second, I don't really have any instrumentation close enough for it to make a difference and it is all a kind of off-white anyway. Third, I was recently trying all my screens in situ for a photo session to put on the web and found that I actually quite liked the Blue. Finally, my Escort is Blue.
So, after all that, what you really need is a comparison off someone who has had an AR and a non-AR of the same colour.
Steve - 18GB Mk II Amber
Steve
2x80GB Mk II with Illuminated buttons
#32830 - 26/06/2001 01:27 Re: Can't read blue screen! [Re: rob]
Wire
Loc: Jylland, Denmark
Hi SysOp-oldtimes,
FidoNet, 2:231/103. It was called Infiltrator BBS, and was quite a nusiance to the people who got my phonenumber after I moved :-)
I ran (among other things) RA, FastEcho, GoldED(betatester) on an older Commodore PC10/II.
http://www.phreak.org/archives/The_Hacker_Chronicles_II/phreak/europe.txt
Lists both mine and Hugo's "World of Cryton" (that was the one, right?).
Any other closet SysOps here?
'Tis indeed a small world.
Lars
Lars MkII 40gig 090000598
#32831 - 26/06/2001 01:57 Re: Can't read blue screen! [Re: Wire]
Ooo, freaky. Not heard that name for a long time :)
Yes, my one was TWoC (the world of cryton). "Rich in Paradise" (252/307), ran ARCbbs too...
