As I've stated before, I'm an X10 junkie. I love the products (mainly the lighting ones).
I recently bought wall switch modules so I can control ceiling lights and an outdoor light with the system. My problem comes in the wiring stage, adn I figured this would be the best place to ask.
I followed the instructions in the attached pamphlet. I set the code, turned off the breaker, and unscrewed the wall plate and old switch. Then I ran into the problem.
My current switch has 3 wires running into it instead of 2 as the instruction say. No, it isn't a 3 way circuit. Only one switch turns the light on. I found the same thing in the other switch I wanted to wire. It appears all of my switches have three wires running to it. Furthermore, all the wires are white sheethed (sp?).
Any ideas on what I should do?
73768-x10 switch.pdf (456 downloads)
