#94971 - 20/05/2002 18:14 Info mode reverting after sync
svferris
Loc: San Diego, CA, USA
I'm not sure if this is a bug or a misunderstanding of how settings are saved...
If I'm working in emplode and I switch the info mode on the empeg, when I do a sync, the info mode reverts back to the previous info mode.
Is this a bug, or do I need to shut down the player (or perform some other action) for the info mode to save properly?
#94972 - 06/06/2002 10:42 Re: Info mode reverting after sync [Re: svferris]
Ooooh.. Roger would know.
Normally, player settings are not committed to flash until power off or reboot. When doing a Sync, the player s/w gets restarted without a reboot, so perhaps it is reading the old settings from flash.
If this were the case, things like volume, balance, etc.. would also suffer. Try it: change volume really up or down, and then sync. Does it revert?
#94973 - 06/06/2002 13:05 Re: Info mode reverting after sync [Re: mlord]
svferris
Actually, I think I read in another post that this is a bug in beta11 when in Home mode.
Can anybody else confirm?
#94974 - 06/06/2002 14:01 Re: Info mode reverting after sync [Re: svferris]
Oh.. there is a bug like that, but most folks enable the Hijack fix for it (in the Hijack menu).
