#58441 - 13/01/2002 16:42 Hijack request..
ClownBurner
Loc: Irvine, CA USA
This would be a great help to those of us who use multiple eq presets:
How about adding an "eq+" option to the popup volume-knob-push button to switch to the next eq setting?
And to make this even handier: The ability to define a 'favorite eq' list that would basically allow you to hide unused eq presets (like an option in config.ini that would let you make a list, like with visuals).
See, I've got a convertable, and with the top down, I need a lot more bass to compensate for wind noise. WIth the top up, I sound like a thumpmobile until I change eq presets, which is very laborious (down left left down right right down down down right down up...)
If this is doable, I think it'd be very useful (for me anyway)... Either way, thanks for all your hard work, ML!
_____________ James Mancini
#58442 - 14/01/2002 22:46 Re: Hijack request.. [Re: ClownBurner]
I don't think I'll get to this one very quickly, but if you haven't already used Hijack's "ir_translate" with the "shift" function, you might want to try it as a workaround.
cheers
