#79349 - 10/03/2002 23:56
Re: The word "the"
[Re: tonyc]
My two roomates usually do "Beatles, The". I tend to do it the proper way though since the playlist menus can be sorted properly and search ignores it. They mainly had it the other away around from using other players before getting their empegs. With emplode 2.0, it's quick to change back around as well, since we archive our music with the the at the end.
#79350 - 11/03/2002 00:21
Re: The word "the"
[Re: tonyc]
Loc: Richmond, VA
I thought Emplode did this too (I could have sworn someone said it did), but jEmplode sorts "The Doors" as "Doors, The") so it would appear between B and E.
Mike
#79351 - 11/03/2002 02:06
Re: The word "the"
[Re: tonyc]
Loc: Riverside, CA
I go through and remove all the The's from the artist title, unless it's required as in the band, "The The". Also, I make sure to use the real band names vs. the "US" names (Charlatans vs. Charlatans UK, Suede vs. The London Suede and Verve vs. THE Verve).
later,
ajay
#79353 - 11/03/2002 09:14
Re: The word "the"
[Re: tonyc]
Loc: NRW, Germany
I've got the "the"s in there for "correctness" (must have been living in Germany too long!  ), but it can be a little annoying in the soup views in emplode as the "the"s get shoved away down with the other t names.
#79355 - 11/03/2002 09:35
Re: The word "the"
[Re: tonyc]
Loc: Seattle, WA, U.S.A.
FWIW, I have banished all of the the. I don't miss those pesky buggers. Some obscure lobe in my diminishing brain has done a fantastic job of helping me not have a seizure when "Clash" floats across the screen instead of "The Clash". Plus, for scrolling-type displays, I think it makes the information content richer and more immediate. Who wants to watch a bunch of "The" fly by??
Jim
Jim
#79357 - 11/03/2002 09:54
Re: The word "the"
[Re: tonyc]
but it *is* part of the bands' names....
Yeah, I went to nuns' school, too!
I think I'm loosening up (or is that losening up?), though, as I age. I've taken a number of other liberties with some of my MP3s -- like renaming and retitling all my Patti Smith into Dionne Warwick tunes for a little surprise when my older sister comes to visit...
Jim
Jim
#79358 - 11/03/2002 10:45
Re: The word "the"
[Re: tonyc]
I've never had a problem with the way the player handles "The", and I leave it in the band names all the time.
#79359 - 11/03/2002 11:08
Re: The word "the"
[Re: mschrag]
Loc: Lochcarron and Edinburgh
I said that the player's search-results screen sorts in that order; perhaps that's what you're thinking of?
#79360 - 11/03/2002 11:19
Re: The word "the"
My tongue-in-cheek comments aside, this is actually something that I agonized over a bit and where I wasn't 100 percent satisfied with the outcome. I couldn't cope with the idea of using a "Clash, The" syntax -- somehow takes the fun out of things for me -- makes me feel like I'm in a library. Whether to keep/drop "The" may also come down to how I interact with the player. I don't think I have *ever* used the remote in-car to search for a name. Using Playlists-->Artists-->, I just wasn't happy with having lots of artists bunch up under "T" when my brain wanted to find the Clash under "C".
In the end I think it's a matter of whatever floats your boat. Remembering a recent thread about capitalization (and maybe about how we have a responsibility to the artist to respect upper/lower case) I will say that I don't feel any such responsibility, regardless of what the nuns taught me!
Anyhow, one thing I really like about MP3 TagStudio is how easy it is to change my mind (I may change my mind on "The" yet again!) and recursively change the artist name for multiple albums. For grins, I just put "remind me never to play piano for them!" in the comment field of every Dead track. Simple.
Jim
Jim
#79362 - 11/03/2002 11:42
Re: The word "the"
[Re: jimhogan]
Loc: Richmond, VA
What interface does MP3 TagStudio have for patterned changes to tags? Is it a regular expression you can run on different tags?
Mike
#79363 - 11/03/2002 11:43
Re: The word "the"
Well then, let's review. Here are the capabilities and limitations as I understand them. Correct me if I'm wrong. Assuming the use of "The" in artists...
