#296556 - 05/04/2007 13:40
Re: More gremlins: Pop when switching off ignition.
[Re: snoopstah]
Quote: However, since plugging the player back into the car this morning, whenever I switch off the ignition, the empeg completely shuts down, and causes a pop through the amps.
Well, the empeg is *supposed* to completely shutdown when the ignition is switched off. So what's new here?
Note that there is a config option in emplode (or config.ini) to adjust the delay time from ignition-off to empeg-off -- perhaps that setting got lost/reset, and all you need is to set it back on again (to, say, 4 seconds or so). ??
