#68188 - 07/02/2002 10:08 IR again....
ashmoore
Loc: TX
Still harping on about IR...
Has anyone got a Philips Pronto (or any other universal remote) working with the Rio? I really don't want to add to the clutter of remotes at home.
========================== the chewtoy for the dog of Life
#68189 - 08/02/2002 09:10 Re: IR again.... [Re: ashmoore]
ClownBurner
Loc: Irvine, CA USA
I've got a Sony AV-2000 and it's programmed for the Rio, works fine. The 'HOLD BUTTON" functions don't seem to work, though, I think because the remote sends CODE-CODE-CODE-CODE instead of CO-----------------ODE when you hold the button down.
But for simple things (play, pause, skip, visual, info, etc.) it works fine in everyday use.
_____________ James Mancini
#68190 - 08/02/2002 11:57 Re: IR again.... [Re: ClownBurner]
ashmoore
Loc: TX
I am making the assumption that you had to 'teach' the Sony each of the buttons.
I don't suppose it would be high priority to build car based remotes into the transmitter code database.
#68191 - 08/02/2002 21:55 Re: IR again.... [Re: ClownBurner]
Do long presses work when Hijack is installed? It tries to "help" some remotes of that type..
#68192 - 11/02/2002 01:25 Re: IR again.... [Re: mlord]
ClownBurner
Loc: Irvine, CA USA
Didn't get a change to try it really, since I just got a new remote, the Phillips ProntoNEO. Very keen. It learned the Empeg codes easily and seems to do both short and long keypresses just fine...