1. The player correctly finds them in a fuzzy search. If I type in "Doors" it works okay.
1a. However, artist which actually begin with D, E, and F appear first when scrolling down, *then* The Doors appears sorted as a "T" instead of a "D".
2. According to what people have said (I haven't tried this yet) playlists and tracks in Emplode are sorted in the T's instead of their proper place. This is not intuitive. Any artists with "The" would have to be manually (alt-dragged) into their proper place in the alphabet, and resorting the playlist would scew this up.
3. Also, according to what I've read here, artists in soup views are sorted with the T's. So, if soup views were implemented on the player, I'd have to go to the T's to get to all of my "The X" artists. Not intuitive.
Make sense? See why this is a bit limiting and counter-intuitive?
#79364 - 11/03/2002 16:12
Re: The word "the"
[Re: tonyc]
I agree, but the solution is hard, and I'm not sure that there's one that's totally correct. To bring up just one possiblility, what if you had the artist ``L'Ame Des Poetes'' on your empeg. This ought to be under the As (unless the French alphabetize using articles, which I doubt). But what if you also had an audio book by ``L'Amour, Louis''? That should be under the Ls. Which also brings up the question of how to alphabetize the names of people. It should be alphabetized by last name, but there's no way for the player to distinguish ``Pink Floyd'' from ``Earl Scruggs'', unless you wanted to list him as ``Scruggs, Earl'', which I don't like, and that doesn't even touch on the fact that ``Gabriel Garcia Marquez'' should be alphabetized under the Gs (for ``Garcia'').
Now, the best idea is probably what you suggest, that it ignore a leading ``The'', as well as ``A'', and maybe ``L''', ``Das'', etc. But nothing is going to be perfect, obviously, and that's why I've already resigned myself to not use the soup lists. I'll just keep creating playlists for everything I want to listen to, and organize them myself. But fixing this problem would tend to speed things up a little.
#79365 - 11/03/2002 16:25
Re: The word "the"
Loc: Minnesota
I always go for the first "real" word in the title myself. For me it's just "Beatles" for example. There was way too much under the T section, and it took to long to scroll there. Besides, I've organized my CD's that way for over 10 years so I'm used to it.
I've also broken down my "various artists" into categories too, that folder was getting a little overwhelming. Now it's "Soundtracks", "Compilations", etc.
I've never had a problem sorting or finding anything this way.
#79366 - 11/03/2002 17:20
Re: The word "the"
[Re: mschrag]
If I take your meaning correctly, I'd say the answer is no. It will recurse through subdirectories, but the substitution is complete -- overwrites whatever else is in the field. No regular expression facility that I can see, but it does have some other built-in geegaws for reformatting file names, titles, that may do what you are looking for.
Jim
Jim
#79367 - 11/03/2002 18:45
Re: The word "the"
[Re: tracerbullet]
All my artist fields (original ID3 and player database) contain "The" where appropriate. My PLAYLISTS however, use "The" after the unique part of the name ("Beatles, The")
This distinction in playlists isn't necessary with 2.0 software, but it's a left-over from the way I have my folders named on my backup drive (the OS doesn't have the fancy sorting abilities made easy by the player database).
Regardless of how Soup views get implemented on the player, I will not be changing the Artist fields to remove leading "The" or "A" - when information is presented in Track view, I want to see it as I would read it on the CD (or album or whatever).
One of the better suggestions (though costly in memory) was to allow using an alternate (new) field for sorting. This would take care of any special cases such as names. I just hope that Soup views will handle the basics like "The" and "A" - I'll just have to get by with a first-last linear alphabetical on artist names.
#79368 - 11/03/2002 19:43
Re: The word "the"
[Re: hybrid8]
You beat me to my suggestion on the alternate artist field which would be used for sorting. I used a CD catalog program called Catraxx which did this. It was smart enough to auto suggest when you used definite articles "The" for english speakers, but it also supported the appropriate ones in other languages.
Brainstorm alert!!!
Actually I think it could be done even simpler and without the extra field. Check this out.... When you enter your artists, you could enter them with a comma. They could be stored with the comma in the ID3 field (and subsequently in the player's FID files and database) to indicate that the player should sort them as such, but when displayed on the player (in track listings, soup views, etc) they could be *displayed* with the "The" in front of them. And for those who want to do their solo artists alphabetically by last name (something I hadn't even thought of until Bitt mentioned it) this would work also. Obviously, Pink Floyd would just be stored as plain ol' Pink Floyd.
