#247008 - 23/01/2005 22:03
Re: Wireless Connectivity Annoyance
[Re: srhodes]
Loc: Southwest
Quote: Another possibility is interference from other 802.11 gear nearby. Can you change channels on the thing?
Unfortunately, I don't think I can.
Try 192.168.1.255 from your web browser as I believe that is the default web address for the WET11 or just use the address that it gets assigned. You should get the Linksys web configuration screen (after login of course--which I'm hoping you've changed the user name and password for...) and be able to change the assignment of the SSID, IP, ect. And you'll notice at the top a "Status" tab on which there is the Wireless Site Survey to see other traffic in the area.
From that information you should be able to choose a suitable channel on your Access Point away from all the traffic. See the WiFi Planet's Assigning 802.11b Access Point Channels tutorial for more detail than you need. Reality, there are only three channels to choose from 1, 6, 11 (in the US) w/o overlap.
Cheers. Tim
