#98161 - 07/06/2002 03:25
HELP
Bad news for me tonight. I had my deck in my friends sled tongiht and the 3 amp fuse blew on the yellow wire off the cage.
After i got back to my car and got to test my empeg, i found out the the screen doesn't turn on anymore, and the led on the blinks like the unmodified led does. My led i set in hijack to blink every 10 seconds. Here is a copy of the bootup. What is wrong with my player?
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v274 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Thu Jun 6 19:37:21 EDT 2002
Processor: Intel StrongARM
empeg-car player (hardware revision 9, serial number 40104126)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9b734
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK3017GAP, ATA DISK drive
hda: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
empeg-flash driver initialize
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:1
e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Oliver
#98162 - 07/06/2002 04:18
Re: HELP
[Re: oliver]
Greetings.
Ugh. The boot log looks fine to me. Questions:
a) Do you get sound out of the unit? (display problem only?)
b) If you get sound, do you get the normal LED pulse then?
c) Do you see the controlled (slow) blink rate when the player is in standby?
d) Can you control or see the player via ethernet? serial? USB?
I suspect power to display board. If the display is broken, or power is not getting to the display, the PIC will power the blinking LED, but the blink software in hijack should only modify the blink rate when the player is off... I suspect that a fuse blew going to the display. Contact support for troubleshooting details.
#98163 - 07/06/2002 04:23
Re: HELP
[Re: pgrzelak]
a) Yes, i do get sound out of the player. But it takes a minute or two for the player to start playing
b) Yes, The led pulses normally.
c) The 4 buttons on the front of the empeg doesn't seem to be responding. But the volume did work, but was very slow.
d) I'm running xp with beta 11 and my usb didn't work. Serial did work with hyperterm. didn't check ethernet.
Thanks for the reply. I hope this helped a bit more.
Oliver
#98164 - 07/06/2002 04:31
Re: HELP
[Re: oliver]
Greetings!
Do you have the illuminated button hack on this player? Did the unit suffer from a fall?
It seriously sounds like a blown fuse powering the display, display board or fuses. Bad new either way, I am afraid... Definately contact support!!!
#98165 - 07/06/2002 04:33
Re: HELP
[Re: pgrzelak]
Nope, don't have the illuminated button hack, although i wish i did because that is one of the coolest things i've seen.
I've never dropped my empeg, i've never let anyone else carry it. I treat it like gold. This will be the last time i bring it to a friends car
I'm going to take off the faceplate to look at my display.
Oliver
#98166 - 07/06/2002 04:55
Re: HELP
[Re: oliver]
I suspect the delay in startup is because of the filesystems. If something blew out, I am guessing your filesystem needs an fsck. You might want to try and do a sync, just to put your filesystems and database file back in order.
Given the blown main fuse, I am guessing that the nipple on the display itself should be fine. I am guessing the fuses to the display board are gone, but that would not explain why the buttons don't work. Can you confirm that while playing a song?
#98167 - 07/06/2002 05:05
Re: HELP
[Re: pgrzelak]
Ok, i just checked the buttons. They seem to be working fine. i can put the player into standby, and the led blinks how i set it to in hijack. I can pause and unpause the player. fastforward and etc. Volume still seems slower, but thats probally just because i don't see my screen.
I just tried to do a sync with the com port with no luck. Emplode isn't finding my deck.
And i still can't find my 2.5mm hex tool  this isn't my night.
Oliver
#98168 - 07/06/2002 05:06
Re: HELP
[Re: oliver]
Also, my player won't go to the prompt. When it tells me to press q, i do, and wait and wait and wait without any reply.
Oliver
#98169 - 07/06/2002 05:17
Re: HELP
[Re: oliver]
Greetings!
Well, at least the audio and controls work. As to removing the face, it is a 2.5mm hex. If you did not have a physical shock, though, the display tube is likely to be in tact. Which would only leave fuses / power path. I know there is a way with a meter to check the power at test points on the display board. But I don't remember what those are at the moment. Looking...
#98170 - 07/06/2002 05:19
Re: HELP
[Re: oliver]
From the terminal session? Try typing q again - if the player is in standby, you sometimes need the additional hit. Meanwhile, reboot with the terminal active, watch the boot and try getting into it from there after the player loads.
#98171 - 07/06/2002 05:28
Re: HELP
[Re: pgrzelak]
ethernet and com port doesn't seem to be working to connect via emplode. USB does show up. i can connect, but when i try and sync the good old xp usb driver craps out.
I tried hitting q a bunch of times durning startup, but it just seems to hang after it says it started the player.cpp file.
Oliver
#98172 - 07/06/2002 05:35
Re: HELP
[Re: pgrzelak]
finally got into the prompt. i tried typing fsck and it echoed back
empeg:/empeg/bin# fsck
Parallelizing fsck version 1.19 (13-Jul-2000)
How do i actually run the file checker?
Oliver
#98173 - 07/06/2002 05:40
Re: HELP
[Re: oliver]
Greetings!