So, the player, when it's displaying them (but not when it's sorting them) could just be instructed to do what our brains do already with names listed as such... Find the comma, read until the end of the string, and then read the rest of the string from the beginning to the comma. Like so:
char * pszComma = strchr(pszArtist, ',' );
if ( pszComma != NULL ) {
write_string_to_screen ( pszComma +1 );
pszComma = NULL;
write_string_to_screen ( pszArtist);
If the artist name info needs to be used later, substitute in your favorite pointer math or string/substring functions to leave the artist string intact. I think this strategy (storing the artists comma separated and displaying them "unravelled" so to speak) would handle all of the cases mentioned so far... Even Gabriel Garcia Marquez could be stored as Garcia Marquez, Gabriel. Plus no extra storage is needed! Just a tiny bit of CPU.
The only *possible* drawback I can think of is that any artists which already have commas in them (???) would get munged, but I can't think of any... So this could be a config option...
Anyone think this is a good idea? I can't believe I didn't think of this before, so there *must* be a flaw in my logic here....
#79369 - 11/03/2002 21:38
Re: The word "the"
[Re: tonyc]
Loc: Massachussetts
Crosby, Stills, Nash & Young
Earth, Wind & Fire
Harry Connick, Jr.
Credence, Clearwater, Revival (I think)
just off the top of my head...
Edited by dcosta (11/03/2002 21:38)
__________
davecosta
Hijacked 60GB MKIIa 2.0b13
#79371 - 11/03/2002 21:51
Re: The word "the"
[Re: tonyc]
Put it in the WISH list. I still love this idea. The bit to turn off the behaviour is nice too, but that needs more db space of course. I don't think I have any artist fields with commas right now.
Of course this will leave all your tracks looking different in other applications (not that *I* care about any other apps as much as the empeg...)
#79373 - 11/03/2002 22:08
Re: The word "the"
[Re: tonyc]
I'll go "me too" your post.
#79374 - 11/03/2002 22:52
Re: The word "the"
[Re: tonyc]
then you could technically enter "Wind & Fire, Earth," and "Stills, Nash & Young, Crosby
How about:
Crosby\, Stills\, Nash\& Young ?? (OK, just kidding!)
I think your solution is great. It could be enough for me to bring back "The" in my tags. Setting a "sort on comma" bit to yes by default would seeme the best way, Another thought I had was to use a double comma as a sort comma, but that would look a bit nasty (course you wouldn't see it on the player) -- Clash,, The?
Will follow th Wish List with interest
Jim
Jim
#79375 - 11/03/2002 23:21
Re: The word "the"
[Re: tonyc]
Anonymous
Unregistered
I am going to write a book named 'The'. The only content in it will be the word "the". Then I'll copyright it. Now anyone who wants to plagerize my writings, aka intellectual property, will have to compensate me for it.
So I'd say your best bet is to leave 'the' out.
#79376 - 11/03/2002 23:57
Re: The word "the"
[Re: tonyc]
I had an idea about this that I submitted to the ID3v2 guys, who promptly rejected it. My idea was to designate a special character to be a delimiter between the name of the artist and a leading article.
To demonstrate, I'm going to use a tilde (~), but in reality, it would have been a control character or some other non-display character that would make no sense in an artist's name. So the artist field would look like "Beatles~The " (notice the trailing space) or "Amour~L'" (notice the apostrophe at the end and the lack of a trailing space). When a player needed to search or alphabetize or whatever, it would use the artist name as given, but, upon display, the part after the delimiter would be printed first and then the rest, without the delimiter.
They didn't like this suggestion because (1) it would break older decoders (to which I suggested using the field termination character as a delimiter, and got no response) and (2) because ID3v2 already has a sort-by tag.
#79377 - 12/03/2002 03:35
Re: The word "the"
[Re: hybrid8]
Soup views deal with articles properly (i.e The Doors gets sorted under D). Or at least, the Artists soup view does; the others currently don't.
There is, in fact, a separate ID3v2 tag for "string to sort under in artist lists" (and others for title and album). But the player doesn't use it; keeping every artist string in memory twice would be too much overhead.
