Quote: Oh yea, big problem there, esp if I use a 2nd hand eBay card.
Well, now I am totally confused. I don't want to spend much more money on this, can anyone recommend a Linux disro I may get on with ???
Cris.
Well, totally sight-unseen, I would recommend Ubuntu Server. The new "Fiesty" is due for final (initial) release later this month, and would probably do an excellent job for you.
(I don't currently have any RAIDs set up around here; the big iron bits I just do manually, because I'm working at a layer or two beneath the RAID s/w. In other words, I'm not much use to you unless you can pop over with your system for an evening. )