The quick answer. This might help...
I know there are a few test points on the display board, but I do not remember where. Meanwhile, the fuses for the display board are underneath the drive tray. You will not be able to get to them (surface mount) unless you void the warranty and remove the drive tray. Any word from support?
Edited by pgrzelak (07/06/2002 06:17)
#98174 - 07/06/2002 06:22
Re: HELP
[Re: pgrzelak]
I just took off the fasica, and the fill nipple is not broken. So this is really good i guess. I wrote david right before i started this thread. And he asked me to check the nipple also.
I guess a good thing that has come out of all this is i'm not a stranger any more  finally building up my post count
Oliver
#98175 - 07/06/2002 06:28
Re: HELP
[Re: oliver]
Valid point about the posting!!!
I am glad that the nipple is okay. That was the worst concern, but it was unlikely. Given that the fuse blew in the line, I am guessing you lost some fuses going to the display card as well. Unfortunately, the only way to check is to remove the drive tray and verify with a meter. There might be other test points or other fuse to check as well, but I am sure David will fill you in on what to test next.
I have a bad feeling that you will be sending this unit home for repair...
#98176 - 07/06/2002 09:32
Re: HELP
[Re: oliver]
When a resolution is reached for this problem, please let me know, and I will add it to the FAQ entry that describes the fill nipple.
#98177 - 07/06/2002 16:52
Re: HELP
David gave me permission to open the player and test the fuses. I will do this any report back to the bbs. I would to thank paul for all his help this morning.
Oliver
#98178 - 07/06/2002 21:06
Re: HELP
[Re: pgrzelak]
Hey Guys,
I just finished testing the 3 1amp fuses near my display connector. The top 2 are still good. The only one that isn't good is the lower fuse. I'm attaching a picture. Please note this isn't an actual picture of the board in my mark2a, this is from the site with the directions on how to fix these fuses.
Oliver
#98179 - 08/06/2002 01:05
Re: HELP
[Re: oliver]
on a brighter note, the usb on my mark 1 has worked flawlessly with windows xp and beta 11 hijacked.
Oliver
#98180 - 08/06/2002 05:48
Re: HELP
[Re: oliver]
I'm stealing that picture for the FAQ, is that OK with the two parties involved in its creation?
#98181 - 08/06/2002 05:48
Re: HELP
[Re: oliver]
Greetings!
Glad to hear it is only the fuse. I don't know if you are comfortable with the soldering to replace it or not, but identifying the source of the problem is more than half the battle.
I find it interesting that the Mark 1 doesn't have the USB problem with XP... Tony: was the USB problem fixed in the internal releases, or are it still being actively worked on? Could be an interesting clue...
#98182 - 10/06/2002 14:22
Re: HELP
[Re: oliver]
Loc: Rijswijk, Netherlands
Amazing. I have the exact same problem so it seems (not the sinc problems though). The same fuse blown. Thx for this thread. Anyone for the exact purpose of this fuse?
#98183 - 10/06/2002 14:38
Re: HELP
[Re: pgrzelak]
I don't run XP, and also the alpha team doesn't have the latest-latest-latest internal build, so I don't know whether or not the USB-driver-under-XP issues have been resolved or not.
#98184 - 11/06/2002 03:13
Re: HELP
They haven't.
#98185 - 14/06/2002 18:01
Re: HELP
[Re: pgrzelak]
Well i just got back from my trip. My mark1 worked excellent expect for twice on the way back it over heated. Thanks mark for the temp warning. The usb with xp i stated as working great has now stopped working again. I was able to add about 4 cds right before i left, and i just tried to add a few more and it just stops half way through (or less).
Oliver
#98186 - 07/07/2002 13:44
Re: HELP
[Re: oliver]
Great News guys,
David wrote me an email friday night saying that my player has been fixed and is on its way back to me. I would like to thanks everyone, especially paul g (pgrzelak) for the help when my player died
Without this forum the empeg wouldn't be such a great investment!
Oliver
#98187 - 07/07/2002 21:01
Re: HELP
[Re: oliver]
Loc: Tucson, AZ
Well put! So what product is this group buying next? Cars, boats, etc. I would like this kind of support from everything I buy!
Steve
#98188 - 09/07/2002 01:01
Re: HELP
[Re: oliver]
Got my player back today, good as new. So happy to have her back in mint condition  David also fixed the dc power plug for me (sometimes my player thought it was at home when it was in the car) Happy happy joy joy! Now if i could only get to a journeyman a little quicker
Oliver
#98189 - 09/07/2002 03:44
Re: HELP
[Re: oliver]
Greetings!
I am glad it worked out! Of course, it is still a question as to why it happened. There might have been a wiring problem in the car you tried it out in.
#98190 - 09/07/2002 10:21
Re: HELP
[Re: pgrzelak]
that would be my guess, but my friend has been using his empeg daily in his car without a repeat of this problem. I guess i just have sh*tty luck
Oliver
