#81249 - 16/03/2002 12:07 jEmplode 28 - Rectangle select/move tool
mschrag
Loc: Richmond, VA
http://www.jempeg.org/jemplode20.jar
I started to take up Mark on his Hijack Animation Challenge and realized that without a block select tool with at least internal cut/copy/paste/move/etc support, it's nearly impossible to really do any good work strictly inside of jAnimEdit, so here it is:
AnimEdit - _Internal Only_ Cut/Copy/Paste of Image blocks (Ctrl-X/C/V)
AnimEdit - Select Tool (shift-drag = move, drag = copy)
AnimEdit - Much cleaner Tool architecture
#81250 - 16/03/2002 20:07 Re: jEmplode 28 - Rectangle select/move tool [Re: mschrag]
loren
YES!!! Thank you thank you thank you!
|| loren ||
#81251 - 16/03/2002 20:16 Re: jEmplode 28 - Rectangle select/move tool [Re: mschrag]
mschrag
Loc: Richmond, VA
I need to add this to the help file, but in selection mode, hit Enter to "commit" the copied/pasted/moved selection. Mike
#81252 - 17/03/2002 10:53 Re: jEmplode 28 - Rectangle select/move tool [Re: mschrag]
I'd like to figure out an easy way to have people upload these animations to RioCar.org, and have a preview. I'd like to have a way for them to just upload one thing, and have the site somehow generate the preview from that. Do you (or anyone else) know of a way of doing this? I'd prefer doing an animated GIF or PNG, instead of people having to upload frame by frame and needing to specify the play order.
#81253 - 17/03/2002 11:25 Re: jEmplode 28 - Rectangle select/move tool [Re: drakino]
mschrag
Loc: Richmond, VA
jEmplode 29 is going up right now -- It has a new File.. Save As Animated GIF.
Mike
#81254 - 17/03/2002 11:26 Re: jEmplode 28 - Rectangle select/move tool [Re: drakino]
Perhaps some could just hack up a simple java-player for the actual animation files themselves.. ?
