#95918 - 27/05/2002 14:07 Second disk dead?
jdandrea
Loc: New Jersey
(gulp)
I haven't had the need to make any player changes until today. I tried Emplode ... and ... got a sync error (this is through ethernet, which I never have a problem with).
It already rebooted, so I went into Hyperterminal and dropped to shell. Then I rebooted again and got this (insert shudder here).
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v269 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Fri May 24 13:37:12 EDT 2002
empeg-car player (hardware revision 9, serial number 30103046)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: ÉBÍ-ÄJÓA­2²0                           , ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: ÉBÍ-ÄJÓA­2²0                           , 24191MB w/18258kB Cache, CHS=49151/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e6
Partition check:
hdb: hdb1 < > hdb2 hdb3 hdb4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,68).
Tried to mount /dev/hdc4 but got error 22
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
-- JD - SN# 040104008 (120GB Blue, Digital Out)
#95919 - 27/05/2002 14:16 Re: Second disk dead? [Re: jdandrea]
The above line looks funky, especially since you've got 18MB of cache You might have a bad drive cable or it has just come loose from one of the drives. If you talk to empeg they'll tell you what to do. No need to panic
- Trevor
#95920 - 27/05/2002 14:28 Re: Second disk dead? [Re: tman]
jdandrea
Loc: New Jersey
Yeah, that's a lotta cache.
To think it has been working (or has appeared to be working) all this time, no problems playing any tracks (it's a nearly full install - two 20GB disks), I bring it indoors and - I confess, I didn't tell the whole story. Here's the whole enchilada:
First, I upgraded to the latest Hijack (ohhh, but that never causes any problems ... no really!).
After that I kicked off Emplode and went in via serial (had to change the player config to use DHCP). Went to sync and - got a sync error (the player had also rebooted).
Went into hyperterminal, dropped to shell, did a rwm, edited config.ini and made the necessary changes (instead of DHCP, I just changed the IP instead). Did a rom and rebooted.
Tried emplode again with TCP/IP - no problems. Went to remove an artist entry (and all associated tracks), synced ... again, same problem - sync error.
Back into hyperterminal, back to shell. Looked around - tried looking at /disk0 and /disk1 - uh oh, no disk1. Nothing there.
Tried mounting /disk1 - nothing. Rebooted player ... THAT'S when I noticed the garbled mess.
#95921 - 27/05/2002 15:15 Re: Second disk dead? [Re: jdandrea]
Greetings!
Probably your cable or jumper came loose off the second drive. You might want to open it and take a look.*
* Disclaimer: I know this particular unit is not under warranty, so feel free to look.
#95922 - 27/05/2002 15:17 Re: Second disk dead? [Re: pgrzelak]
jdandrea
Loc: New Jersey
OK. (Now, don't I need a special wrench for that?)
#95923 - 27/05/2002 15:23 Re: Second disk dead? [Re: jdandrea]
Greetings!
Yup. A 2.5mm hex wrench. 5:1 loose cable or jumper.
#95924 - 27/05/2002 15:39 Re: Second disk dead? [Re: pgrzelak]
Fixed. Loose cable.
#95925 - 27/05/2002 15:56 Re: Second disk dead? [Re: pgrzelak]
jdandrea
Loc: New Jersey
Yup, all's well - though upon examining the insides it sure didn't appear that anything was loose. Hmm ... hmm ...
No matter. Thanks to everyone for the help, esp. Paul for over-the-phone coaching.
Edited by jdandrea (27/05/2002 15:56)
#95926 - 27/05/2002 16:02 Re: Second disk dead? [Re: jdandrea]
Yeah, Paul is a great guy! He once helped me out tremendously when I had a problem installing a second HD.
It's because of people like him this community is the way it is, and I'm proud being part of it!
#95927 - 27/05/2002 16:53 Re: Second disk dead? [Re: BartDG]
Aw... Shucks...
#95928 - 28/05/2002 09:33 Re: Second disk dead? [Re: jdandrea]
David
Loc: Cambridge
That could be a sign of the cable being faulty. If you get this problem again, email me for a replacement.
#95929 - 28/05/2002 17:19 Re: Second disk dead? [Re: David]
Slightly off-topic here, but...
I bought a spare player during the fire sale. I've loaded it with about 8 GB of music, and tested it for several days in my car, and it seems to be working perfectly.
However, we all know there is a non-trivial likelihood that the drive cable is indeed defective and just hasn't shown the problem yet in the limited amount of testing that I did.
These cables are available now... but how about in the future? If I install my empeg in a second car a year from now, and a month after that the cable fails, what will my options be?
#95930 - 28/05/2002 17:57 Re: Second disk dead? [Re: tanstaafl.]
acurasquirrel_
Wondering the same thing kinda. Say some how my cage and harness get destroyed by say a freak car fire but I was able to rescue the empeg with minimal 3rd degree burns. Now I need a new car dock will I be able to get one from you guys in like a year?
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
#95931 - 28/05/2002 17:58 Re: Second disk dead? [Re: tanstaafl.]
Laura
Loc: Greenhills, Ohio
Good question since a lot of us have spares. I haven't even taken mine out of the box yet.
Laura
MKI #017/90
whatever
#95932 - 28/05/2002 21:36 Re: Second disk dead? [Re: acurasquirrel_]
If you're worried about that, you've only got a couple of days to buy a spare car dock, as the Empeg store closes on the 31st of this month. I recommend you take advantage of this opportunity.
#95933 - 29/05/2002 00:51 Re: Second disk dead? [Re: tanstaafl.]
David
Loc: Cambridge
If your cable is going to fail, it will probably do so within the first month of regular use.
If you have spare players, unpack them and use them as your normal unit for a month.
Cables will be available for as long as I am providing support, which at the moment is indefinitely.
