#77554 - 04/03/2002 08:19 Detail in PopUp0 shows SeekTool Info !
dda
Loc: Belgium
Detail in PopUp0 selects the Seek Tool Info and doesn't show the song details like it should do. A little bit like this symbolic name was only a short press equiv.
Does anyone have the solution ? Mark ?
DDA
#77555 - 04/03/2002 09:56 Re: Detail in PopUp0 shows SeekTool Info ! [Re: dda]
Happy Birthday tonyc
Uh... Hold the button down...
#77556 - 04/03/2002 14:12 Re: Detail in PopUp0 shows SeekTool Info ! [Re: dda]
bonzi
Yes, Info and Detail PopUpX keywords are equivalent (unlike Detail one attaches to knob press directly from Hijack menu). This was mentioned in several threads (some rather heated ones ). Just remember to hold the button.
#77557 - 04/03/2002 20:04 Re: Detail in PopUp0 shows SeekTool Info ! [Re: bonzi]
YEah, I know. I might make that more intuitive some day, but for the time being..
The IR translation layer scares me a little. It does so much, and wasn't really constructed with all of that future capability in mind. It just started out as a very simple button->button translator..
#77558 - 04/03/2002 23:34 Re: Detail in PopUp0 shows SeekTool Info ! [Re: mlord]
Yeah but it's perhaps the most powerful feature (except for the user application interfaces) in Hijack... So much customization can be done with the IR trans. Has the code just gotten out of control? Or is there some other problem with it?
If you're looking for something besides IR trans to work on (teehehehe) how about that in-place writing of data to the hard disk? Or the mmap buffer for display writes? Eh?
#77559 - 05/03/2002 01:14 Re: Detail in PopUp0 shows SeekTool Info ! [Re: mlord]
bonzi
Please do. It's not as if it were *difficult* to hold a button, but one just forgets. I will have to remove 'Details' from my popups: seeing 'Info' will, I hope, make me remember to hold it for details display...
Thanks for the feature, BTW. Makes the player *much* easier to operate while driving (although I am quite good at operating the remote blindly).
#77560 - 05/03/2002 08:27 Re: Detail in PopUp0 shows SeekTool Info ! [Re: tonyc]
The IR stuff is just so close to the hardware, timing is tight. So it cannot do too much in the button interrupt handler. So it gets offloaded to the next level, which is the display handler (also running as an interrupt handler). And by then it's too late to use certain conditionals where I'd like. And it all has to run without delaying buttons fed to the player, or the UI seems slow. But yet it still has to maintain sequence and timing of the original presses, plus translated macros, as they're fed to the player. Plus, some "buttons" pop-up menus and whatnot. Etc..
It would be easier to be fancy if I chewed up 10-20KB more memory for separate threads and fancier data structures, but I don't really want that much system loading for it..
blah blah blah blah
And the darned thing breaks so easily when any of the above considerations is forgotten..
#77561 - 05/03/2002 08:37 Re: Detail in PopUp0 shows SeekTool Info ! [Re: mlord]
Okay, then don't change a thing. It works great for me as is.
#77562 - 05/03/2002 08:42 Re: Detail in PopUp0 shows SeekTool Info ! [Re: tonyc]
Who are you, and what have you done with Tony??
#77563 - 05/03/2002 10:31 Re: Detail in PopUp0 shows SeekTool Info ! [Re: mlord]
Teeeheheehe.. No, seriously, IR trans does everything I want it to do. All I want from Hijack now is the userland interface stuff, i.e. the in-situ disk writing and mmap display buffer. The disk writing thing will allow my alarm clock app to save your alarm time, time format, etc. Right now I'm losing all that stuff on reboots. Everything else (HTTP, FTP, IR trans) are, in my mind, as good as I need them to be.
Oh, except last night my FTP client tried to make a directory and it chopped off the first character.. Like "MKD images" made a directory called "mages." This was with v228 I think. I know you fixed a problem with an initial space being added for some people, maybe the fix introduced some other bug? Anyone else who's using CuteFTP have any similar problems?
#77564 - 05/03/2002 10:48 Hijack v230: fixed MKD/RMD commands [Re: tonyc]
Oh crap. I got the conditionals backwards on that.
Fixed in v230, out shortly.
Thanks!
