#80869 - 14/03/2002 22:02 getting 'hijack config error' since v239
jwickis
Loc: India
The 'hijack config error' is coming up at bootup w/v239 on, when downgraded to v236 no error. The player seems to be OK otherwise, it's sitting here playing w/no problems.
#80870 - 14/03/2002 22:10 Re: getting 'hijack config error' since v239 [Re: jwickis]
KungFuCow
If you have any of the random dancing stuff in your config, you need to remove it or you will get the config error.
#80871 - 15/03/2002 17:15 Re: getting 'hijack config error' since v239 [Re: KungFuCow]
jwickis
Loc: India
If you have any of the random dancing stuff in your config, you need to remove it......
Don't have that in my config.
#80872 - 15/03/2002 17:16 Re: getting 'hijack config error' since v239 [Re: jwickis]
Post your config, we'll tell you what's broke about it...
#80873 - 16/03/2002 13:23 Re: getting 'hijack config error' since v239 [Re: tfabris]
jwickis
Loc: India
[synchronise]
seq_num=97
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
24=Image Pan
23=Analogue Clock
22=Clock
21=Flancedoor
20=InfoTex OTT
19=Tux too much
18=Tux Much
17=Sphere Plasma
16=Tube Plasma
15=Sugar Cube
14=Tubular
13=Pianola
12=Spectrokit 128
11=TimeShade 128
10=Spectrometer 128
9=Lavatory Floor
8=Hula Hoops
7=Casualty
6=Anna Vu
5=Funnelweb
4=Oscilloscope
3=SoundFlag
2=Sound Samosa
1=Image Pan
count=24
[VisualFavourites_FM]
count=0
[hush]
hushpercent=50
[display]
visual_names=1
caching=0
[volumecap]
enabled=1
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[controls]
stalk_side=none
[tuner]
region=us
[Options]
Name=jeffsempeg
[User Info]
email=*******************
phone=xxxxxxxxxx
name=**** ********
[Network]
Gateway=0.0.0.0
Netmask=255.255.0.0
IPAddress=169.254.88.77
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=500000.45
[aux]
source=
title=
artist=
[output]
notify=1
[hijack]
menu_remove=calculator
menu_remove=font display
old_style=1
time_offset=-122; Central Standard Time (CST) Indiana
#80874 - 16/03/2002 13:27 Re: getting 'hijack config error' since v239 [Re: tfabris]
jwickis
Loc: India
Here's the Mk2a's config as well, the first reply was a Mk2.
[Options]
Name=jeffsrio
[User Info]
Email=****************
Phone=*** *** ****
Name=xxxx xxxxxxxx
[controls]
stalk_side=none
[tuner]
region=us
[Network]
Gateway=0.0.0.0
Netmask=255.255.0.0
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=500000
[display]
visual_names=1
caching=0
[synchronise]
seq_num=164
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[hush]
hushpercent=30
[volumecap]
enabled=1
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[aux]
source=
title=
artist=Rio-car
count=0
count=0
count=0
count=0
[output]
notify=1
[hijack]
time_offset=-363
old_style=1
#80875 - 16/03/2002 16:31 Re: getting 'hijack config error' since v239 [Re: jwickis]
Well, hook up the serial port to some software, and watch for the error message indicating exactly which line is causing trouble..
#80876 - 16/03/2002 18:36 Re: getting 'hijack config error' since v239 [Re: mlord]
jwickis
Loc: India
Well sorry for the trouble but now it's working, no hijack config error coming up. I'm so lost now, I don't know what I did or what happened, not enough sleep I guess.
#80877 - 20/03/2002 23:47 Re: getting 'hijack config error' since v239 [Re: jwickis]
frekin
I haven't been able to check the forums for a few weeks, so I finally autoHijacked today from v2.35 to v2.46. Now I'm getting a "hijack config error", though I never made any changes to the config.ini between those versions:
[Options]
Name=Dirty Sanchez
[User Info]
Email=*******@hotmail.com
Phone=(***)***-****
Name=****** *********
[Network]
Gateway=***.***.***.***
Netmask=255.255.255.0
IPAddress=***.***.***.***
DHCP=0
[sense]
muteaction=0
mute=-1
[display]
visual_names=1
caching=0
[hush]
hushpercent=10
[volumecap]
enabled=1
[kenwood]
disabled=0
[ramp]
disabled=0
[controls]
stalk_side=none
[tuner]
region=us
[power]
off_timeout=30000
[aux]
source=
title=
artist=
[synchronise]
seq_num=175
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[menu]
quit=1
sort_playlist=0
count=0
count=0
count=0
count=0
[hijack]
;kftpd_password=empeg
time_offset=-480
kftpd_show_dotfiles=1
khttpd_files=0
khttpd_dirs=0
dance=breakdance.raw; one of the "original" dances
dance=princedance.raw; one of the "original" dances
dance=stonkdance.raw; one of the "original" dances
dance=AirTar.raw
dance=Dafonze.raw
dance=MoreDancing.raw
dance=PoleDancer1.raw
dance=PoleDancer2.raw
dance=PoleDancer3.raw
dance=TopPoleSpin.raw
dance=ymca.raw
[ir_translate]
PopUp0=Shuffle,Repeat,Info,Visual,SelectMode,Clock,Detail
KnobLeft=KnobLeft.U,Info.N,null
KnobRight=KnobRight.U,Visual+.N,null
;Kenwood RC-500 Remote
B94613=Ok
B9460D=Cancel
B9460C=Search
B9460A.LN=Track-
B9460B.LN=Track+
B94616=Shuffle
B9460F=Info
For each change detailed below, I used the Emplode (not jEmplode) config.ini editor, synchronized, then opened the Hijack menu and used the reboot function...
