#36914 - 21/08/2001 14:28 help emplode not showing additional space.. >>
silvercas
here is the log showing empeg sees it
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 7, serial number 90000723)
Command line: mem=12m temp=31
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:d
3
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...t: old root has d_count=1
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
Tried to mount /proc but got error 16
No secondary hard disk
Starting player
empeg-car 1.01.
#36915 - 21/08/2001 14:38 Re: help emplode not showing additional space.. >> [Re: silvercas]
Okay, did you run the builder image on the second drive AND do a full install of 1.03 onto the second drive as described in the FAQ? And did you do at least one synch?
#36916 - 21/08/2001 14:43 Re: help emplode not showing additional space.. >> [Re: tfabris]
silvercas
ok I did the upgrade as stated in the fAq to the 2nd drive did I read wrong..then I added one file to the empeg to see if it would show and no luck.. then i just updated my emplode and my firsts drive to 1.03 builder.
#36917 - 21/08/2001 14:44 Re: help emplode not showing additional space.. >> [Re: tfabris]
silvercas
you got AOL's IM?
#36918 - 21/08/2001 14:46 Re: help emplode not showing additional space.. >> [Re: silvercas]
silvercas
ITS WORKING... I HAD TO UPGRADE MY FIRST DRIVE... YIPPIE!! THANKS FOR RESPONDING THOUGH
AHHHHH I LOVE THIS
#36919 - 21/08/2001 16:38 Re: help emplode not showing additional space.. >> [Re: silvercas]
you got AOL's IM?
Nah, I use ICQ. And lately, Trillian as an ICQ-replacement.
I do have an AOL Instant Messenger account, but for some reason, Trillian looks like it might be having trouble with it. Some of my AIM buddies do not show up even when they're online. Perhaps it's one of AOL's countermeasures to prevent third-party software from using their system.
#36920 - 21/08/2001 17:19 Re: help emplode not showing additional space.. >> [Re: tfabris]
mardibloke
Loc: Penarth, UK
Trillian works a treat for me, use it for AOL and Yahoo buddies, not using it at all for ICQ. Very handy as Trillian also starts and automagically joins me to the Empeg channel on IRC.
Rod, UK Mk2 64gig Red S/No.341 2xDell RioReceiver
Rod, UK
#36921 - 21/08/2001 17:26 Re: help emplode not showing additional space.. >> [Re: tfabris]
silvercas
thanks for responding.. next upgrade will be when these 45gb ibm drives go down to 150