The first thing I did was check every hijack-related line to look for stray characters. Then I removed the "time_offset=-480" line, which didn't get rid of the problem. Then I got rid of the first three "dance=" lines, thinking maybe the comments were somehow screwing things up. No luck. Finally, I got rid of all the "dance=" lines, and the config error message disappeared. After I had satisfied myself that the error message wasn't going to return by rebooting multiple times, I added the "dance=" lines back in manually. The "hijack config error" message came back!
Has the syntax for hijack's flancedoor settings changed somehow?
#80878 - 20/03/2002 23:56 Re: getting 'hijack config error' since v239 [Re: frekin]
Yes, the flancedoor lines are no longer supported by Hijack and must be removed. There have been a few other posts on this subject elsewhere in the BBS.
#80879 - 20/03/2002 23:58 Re: getting 'hijack config error' since v239 [Re: jwickis]
RobotCaleb
umm, they were taken out.
as should yours
#80880 - 20/03/2002 23:58 Re: getting 'hijack config error' since v239 [Re: mlord]
frekin
I suddenly remembered that I had set up the serial cable in a convenient location, so I decided to load up hyperterminal and check things. Here's the last section that hyperterminal displays:
[hijack] ERROR: : "dance=breakdance.raw; one of the "original" dances"
[hijack] ERROR: : "dance=princedance.raw; one of the "original" dances"
[hijack] ERROR: : "dance=stonkdance.raw; one of the "original" dances"
[hijack] ERROR: : "dance=AirTar.raw"
[hijack] ERROR: : "dance=Dafonze.raw"
[hijack] ERROR: : "dance=MoreDancing.raw"
[hijack] ERROR: : "dance=PoleDancer1.raw"
[hijack] ERROR: : "dance=PoleDancer2.raw"
[hijack] ERROR: : "dance=PoleDancer3.raw"
[hijack] ERROR: : "dance=TopPoleSpin.raw"
[hijack] ERROR: : "dance=ymca.raw"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
hijack_tone_init completed.
Seems pretty conclusive. What I don't understand is why the original poster got the error, even though he has no flancedoor lines.
#80881 - 21/03/2002 00:07 Re: getting 'hijack config error' since v239 [Re: tfabris]
frekin
Oops...from now on I'll check the Hijack FAQ Changelog whenever I use autoHijack to jump through multiple Hijack versions in one step, hehe. Sorry for all that ascii above.
#80882 - 21/03/2002 00:18 Re: getting 'hijack config error' since v239 [Re: frekin]
loren
Cool, That's exactly why i started keeping a changelog. Hope it comes in handy. =]
|| loren ||
#80883 - 21/03/2002 16:36 Re: getting 'hijack config error' since v239 [Re: mlord]
jwickis
Loc: India
I found out what was wrong, it's in my config. post, the last line has a period in it. I didn't put it there as puncuation of the post. All is well my guess is when I took out the dance lines it was a stray I didn't see.
#80884 - 22/03/2002 17:20 Re: getting 'hijack config error' since v239 [Re: tfabris]
jloew
Loc: SF Bay Area
I couldn't find anywhere that explained why "dance=" is no longer supported???
MkIIa [blue]BLUE[/blue]
#80885 - 22/03/2002 17:21 Re: getting 'hijack config error' since v239 [Re: jloew]
No explanation has been given.
I happen to know why, but if I told you, I'd have to kill you.
#80886 - 22/03/2002 17:24 Re: getting 'hijack config error' since v239 [Re: jloew]
guardian__J
Loc: MI, USA
what I can infer from Mark's post, I think something similar is going to be built into the next version...
but just my own guess...I have no privilaged info and have not received any secret info...
guardian__J
MKIIa 20g Smoke
#80887 - 22/03/2002 17:28 Re: getting 'hijack config error' since v239 [Re: tfabris]
jloew
Loc: SF Bay Area
You guys are VERY mysterious! ;-)
